| paddlesat16 |
 paddlesat16 Crazy Courier
| yen_powell |
| MickC |
 MickC Spanner Monkey
 Posted: 18:43 - 18 Sep 2011 Post subject: |
It's the reason behind the fins, heat dissipation. If insulation on wres is starting to melt, you have a problem. Otherwise it's doing what it is meant to do. ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
 Posted: 21:49 - 18 Sep 2011 Post subject: |
As above. That's why they have cooling vanes.
If you are concerned, making sure it's in somewhere it gets some air flowing over it and bolting it to a big metal bit of the bike for heat sinking are both good ideas.
It would be a mistake to assume the manufacturer put it in the best place, you just need to look at a VFR750 to dispel that one (attached to a flimsy bracket, under a plastic fairing and with no cooling fins, then they act all surprised when they fail).
I've even known people fit computer CPU fans to them BUT yes, they get pretty damned hot as standard and this is normal. They get less hot the more power you are using for the bike which is the main reason I have my headlights on most of the time on the VFR. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| paddlesat16 |
| Fizzer Thou |
| whitedevil |
 whitedevil World Chat Champion
| paddlesat16 |
 Posted: 10:26 - 19 Sep 2011 Post subject: |
Many thanks for your replys guys, I think i'm gonna run some tubing of some description to aid cooling and maybe change the reg/rec at some date to a more modern mosfet type which don't generate the heat so much. See thread
https://www.apriliaforum.com/forums/showthread.php?t=207174
Regards ____________________ I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T. |
The last post was made 14 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
