Honda Bros 400 problem
sgtcalle
PostPosted: 13:15 - 15 Sep 2011    Post subject: Honda Bros 400 problem Reply with quote
Hey guys, tried to start my Bros up this morning for work, started after a bit of effort (often does this on a cold morning anyway) idled for a while then cut out. Wouldnt start again, turns over but doesnt take, thought it might be a fuel problem so i filled her up, tried again after getting home from work. Theres now a wierd "phut phut phut" noise coming from the engine, managed to get her started, but she isnt running at all right. Bearing in mind she ran fine yesterday, can anyone help? Im new to bikes and not great with the mechanics, but it seems to me like a dead cylinder, maybe something to do with the spark plug, as its a v-twin and the noise seems to be coming from one cylinder. Thanks for any help.
PS just had the spark plug from the cylinder i think is dodgy out, looks okay to me. ran the bike for a while, one cylinder stayed cold, although header coming out of it was warm
sickpup
Old Timer
PostPosted: 18:36 - 15 Sep 2011    Post subject: Reply with quote
Front left plug as you sit on the bike. Change it.
P.
PostPosted: 20:41 - 15 Sep 2011    Post subject: Reply with quote
hahadumball wrote:
My bros does this a lot :/
both cylinders get hot dosen't sound healthy, my money situation is tight atm but first chance i get im doing piston + rings so i get to inspect all then.
Why jump in at the deep end, compression check and new plugs.
chrisjpartrid...
PostPosted: 03:12 - 16 Sep 2011    Post subject: Reply with quote
Check the choke cable!
It's a "Y" shape type cable; as in one cable becomes two any they are prone to failing.
This happened on mine before resulting on one carb being stuck on full choke and flooding one the front cylinder.
Naturally the problem became worse as the engine warmed.
Could be something else but hey it's an easy one to check and rule out.
yen_powell
PostPosted: 06:41 - 16 Sep 2011    Post subject: Reply with quote
Same cable on the Africa Twin. I removed mine altogether and blanked off the chokes a few years ago (you have to fit the plungers and springs first), never had any problems since.
XT1200Z and a DR350 in bits
sgtcalle
PostPosted: 10:39 - 16 Sep 2011    Post subject: Reply with quote
Thanks lads, ill get onto it, no harm in changing the plugs, can always use a spare. Any ideas on getting the front left plug out as its a bitch to get at? will i need to have the tank/radiator off?
yen_powell
PostPosted: 13:41 - 16 Sep 2011    Post subject: Reply with quote
Make sure you use the genuine Honda tool and it's not too bad. Wemoto sell it. It's a box spanner with an 8mm hex bar attached on a swivel joint. I use that with an 8mm ratchet spanner and have no problems removing or refitting the deep plugs on Africa Twins, Transalps and Deauvilles.
sgtcalle
PostPosted: 14:53 - 18 Sep 2011    Post subject: Reply with quote
thanks for the tip
The last post was made 14 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 65.75 Kb
