chain rust?
WULFSTAN
PostPosted: 14:22 - 11 Sep 2011    Post subject: chain rust? Reply with quote
alright lads anyone got any tips how to get really bad rust of my old fellows cbr 600 chain thats been stood for 2 years ? thanks
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
Quote Me Happy
PostPosted: 14:43 - 11 Sep 2011    Post subject: Reply with quote
I would imagine a chain that has stood for two years and has 'really bad rust' will need replacing as many of the links will have probably seized.
However, if you want to give it ago I'd use a stiff brush and some paraffin.
Dazbo666
PostPosted: 15:04 - 11 Sep 2011    Post subject: Reply with quote
Maybe a spark plug brush, and paraffin, then re-oil it....
but expect to have to replace the chain VERY soon
Word of the day : DILLIGAF
Oldie
PostPosted: 17:03 - 11 Sep 2011    Post subject: Reply with quote
Take it off the bike and leave overnight in a pan of vinegar - then as above.
Mr Hammers
PostPosted: 22:32 - 11 Sep 2011    Post subject: Reply with quote
When I got my boy his KTM the chain was pretty much locked solid with rust in most places. Did nothing other than leave it in an oil bath for almost six months, with an occasional poke. Didn't expect much, but surprisingly it worked, and is still going strong today! Very Happy
A Guide To Powerbands
serlant
PostPosted: 07:47 - 12 Sep 2011    Post subject: Reply with quote
When i bought my vtr it had been sat for a year and the chain was pretty rusty. just oiled it before i first rode it and when i got back gave it a good scrub and that was 99% of the rust gone, I would make sure all the links are free first.... have adjusted the chain 3 times in 5000 miles.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
Paxovasa
PostPosted: 08:22 - 12 Sep 2011    Post subject: Reply with quote
As most have said, check the chain for tight links.
Get the rear wheel off the ground and give it a close inspection and lube it to the extreme...
PostPosted: 08:55 - 12 Sep 2011    Post subject: Reply with quote
That would truly destroy the chain. It would rust instantly after that and take all of the grease from inside the links.
devojunior
PostPosted: 12:04 - 12 Sep 2011    Post subject: Reply with quote
what i do if a chain needs a really good clean but is beyond repair is as follows.
1) take chain in hand and looosed links up as much as possible.
2) get that old tray of engine oil you never get round to pouring down the drain because its outside your neibours house.
3)put chain in so its submerged totally and leave for a couple of days.
4)take chain out and it SHOULD be nice and free and smooth.
5)clean all crap off with parafin and very stiff brush
6) clean in hot soapy water then lube thoroughly.
but factor in your time and the cost of parafin lube ect maybe just treat him to a new o ring its nearly crimbo anyway sausage.
good luck and merry christmas.
PostPosted: 12:31 - 12 Sep 2011    Post subject: Reply with quote
Oil doesn't get rid of rust. Any chain recovered by putting in an oilbath couldn't have been too bad in the first place. My suggestion is change it for a new one coz if it snaps it might cost you an engine - or worse.
Serendipity
PostPosted: 13:00 - 12 Sep 2011    Post subject: Reply with quote
Yeah, if it’s bad get a new chain. My CBR600 had been stood when I first bought it and the chain was dry and heavily rusted. I decided to lube it and see how it went. The chain needed almost daily adjustment and reached the wear limit in a few hundred miles.
Even worse with mine was the corrosion on the front brake pads which ended up with the friction material falling off one pad. I was zooming along the A404 when something heavy hit my boot. Couldn’t see anything amiss so carried on to the next junction. Left the main road and nearly shat myself when the brake lever came back to the bar with no resistance. Queue furious pumping on the lever and stamping on the back brake.
Rust in your underpants FTL. Sad
2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
Walloper
PostPosted: 15:46 - 12 Sep 2011    Post subject: Reply with quote
fit a new chain.
devojunior
PostPosted: 08:46 - 13 Sep 2011    Post subject: Reply with quote
see nmber 5 if you were refering to my method.
PostPosted: 09:32 - 13 Sep 2011    Post subject: Reply with quote
Why on earth would you clean a chain in hot soapy water?
I'm slightly concerned how a lot people look after their chains.
PostPosted: 09:40 - 13 Sep 2011    Post subject: Reply with quote
If an O ring chain then unlikely that there is any rust anywhere critical. If there is then the O rings are shot anyway so the chain is scrap.
Check for any stiff links. If there are any it suggests the lube has escaped from that link and so the sealing wrings are knackered (although could also be a bent pin on that link).
If you want to clean it up then I would use a toothbrush and some oil. Wouldn't worry about which oil too much (maybe used engine oil). Just scrub it up a bit.
devojunior
PostPosted: 09:54 - 13 Sep 2011    Post subject: Reply with quote
chris-red whats the differnce in using an off the shelf chain cleaner as apposed to a bottle of fairy and some hot water then re lubing.
the op asked how to clean his chain and theres been some suggestions,nobody said it was the best way to protect or prolong the life of a chain just how to clean up a rusty one.
if it was me and i was going to keep the bike rather than sell it on id buy a new one as fixing an old rusty one is false economy when you factor in the recovery of your bike when it snapps miles from hope.
if i were to be cleaning the bike up to sell on then id do as most have suggested and just clean it and lube it.
PostPosted: 11:33 - 13 Sep 2011    Post subject: Reply with quote
By hot soapy water I assume you mean fairy liquid, which is a degreaser. Paraffin doesn't take off grease anywhere near as much as Fairy liquid/other degreasers do. You don't want to get grease of the chain just the dirt and muck.
Get a chain brush, a rag, a jar of paraffin and some chain lube.
Get the rear wheel off of the ground.
Dunk the chain brush in paraffin, put it on the chain and spin the wheel round.
Repeat a few times
Grab the rag and hold it round the chain and spin the wheel round a few times changing to a clean part of rag every now and then.
Re-Lube
Soaking it in Fairy will only serve to de-grease the o-rings.
Stuster
PostPosted: 14:44 - 13 Sep 2011    Post subject: Reply with quote
I agree with these guys, Buy a new chain. Its not worth the risk of it snapping on you Neutral
Yamaha TZR125 x 3 Lifan LF125 14-F x 3 Jinlun 125 x 1 Honda CBR 600 F1 Honda Varadero 125cc I am now starting my Honda VFR400 NC30 Project Smile (Still ongoing 27/02/18) Daelim Roadwin 125R
Walloper
PostPosted: 11:47 - 15 Sep 2011    Post subject: Reply with quote
Repeat a few times
Re-Lube
Fairy Liquid is not going to harm the chain or the orings.
If it is a sealed chain the oil/grease inside will be fine. (Unless the seals are damaged)
Paraffin will remove oil grease far easier/sooner than any detergent will.
The lubrication qualities of Paraffin are not very valuable to a chain.
So no matter how or what you clean the chain with you will still need to lubricate with a suitable lubricant.
A lot of folk go on about used engine oil.
For my money used engine oil is finished and probably contains harmful compounds too.
For the cost of about a fiver a can of chain lube will help. It will not fling off as 'used engine oil' will (Or any other 'oil' will if you get down to it.)
The chain 'may' be OK but it would have to be cleaned then checked.
Pitch Extention and 'Snake' Excessive Side play all due to worn pins/bushes.
Stiff/Siezed links need to be fixed as if not freed these may break in service.
One could spend an hour or two phannying about cleaning freeing a rusty chain then evaluate.
Silentwalker
PostPosted: 14:00 - 15 Sep 2011    Post subject: Reply with quote
Well rust can be removed with rust remover, so your old chain might look ok on the outside but what about the insides? Well in the old days you could buy a tin of chain grease, heat it up then dip the chain in it to lube it. But modern chains aren’t made for that sort of DIY fixing.
If that chain has worn inside and snaps, you are looking at a nasty potentially lethal accident and a heck of a lot of expensive damage like a chunk ripped out of the engine casing (seen it happen to a ZZR1100).
I’m afraid I have to go with the others, cheapest fix in the short term is a new chain, and you might as well replace the sprockets whilst you’re doing that.
Also two years off road, I think your going to need to check literally everything first for storage wear, re-grease all bearing, strip the brakes, clean and put in new seals. Having just restored my old GPz900 after sitting in a garage you’d be surprised what can end up needing repairs.
adie125
PostPosted: 20:43 - 18 Sep 2011    Post subject: Reply with quote
dunk it in petrol as tho it will make the rust come off easier and after that use a hard brush probs a wire brush will do it put paraffin on it brush it untill it comes off.
The last post was made 14 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 115.23 Kb
