honda bros 400 jet maybe?
at106
PostPosted: 09:13 - 18 Sep 2011    Post subject: Reply with quote
If you change the jets in 1 carb you must do exactly the same in the other.
The main jet effects running from around half to full throttle. Low speed jet effects running from idle to around half throttle.
If you fit bigger jets the engine will run richer but performance probably wont change, unless you fit a performance exhaust or performance air filter. Without doing this the engine will probably bog down when you open the throttle and you'll probably go slower.
0ddball
PostPosted: 09:18 - 18 Sep 2011    Post subject: Reply with quote
If it's running fine don't start messing with it.
ZXR750L
Slacker24seve...
PostPosted: 13:58 - 18 Sep 2011    Post subject: Reply with quote
Ok mate, so basicly if i do jets i have to do air filter and exhaust :/
Not necessarily. Get it set up on a dyno properly or you will almost certainly make it worse. Quite why you'd like to put performance exhaust on a Bros is beyond me.
Banger rallies are ace
The last post was made 14 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 51.68 Kb
