cg 125 clutch(i think)
BigGeeking
PostPosted: 01:09 - 17 Sep 2011    Post subject: cg 125 clutch(i think) Reply with quote
Hi all
on my Honda cg 125 when slowing down with gears say I’m in 3rd them go down to 2nd when I slowly let out my clutch I get like a fast juddering noise (cant explain the noise) but if I blip the throttle before letting the clutch out it dose not happen it seams to do it more when cold
the chain tension is good and it has new sprockets on and lube well its like its coming from the clutch??????
thanks john
Karma
Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,,
Fizzer Thou
PostPosted: 14:56 - 17 Sep 2011    Post subject: Reply with quote
When you blip the throttle just before changing down a gear there is less chance of the back wheel locking up momentarily.
Always have a 'Plan B'
Teflon-Mike
tl;dr
PostPosted: 15:26 - 17 Sep 2011    Post subject: Reply with quote
Yup; could be over braking your rear wheel, not making a smooth enough change; could be suspension units, lack of damping would let the spring slap the wheel down hard as you take weight off it; then 'bounce' as the wheel 'skids'; sproket dampers, or cush drive could also be loading unloading causing judder, when you shift gear, and if the sprokets have just been changed that particular one would be number one on my list of things to check. Has sproket bolts been done up properly? Were tab washers used correctly? Have they come loose? Was sprocket aligned properly; sometimes on small hondas they have a circlup around centre boss; and the bolts are only holding 'pegs' loosely into sproket damper rubbers.... if they are worn, play = judder.
Or combination (likely) of all three. Cg is not renouned for being well damped, and shocks are often hard worked and sorely neglected, as are sproket damper bushes and pegs, and if somje-one has forgotten the sproket circlip at some time..... it will slap and judder like buggery, and make itself worse and worse.... especially with learners working it hard, making more changes than they really need, as clumsily as they will.....
BigGeeking
PostPosted: 19:26 - 17 Sep 2011    Post subject: Reply with quote
thanks for the replys all
i sounds like the chain is slipping over the sprocket type of noise.
and it has done it when at a stand still when the clutch is not pulled in far so in sted of sliping it was making this noise if that helps Crying or Very sad
Teflon-Mike
tl;dr
PostPosted: 20:12 - 17 Sep 2011    Post subject: Reply with quote
If its rattling at stand still, could be the friction plates are on the way out, but if that for worn, usually pressure on the plates would see the cluytch slipping under load..
HOW2: Overhaul Clutch (Small Honda's +)
More likely, that it would be sloppy selector mech & its the DOG clutched between the gears rattling in a 'partial engagement'...
THAT is a complete tear-down split the crank cases job, inspecting the selector drum; selector forks and the actual gears themselves.
THOUGH if you take the primary drive off to inspect / overhaul clutch basket. may find something 'obviouse' like bent selector ratchet not shifting the selector drum full travel, giving similar effect, of partial gear engagement.
The last post was made 14 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 48.37 Kb
