Rotary Transmission
shaundtsl
PostPosted: 12:45 - 13 Sep 2011    Post subject: Rotary Transmission Reply with quote
Hi Guys,
I am new to this forum and to biking.
I just picked up a lifan 125 scrambler for pretty cheap. Its in good running condition etc and would like to start using it for commuting and maybe some trail type stuff.
The only thing I dont like is it has a rotary transmission, which means I could easily pop it into 1st from 5th which I dont like.
So, my question is this, can I modify it to only go up and down? Or, if I want to replace it, do I need to replace the whole engine or just the gear box?
I also read that some honda parts might work. If I was trying to source second hand parts, could I use honda?
Thanks in advance!
Martay
PostPosted: 14:25 - 13 Sep 2011    Post subject: Reply with quote
Yes you could, but it would be like trying to ram a car box into 1st from 5th. Its technically possible but fucking difficult!! Even if you try, its really hard to do.
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
shaundtsl
PostPosted: 14:50 - 13 Sep 2011    Post subject: Reply with quote
Thanks, I did manage to do something though, I was riding around 40-ishkm/h and I am not sure which gear I changed to and the bike revved really high slowed down all most throwing me over.
I would like the peace of mind that all the way up until it doesnt go anymore is 1st and all the way down is 5th (or 1st prize would be the normal way).
Can this easily be done?
PostPosted: 15:10 - 13 Sep 2011    Post subject: Reply with quote
I've got a C90 with this sort of transmission and really it only goes into first again when you've come to a complete halt. I'd be surprised if you're pelting along at 50mph and suddenly accidentally kick it into first.
shaundtsl
PostPosted: 15:39 - 13 Sep 2011    Post subject: Reply with quote
Thanks, maybe I need to just "get to know" it first a bit better. I am just cautious I suppose.
Teflon-Mike
tl;dr
PostPosted: 16:49 - 13 Sep 2011    Post subject: Reply with quote
Normally its the othwe way around; down for 1st, up for 2n'd thru fith....
Are you sure you are shifting the right way?
Frost
PostPosted: 17:10 - 13 Sep 2011    Post subject: Reply with quote
Chinky bikes often have a N-1-2-3-4-5 gearbox. Some of the older ones have a C90 clone engine in them with rotary gearbox. I managed to get one of those into 1st from 5th but i could feel everything tighten up and my speed drop as i let the clutch out so i whipped it in and came to a halt sharpish to investigate. everything seemed fine until i set off and realised i was already in 1st Laughing
Dan_Davies
PostPosted: 18:25 - 13 Sep 2011    Post subject: Reply with quote
good luck if its a lifan (Y)
current ride: 07 suzuki sv650s
ex rides : lifan mirage 125
shaundtsl
PostPosted: 19:15 - 13 Sep 2011    Post subject: Reply with quote
I dunno guys. I just tried it out on purpose, got into 5th, pulled the clutch in pushed the gear down into neutral and again into 1st. Slowly released the clutch and the revs shot up and bike slowed down as expected.
I dont feel confortable riding like this...
Is there anything I can do to remedy it or should I just look at selling the bike?
herulach
PostPosted: 19:55 - 13 Sep 2011    Post subject: Reply with quote
I'mnot quite sure what you're asking.
You start in neutral, then go through the gears to 5, then push down once and you end up in neutral, then a second time for first?
Something is really wrong there I reckon.
YBR 125>FZS600
shaundtsl
PostPosted: 20:37 - 13 Sep 2011    Post subject: Reply with quote
From what I understand that its fine that it does that, but I just dont want to be cruising along and accidently go into 1st gear, and as I read, it shouldnt allow 1st gear while the bike is moving, but mine seems to allow it.
I read that rotary transmission are useful for alot of traffic type of driving where its easier and quicker to get back to 1st when you need to.
So my question is, can I do either of the following:
1. Source a second hand gear box which allows the standard gear shift patter and have it fitted?
2. Have the current gear box modified to only go up and down?
3. Rather sell the bike and try get something else?
herulach
PostPosted: 20:50 - 13 Sep 2011    Post subject: Reply with quote
Must be annoying, how do you change down from say 5 to 4?
YBR 125>FZS600
binge
Emo Kiddy
PostPosted: 20:53 - 13 Sep 2011    Post subject: Reply with quote
If it's an all up (or all down) box, then how are you going from 5th to 1st by accident?
You'll have to go into neutral first surely?
As it'd go-
N 1 2 3 4 5 (Then down again would be back to N)
I think you need to learn how to ride your bike properly.
You should just know what gear you are in from the speed and RPM of the engine. It's about paying attention to your bike.
Ben
Frost
PostPosted: 20:59 - 13 Sep 2011    Post subject: Reply with quote
For a start all bikes will go into 1st when they are still moving, otherwise that would be a hell of a pointless gear. An R1 does 100mph+ in 1st so it's a very useful gear.
As said above the Honda C90 uses this type of gearbox and is the best selling bike of all time. There are more of them in use throughout the world than any other type of bike. They all seem to have survived riding them so shall you.
A gearbox cannot simply be swapped over. You can't just unscrew the old one and bolt a new one on. You have to take engine out, the cylinder off, engine covers, fly wheel must be pulled using a special tool, the engine cases split and the gearbox internals changed. I was once quoted £1000 for a gearbox rebuild and you'd need a part that may or may not exist. I could buy 4 or 5 chinky bikes for that.
Frost
PostPosted: 21:03 - 13 Sep 2011    Post subject: Reply with quote
As it'd go-
I hadn't thought about that. The old rotary box bikes used to go:
1-N-2-3-4-5
So then you could go directly from 5th to 1st. Having Neutral inbetween surely improves matters greatly!
shaundtsl
PostPosted: 21:16 - 13 Sep 2011    Post subject: Reply with quote
I can pull the gear up again to gear down to 4th from 5th, so it really works both ways.
Thanks guys, Yip, getting to know my bike is probably the most important part of all. I guess a part of me would just like to have a normal standard type of bike to begin learning on.
This whole thing is pretty daunting with me just starting out.
The last post was made 15 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 92.3 Kb
