Question re. pulling away in first
Mister James
I want to believe!
PostPosted: 19:20 - 03 Sep 2004    Post subject: Question re. pulling away in first Reply with quote
Ok, having recently spent a day pootling around on a gn125 to get some experience on a geared bike, I noticed that it didnt have much range in the lower gears, ie one had to change up from first almost as soon as you are moving, and again up to third, before you are travelling at a reasonable speed. Having seen guys (and ladiez) riding proper bikes, they seem to get up to a half decent speed in first, without any noticable gear changes.
Thus, when I get my fazer, am I right in thinking that when I'm pulling away from the lights etc, I wont have to change up through the whole gearbox just to get moving?
carvell
Scuttler
PostPosted: 19:29 - 03 Sep 2004    Post subject: Reply with quote
Yes the gears are close together on smaller bikes, same number of gears as a big bike that goes over twice the speed, therefore they have to be close.
I can get up to around 40mph in first, I usually change at 30mph odd I think.
So to answer your question, yes, you will be able to go further in first on a bigger bike.
Yamaha TDM 850
Mister James
I want to believe!
PostPosted: 20:54 - 03 Sep 2004    Post subject: Reply with quote
Excellent - that's exactly what I suspected, but wanted to check. Commuting would be a pain in the arse if the bigger bike was anything like the little honda thing!
dibbster
PostPosted: 22:38 - 03 Sep 2004    Post subject: Reply with quote
Won't have to change as quick for example my RF will do 55 in 1st and about 80 in 2nd. Whenn commuting I can stay in 2nd most of the time where as on the CG I used to spend loads of time changing gear. Sad
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
Rollins
PostPosted: 23:53 - 03 Sep 2004    Post subject: Reply with quote
You could always buy a ZX-10R or an R1 and do 100mph on the first cog...
Frost
PostPosted: 01:23 - 04 Sep 2004    Post subject: Reply with quote
Your not revving the bike hard enough. It will do 40mph in 3rd!
The revs are smooth low down, then when they hit around 6000 it starts to vibrate and sounds like a car engine maxed out in a gear. Keep the throttle open and let the revs rise. you will go though a lumpy patch of a few thousand rpm, followed by a bust of power, then you change up.
My bike is like that, alot of people think i'm gear changing when i have to, where as in reality i just change up before i hit the lumpy bit to save fuel Razz
Craggles
PostPosted: 13:13 - 04 Sep 2004    Post subject: Reply with quote
I have a gn125 - I can get to 30 in 2nd, 40 in 3rd (or 50 on a slight downhill, reving to the red line Wink). 50 in 4th on a flat... 5th is kinda useless really, only use it to keep the revs down a tad, save my legs from vibrating and save fuel like DaFrostyOne.
Hoping to get a bit more out of it once I've had the carb serviced.
By then I'll be looking at a 250 anyway Wink
Craig
If this signature is blue, you're riding too fast
Davo
Davo To The Rescue!
PostPosted: 15:13 - 04 Sep 2004    Post subject: Reply with quote
My friends Hayabusa, does 95mph in 1st (just before it bounces of the rev limiter).
Wave2k
G's Stalker
PostPosted: 15:30 - 04 Sep 2004    Post subject: Reply with quote
ive just come from a rs125 to a cbr4
im so suprised where i would usually change gear it had 6k left
now i can toddle along in 1 gear and not get foot ache
Ducati 1299 Panigale
2009 Corvette C6 z51
ts50x0
PostPosted: 18:08 - 04 Sep 2004    Post subject: Reply with quote
[quote]The revs are smooth low down, then when they hit around 6000 it starts to vibrate and sounds like a car engine maxed out in a gear. Keep the throttle open and let the revs rise. you will go though a lumpy patch of a few thousand rpm, followed by a bust of power, then you change up. [quote]
i think you are talking about a 2 stroke. you get nothing out of reving a 125, 4 stroke, single.
The last post was made 21 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 64.98 Kb
