Will a wrongly adjusted clutch grab on start-up?
ClockworkJesu...
PostPosted: 00:48 - 12 Sep 2011    Post subject: Will a wrongly adjusted clutch grab on start-up? Reply with quote
So a while ago I made a post about my bike's clutch. if I fire it up from cold, pull in the clutch and kick it into first, the bike lurches forward as if the clutch was out.
if I put it into gear, engine off, and pull in the clutch, I can't move it until I've shoved the bike around to make the clutch let go.
I was told it could be an oil problem, so I changed the oil. Sadly, it didn't solve the problem.
So I was wondering the other day, could it be badly adjusted? As if it was always slightly on?
Or maybe the plates are just worn and the clutch is gumming up?
Advice?
Souleh
PostPosted: 00:53 - 12 Sep 2011    Post subject: Reply with quote
Usually when cold youll get that kick into first due to the oil.
Its a wet clutch so even when its engaged and you select first, the oil between the plates catches a bit, giving the jolt. Its not a problem ..!
Same reason why a bike rear wheel spins when its on a stand in neutral and rev'd a bit.
As for not being able to move it in gear with clutch engaged, sounds like its not fully engaging, try adjusting the clutch cable to pull it out a bit further
ClockworkJesu...
PostPosted: 00:56 - 12 Sep 2011    Post subject: Reply with quote
Yeah. I'll probably try and adjust it the best I can.
S'just annoying. Its either kick it into 1st from neutral, let it stall, and then fire up again;
or kick it into first when the engine's off, hold the front break and the clutch, and then start the bike, and let the starter motor release the clutch - which is what I've been doing.
bouncerdove
PostPosted: 21:24 - 12 Sep 2011    Post subject: Reply with quote
Hi. I have come across this problem twice and the solution was the same in both cases. The clutch plates have probably become gooed up with either the wrong oil or very old oil. This forms like a treacle on the friction plates causing them to stick together like glue. This frees off a bit when the bike is at normal running temp (just like treacle thins when heated).
One way of curing them is to remove and soak them in petrol for a few hours, then clean thoroughly. Another is to replace them.
Regards bouncerdove
Glenben92
PostPosted: 09:44 - 13 Sep 2011    Post subject: Reply with quote
Deffo just the plates sticking. start the bike, clutch in, rear brake pressed FIRMLY. Rev it up a bit as you kick it into first, this should separate the plates, it's never failed for me. I always do this in the colder mornings.
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
ClockworkJesu...
PostPosted: 10:04 - 13 Sep 2011    Post subject: Reply with quote
Alright, thanks guys! Much appreciated! Very Happy
The last post was made 15 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 46.99 Kb
