Sealing new end can?
Snorty
PostPosted: 11:43 - 11 Sep 2011    Post subject: Sealing new end can? Reply with quote
I finally got some new end cans for my GPZ, and I've stuck them on so I can at least used the bike now.
However I can feel a small air leak, what should I use to seal this? (The leak is where they slip on).
Nexus Icon
PostPosted: 11:47 - 11 Sep 2011    Post subject: Re: Sealing new end can? Reply with quote
Can you not just do the clamp up a bit more? Any pastes you use to seal it (GunGum, etc.) will make it a right bastid to remove in the future.
Greetings from Shitsville!
kestrel
PostPosted: 12:43 - 11 Sep 2011    Post subject: Re: Sealing new end can? Reply with quote
Go to your local motor factor and ask for a tube of exhaust assembly paste. Smear some on the inside of the larger pipe and make the joint up. Be careful not to get any on the outside of the pipes as it's a bastard to clean off once dry.
Isle of Man.........Road Racing Capital Of The World
MickC
PostPosted: 17:47 - 11 Sep 2011    Post subject: Reply with quote
Or as a bodge try wrapping tin foil around the end of the pipe then re-clamp it.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Dazbo666
PostPosted: 18:21 - 11 Sep 2011    Post subject: Reply with quote
Gun Gum, assemby paste, or exaust wrap??
Word of the day : DILLIGAF
PostPosted: 20:00 - 11 Sep 2011    Post subject: Reply with quote
Clear bathroom silicone is the bees-knees for fitting exhausts.
I shit you not. I've had it sealing the push-fit joint between the header and cylinder head on my Enfield for the last six months. You wouldn't think it could stand the heat but it does, stays flexible and just peels off when you want it to. If it'll survive on the header of an air-cooled bike (gets hot enough to blue the chrome), it'll survive anything.
Nobody was more surprised then me when this suggestion worked.
Dazbo666
PostPosted: 20:32 - 11 Sep 2011    Post subject: Reply with quote
hmmm, might even have to try this as a temp fix on the Bandit
HD
PostPosted: 20:59 - 11 Sep 2011    Post subject: Reply with quote
Yeah silicone is very resistant to temperatures.
Fire putty is what I have in my toolbox, never used it though Laughing
kingsmith
PostPosted: 23:15 - 11 Sep 2011    Post subject: Reply with quote
been using that stuff for years great stuff, easy to get of and seals and thing up ..and cheap lasts ages..
always have a tube in the garage..
honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy
Ariel Badger
PostPosted: 23:24 - 11 Sep 2011    Post subject: Reply with quote
Another vote for bathroom sealant
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Pie-Roe
PostPosted: 00:21 - 12 Sep 2011    Post subject: Reply with quote
I can vouch for one better on silicone sealant, I used it to fix a sheared off bit that wasn't fixed by getting a new engine cover on my bandit. Crashed it and ripped out one of the bolt holes in the case itself, about 2cmX1cm wide, cleaned it all up with petrol, sealed it up and it lasted about 9 months until I sold it when it failed an MOT
Snorty
PostPosted: 00:40 - 12 Sep 2011    Post subject: Reply with quote
The previous cans I had on (before they sheared off at the bracket) were sealed using silicone, I can attest to it being a decent fix also! As I don't have any and didn't want to spend a penny I went for the tin foil and tighter clamps ideas. Also patched up the collector box hole, sounds as smooth as a babys backside (if you could convert touch to sound!)
Cheers fellas! My neighbours must be very happy. My pillions too. Noise ever bothered me as I use in-ear headphones.
Dazbo666
PostPosted: 10:29 - 26 Sep 2011    Post subject: Reply with quote
Well I managed to re-fit the exhaust over the weekend using the silicone sealant, and did 90+ miles with very pleasing results...
(Although I had previously used some spare leftover "bathroom sealant" that was in the garage... but it turned out not to be the silicone type Embarassed It just dried out, cracked and flaked off)
Glad to say the silicone option has remained in place, and gas tight, so will be keeping a tube in the garage as an emergency backup fom now on!! Thumbs Up Karma
The last post was made 14 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 83.87 Kb
