Any German speakers willing to do a bit of translation?
Quote Me Happy
PostPosted: 08:53 - 11 Sep 2011    Post subject: Any German speakers willing to do a bit of translation? Reply with quote
Hi,
I'm after this PDF translated in to English.
I'm willing to make a small payment as well - just a small one but if you're sat at home doing not much it's an easy 10 mins work.
Thanks
Raffles
PostPosted: 11:10 - 11 Sep 2011    Post subject: Reply with quote
You should have a word with these guys, they may be able to help you.
https://www.youtube.com/watch?v=kzolOc5VxL0
Minty
PostPosted: 11:47 - 11 Sep 2011    Post subject: Reply with quote
I went to Trotters German Speaking classes. My teacher was class and very thorough:
https://www.wearysloth.com/Gallery/ActorsM/tve11911-19850228-258.jpg
I can have a go, if you like?
My fingers smell of your mum.
Quote Me Happy
PostPosted: 11:55 - 11 Sep 2011    Post subject: Reply with quote
If you sprechen sie Deutsch Mr Mint then go for it Very Happy
Aff
PostPosted: 12:58 - 11 Sep 2011    Post subject: Reply with quote
Heres the Google Translate version... suppose its slightly more understandable
Hepco & Becker GmbH
At the stone wall 6
66955 Pirmasens
Germany
Luggage carriers with Gepackbrucke Tel: +49 (0) 6331 1453 100
Fax: +49 (0) 6331 1453 120 Hepco &
Yamaha XT 600 E e-mail: vertrieb@hepco-becker.de BECKER
from year 95 Internet: www.hepco-becker.de
Item number: 650 480 00 01 black
The kit umfaRt folqende parts:
Koffetrager 1 left 1 right Koffetrager
1 1 Gepackbrucke Versteifungsbugel
2 hexagon bolts M 8 x 25 11 0 8.4 washers
1 Hexagon screw M 6 x 25 5 0 6.4 washers
Sechskantschtauben 4 x 20 2 M 6 M 8 self-locking nuts
2 Sechskantschtauben M 8 x 65 5 self-locking nuts M 6
4 Schlotschtauben M 6 x 16 2 Aludistanzen 0 15 0 9 x 13 mm
2 Allen screws M 8 x 25 1 Inbusschtaube M 8 x 20
1 0 6.4 x diameter washer 4 0 18 mm plastic caps M 8
2 slices of body 0 8.4 0 25 x 1 mm plastic cap M 6
Installation instructions:
Remove the seat, grab handles and rear panel disassemble the flasher cable
rear turn signals separate and remove the blinkers.
The front tubular strut of the right Koffetragers Auten is about the attachment to the exhaust
Frame with the screw M 8 montiet x 20. The front side of the bracket
Koffetragers is montiet Auls over the muffler attachment. The original thick-washer
comes among them, which is fixed with the original screw.
The front of the strut tube is left Koffetragers at the rear top of the screw
Soziusfufirastenauslegers screwed. The brace is between the frame and boom
pushed; Verschraubeung to use the hexagon socket screw M 8 x 25. Under forward
Fixing zwischengefugt be 3 washers as spacers 8.4 0. For screwing
also use the socket screw M 8 x 25.
The front side of the left bracket Koffetragers will step over the
Side bar of Kotflugels montiet. For this purpose, use the hex head screw M 6 x 25, by
inside a body of disc 0 6.4 x 0 18 mm inferior.
Now the turn signals to the holding tabs of Koffetrager as original mount and the flasher cable
stuck together, they have to not be verlanget.
Rear panel mount. The handles on the front fittings as original
. Mount The rear screw holding the handle is done together with the
Gepackbrucke.
The Aludistanzen 0 15 0 9x13 mm into the holes used as spacers, consider writing the
Gepackbrucke slide. To fasten the hexagon bolts M 8 x 65 along with washers
. use
Happens behind the fixing of
Gepackbrucke to the original
Blinkerhaltem together with the
Brackets of Koffetrager. This be of montiet OUTDOORS. To
Fixing the hex screws M 8 x
25 use. The wheel side of the forth
Body slices 0 0 8,4 x 25 mm plus
Install self-locking nuts.
The Versteifungbugel is placed so dat it over the
Kotflugel proceeds below the license plate holder.
He is on the left and right on the small side tabs
the Koffetrager (seen in direction of travel - dayor) with
M 6 x montiet Schlofischrauben the 16th With the
Kotflugel he is not screwed.
Hepco & Becker are montiet case with Aluadapter, then the Aluadapter with the
Hexagon screws M 6 x 20 ansatt montiet the vent screw M 6 x 16.
After assembly, check alll the fittings are tight and
Plastic caps imprinted.
Furthermore we offer for this bike with one Motorschutzbugel At.-Nr. On 501 407.
Electric Bike Project
Quote Me Happy
PostPosted: 14:51 - 11 Sep 2011    Post subject: Reply with quote
While I appreciate the effort, I'm after a proper translation Thumbs Up
tatters
Exxon Valdez
PostPosted: 16:01 - 11 Sep 2011    Post subject: Reply with quote
Translation below
Bringen Sie die Yamaha XT600E und Hepco & Becker painner / Rack-System rund um herr Tatters zu einem Abend fit wie er ausgestattet wie exakt die gleichen Rack auf einer KLR650C und weiß, die Hälfte der mitgelieferten Schrauben sind die falsche Länge.
Bring the Yamaha XT600E and Hepco & Becker painner/rack system around to Tatters to fit one evening as he as fitted the exact same rack on a KLR650C and knows half of the bolts supplied are the wrong lenght.
Quote Me Happy
PostPosted: 16:08 - 11 Sep 2011    Post subject: Reply with quote
Cheers Laughing
It's not the fitting I'm having problems with though, it's just that I want the info to put up on my site as well though as it's a fairly common problem.
Anyway, someone has lost all the nuts and bolts that came with the kit so a translation would be useful so I can order replacements.
The last post was made 14 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 59.23 Kb
