| sparkywilliam... |
 sparkywilliam... Scooby Slapper
| doggone |
 doggone World Chat Champion
| P.addy |
 P.addy Formerly known as P.
 Posted: 22:00 - 25 Aug 2011 Post subject: |
Got a PRI option on the fuel tap?
Use that and see if your problem clears.
If so check your vacuum pipe for splits and if its not that check the diaphragm in the fuel tap itself. Fuel tap rebuild kits are cheap on the bay  |
| sparkywilliam... |
| SuzukiTom |
 SuzukiTom Nova Slayer
| sparkywilliam... |
| Moxey |
 Moxey World Chat Champion
 Posted: 19:13 - 26 Aug 2011 Post subject: |
Have you cleared the tank breather? Its actually located in the cap itself looks almost like a tiny jet on the underside of the cap when you take the cap completely out. Simple job and worth a check, mine was blocked but didn't solve the problems I had.
https://www.youtube.com/watch?v=1lG0M60mwxo (visual guide to what people are suggesting it causes)
Been looking at my plugs lately and found mines running lean again, took it out last night round my local bypass to about 60(ish ) and when coming back into town to my house the bike felt flat, poor throttle response and tickover was slightly lower (enough for the lights to be flickering due to low alternator revs).
So turned fuel tap to prime and shook the bike abit, revs climbed up and light stopped flickering, took bike for a spin around the block and it was perfect again, throttle response was instant etc.
So problem must be fuel tap on mine leading to fuel starvation when cruising at high speed/revs but I've already renewed most of the service items in the tap so can't comprehend why it still doesn't work properly on vacuum yet (filters are clean also).
Just saying you should check if its your fuel tap or cap thats in the wrong, I've narrowed mine down to the tap but no idea whats possibly wrong with it.
Running on prime should be fine as long as you check the Float heights are correct and valves are working! The CV carbs were not designed to be fed from a gravity fuel tap so when on prime they have a tendency to flood if theyre not pretty much perfectly set up at the float valve to prevent overflow etc.
(if you don't have a Haynes, Floats should be 17mm + 1mm) ____________________ Current: 02 FZS 1000 & 91 Royal Enfield Bullet 350 Some Bike Pics...
'I was too busy paying attention to pay attention' |
| P.addy |
| sparkywilliam... |
| P.addy |
 Posted: 12:39 - 30 Aug 2011 Post subject: |
Either a vacuum pipe from the fuel tap is torn/worn/missing/disconnected ...
Or
The fuel tap diaphragm could have perished, fuel tap rebuild kit from ebay sorts it  |
| sparkywilliam... |
| P.addy |
| sparkywilliam... |
| Paxovasa |
 Paxovasa World Chat Champion
| P.addy |
| Paxovasa |
| P.addy |
 Posted: 09:57 - 14 Sep 2011 Post subject: |
To be honest...when mine did that.. I just swapped the vacuum tube and the fuel tap was rebuilt... I hate stuff that has more than 1 possibility... just fix them all  |
| sparkywilliam... |
| P.addy |
| sparkywilliam... |
| P.addy |
 Posted: 10:28 - 14 Sep 2011 Post subject: |
Check the larger "tube" for the fuel...possible you have a blocked filter or fuel tube.
Silly thing.. you do have enough fuel in there to test the ON option right?  |
| sparkywilliam... |
| P.addy |
| sparkywilliam... |
| P.addy |
The last post was made 14 years, 160 days ago. Instead of replying here, would creating a new thread be more useful? |
