aerox problem IGNITION
fitbikeco
PostPosted: 15:15 - 19 Sep 2011    Post subject: aerox problem IGNITION Reply with quote
help please
having problems getting the ignition barrel of to replace it because i snapped half the key in it anyway got the new ignition but i cant get the old one of some sort of security key bolt but cant find nothing saying anything about it, its the 2 bolts holding ignition on???
thanks
andy_uk
PostPosted: 16:05 - 19 Sep 2011    Post subject: Reply with quote
I'm not familiar with the aerox, can you post a picture of the bolts?
edited to add :
I just googled the lock and it looks like they use shear-off bolts (see the 2 bolts in the attached pic).
Did you get bolts with the new lock?
If not, I'd advise getting some...
To remove them you'll need to use either a hammer & screwdriver or cut a slot in each head with a dremel (other power tools are available Wink ) and unscrew them.
https://images.wemoto.com/full/IGNITION_SWITCH_AND_LOCK/10032477.jpg
fitbikeco
PostPosted: 00:59 - 20 Sep 2011    Post subject: Reply with quote
thanks will have to keep going at it when got time
fitbikeco
PostPosted: 03:13 - 20 Sep 2011    Post subject: Reply with quote
got it off just used a drill and a small drill bit and drilled out shaped like a flat head and unscrewed it Smile)
The last post was made 14 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 38.76 Kb
