no way to change oil in my car... via filter?
Mondeo Man
PostPosted: 18:38 - 20 Sep 2011    Post subject: no way to change oil in my car... via filter? Reply with quote
I bought a vacuum. Unfortunately, it's useless, as it doesn't reach into the sump (there's a baffle I understand).
I can't loosen the sump plug- even after soaking it in wd40. I have broken a socket this afternoon trying. It just won't budge. I am astonished that some numpty has tightened it to this extent (the friendly machanic, I assume, which the previous owner took te car too - clearly a clown).
I am thinking I might have to go for it via the filter. How practical is this?
I might take it to Kwix Fit.
Oh life, why do you taunt me so
https://www.emotty.com/images/emoticons/1132.png
herulach
PostPosted: 18:47 - 20 Sep 2011    Post subject: Reply with quote
try some actual penetrating fluid - plusgas or similar, wd40 will do nothing.
YBR 125>FZS600
fatpies
PostPosted: 18:49 - 20 Sep 2011    Post subject: Reply with quote
Try using a socket which fits 100% as if you've broken it or rounded it off then it probably didn't fit, lest you bought a tool made from cheese.
Then use an extension bar (a hollow steel tube will do) to try and undo it....
Else just bring it to a mechanic.... the kwik fit deals are often cheaper than buying your own oil and filter and doing it yourself. Some sort of loss leader I suppose so they can get you in and make up problems with the car and charge you for them.
But I know mercedes use a vaccuum sort of thing to suck out the oil from the engine as it gives them a faster turn around time than letting it drip out.
mad4it028
PostPosted: 18:52 - 20 Sep 2011    Post subject: Reply with quote
old fuel pump put pipe down dipstick into sump?
tatfan
PostPosted: 18:53 - 20 Sep 2011    Post subject: Reply with quote
I assume you were turning it the right way. Have you checked to make sure it's not reverse threaded?
Mondeo Man
PostPosted: 18:56 - 20 Sep 2011    Post subject: Reply with quote
It's not budging either way. I am anti clockwise. I have tried socket and big old wrench. No movement at all (just rounding off).
I have a silverline oil extractor but the tube goes so far down the dipstick tunnel, and stops. There is something blocking it.
mad4it028
PostPosted: 18:59 - 20 Sep 2011    Post subject: Reply with quote
ide put an impact gun on it the worse thats gonna happen is you need a new sump
JonB
Afraid of Mileage
PostPosted: 19:04 - 20 Sep 2011    Post subject: Reply with quote
What car you got, you haven't mentioned it?
mr jamez
PostPosted: 19:14 - 20 Sep 2011    Post subject: Reply with quote
Take it to a garage, oil changes are cheap. Not worth scrabbling around on the drive to save a few quid imo.
Mondeo Man
PostPosted: 19:16 - 20 Sep 2011    Post subject: Reply with quote
Yes, but will Kwix fit be able to get the bolt off!
Quote Me Happy
PostPosted: 19:17 - 20 Sep 2011    Post subject: Reply with quote
I've booked my car into National Tyres for Sunday afternoon for the grand sum of £32. For the time plus the cost of oil and filter it's not worth doing myself.
mad4it028
PostPosted: 19:18 - 20 Sep 2011    Post subject: Reply with quote
oil and filter at shit fit cost me £35 today in my transit van
The last post was made 14 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 70.87 Kb
