RMR 125 dies above idle
s91s91
PostPosted: 17:14 - 17 Sep 2011    Post subject: RMR 125 dies above idle Reply with quote
My sons having probs with his RMR125. We have fixed issues with a bad earth but now the bike is a bitch to start and once it finally starts it and when you touch the throttle at idle it dies. If we use the choke its a bit better. We have stripped the carb and all jets seem clean and we are about to renew the spark plug (only done 3K mls) and would appreciate any input? Thumbs Up
andy_uk
PostPosted: 20:26 - 17 Sep 2011    Post subject: Reply with quote
Fuel filter clean?
Stuster
PostPosted: 20:36 - 17 Sep 2011    Post subject: Reply with quote
Hi,
As above and you checked that enough petrol is getting through? As in the fuel lines? You say you checked the jets and all good. What RPM does it get to with the choke on before it dies? Also have you checked for compretion? My DT did the same, was ok on the choke but died Sad turned out it needed a top end rebuild, as this is a 4 stroke though and only done 3k i cant see it needing a top end re-build? You checked that nothing has come loose when fixing the bad earth?
Best of luck mate Thumbs Up
Yamaha TZR125 x 3 Lifan LF125 14-F x 3 Jinlun 125 x 1 Honda CBR 600 F1 Honda Varadero 125cc I am now starting my Honda VFR400 NC30 Project Smile (Still ongoing 27/02/18) Daelim Roadwin 125R
Nope.
PostPosted: 21:01 - 17 Sep 2011    Post subject: Reply with quote
Im currently going through this problem with my 4t Sachs.
Check the following:
Airfilter.
Fuel
Carb Diaphragm
Carb Jets
Carb Floats
Carb Air mixture screw.
CarlosCBR
PostPosted: 21:55 - 17 Sep 2011    Post subject: Reply with quote
My vote is for carb diaphragm.
Nope.
PostPosted: 22:03 - 17 Sep 2011    Post subject: Reply with quote
My first thought Smile
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
s91s91
PostPosted: 11:39 - 18 Sep 2011    Post subject: Reply with quote
Thanks - all. Its a piston slide carb so no carb diaphram. I'm going to change the sparkplug - in case its knackered. Fuel flow seems fine and we have cleaned out the filter.
s91s91
PostPosted: 18:36 - 18 Sep 2011    Post subject: Reply with quote
changed plug (NGK Iridium) and checked spark at plug. We got a spark but it wasn't as big as expected. Plenty of fuel getting through but bike wont start. Have had to take battery out to recharge it.
Nope.
PostPosted: 18:39 - 18 Sep 2011    Post subject: Reply with quote
IIRC, Iridiums are generally pretty crap in two strokes. Get a proper, regular NGK in there.
s91s91
PostPosted: 18:48 - 18 Sep 2011    Post subject: Reply with quote
Its not a 2 stroke, its a 4 stroke.
Had problems with a short circuit in my handlebar controls ( have been replaced) is it possible that this short could have had an impact on my battery despite giving okish results with VOM or usually from lights.
Engine does crank but doesnt turn over now. Carb has been cleaned several times now and I'm not getting anywhere
Any ideas?
Dan_Davies
PostPosted: 19:47 - 18 Sep 2011    Post subject: Reply with quote
i had a similar problem on the lifan 125 Sad took it back to the garage i had it off as i'd only done 2000 mls on it and it had a years warranty. they couldnt find anything up with it "/
current ride: 07 suzuki sv650s
ex rides : lifan mirage 125
s91s91
PostPosted: 21:07 - 18 Sep 2011    Post subject: Reply with quote
I assume its gravity fed.
The last post was made 14 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 15 - Page Size: 88.77 Kb
