Riding a Ural 1500km through Siberia in Feb. Any advice?
Are we mad?
Yes
81%
 81%  [ 18 ]
No
18%
 18%  [ 4 ]
Total Votes : 22
icebound
PostPosted: 23:21 - 20 Sep 2011    Post subject: Riding a Ural 1500km through Siberia in Feb. Any advice? Reply with quote
Hi all.My missus-to-be and I are joining an unsupported adventure race (The Ice Run) which follows a frozen river in Siberia next Feb. We know little about biking in the cold and less about Soviet motorbike and sidecars. Any advice on how to get a good understanding of the Ural (modeled on a BMW R71 apparently) and how not to freeze to death would be much appreciated. We're getting married a month after the race and would hate to disappoint our guests. Thanks v much!
Biker
PostPosted: 17:03 - 21 Sep 2011    Post subject: Reply with quote
Sounds like it will be an amazing adventure. Can't help on the bike front but makes sure you pack your thermals!
Helly Hansen make some good stuff (a sailing brand). In camping shops you can also get self heating handwarmers.
Take one of those silver sheets you see people wrapped up in after the marathon. They are light to pack and could help save your life.
Also make sure you have some way of contacting people in an emergency. Check in with people if poss so they can look for you if you miss a check-in.
Stay safe Smile
von1papen
PostPosted: 18:10 - 21 Sep 2011    Post subject: Reply with quote
I've used said bike as a friend owns one, prepare for very clunky gearing and truth be told poor handling lol
You literally fight the thing round corners, this is probably due to having a sidecar admittedly so theres no lean!
Also the person in the sidecar may have to lean out when cornering as it can sort of tip up into the air lmao However it is a ww2 design and the originals had a pretty good reputation, the Urals don't though..... lol
I think the main thing is just knowing the bike and being handy with spanners! It is not a jump on and ride off with no maintenance worries kind of machine.
Charlie
PostPosted: 19:05 - 21 Sep 2011    Post subject: Reply with quote
What are the temperatures in February in Siberia?
Merino wool is better than the smelly helly hansen stuff, which gets pretty smelly pretty quickly. But it is more expensive.
Sounds like an epic adventure. Keep us updated!
icebound
PostPosted: 19:25 - 21 Sep 2011    Post subject: Temperature check....Siberia Reply with quote
Thanks for all your kind advice! I gather that the usual temperature for that time of year in -40. Found this website about a chap called Hubert who's riding around the world for 7 years on a Ural. You must have a look at what he wore in Siberia. https://www.thetimelessride.com/US/Eurasia/Lake-Baikal/Lake-Baikal.141.htm
Thanks again! Mr. Green
herulach
PostPosted: 19:42 - 21 Sep 2011    Post subject: Reply with quote
Kudos for trying it, but to be honest, its seems slightly...ill advised.
A (presumably) fairly considerable distance on a bike you don't know in conditions where even a fairly minor mechanical failure could literally kill you in a fairly short period of time - bear in mind you'll be basically unable to do any kind of mechanical work in those temperatures.
That said, if you're going to do it, heated everything for both of you, a significantly uprated alternator to run it all. Also bear in mind the freezing point of brake fluid is somewhere around -40. Is the bike yours or are you renting it? Bear in mind you're going to need different oil at those kinds of temps as well.
Your first priority really should be good survival gear, including a tent (even if you're not camping)
YBR 125>FZS600
D O G
PostPosted: 14:51 - 23 Sep 2011    Post subject: Reply with quote
I presume you must be well experienced in cold weather survival in general tho? You must have done endurance events of some nature.....no?
Looking at the website, if you don't, then you're screwed, and I'd be interested to know what vetting the organisers do prior to accepting you on the event.
PostPosted: 15:44 - 23 Sep 2011    Post subject: Reply with quote
You're Mental and probably going to die. Good luck! Laughing
colin1
Captain Safety
PostPosted: 16:24 - 25 Sep 2011    Post subject: Reply with quote
Make a will.
Teflon-Mike
tl;dr
PostPosted: 23:36 - 25 Sep 2011    Post subject: Reply with quote
He's riding a Ural; freezing to death in Siberia wouldn't be my first concern.... Making it as far as the FERRY would be an accomplishment!
I once went as far as Devizes (from Brum) to get a Dnipnier....
Was quite impressed..... it made it HALF way back!
funmonkee
PostPosted: 23:41 - 25 Sep 2011    Post subject: Reply with quote
^ are they really that unreliable ?
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
deleted111
PostPosted: 10:05 - 26 Sep 2011    Post subject: Re: Temperature check....Siberia Reply with quote
I enjoyed reading that and looking through his pictures, thanks Thumbs Up Karma
You're still a nutter, though. Laughing
Gerrard
PostPosted: 09:52 - 28 Sep 2011    Post subject: Reply with quote
If you getting married when you get back mind the old tadger dont fall of in the cold... Shocked
A great adventure wish I was going.. Thumbs Up
Honda Blackbird the great all rounder.
Chillin near Malaga.
Marco Simoncelli 58
Okeydokey
PostPosted: 23:33 - 29 Sep 2011    Post subject: Reply with quote
Sounds to me like you need to get your hunting, trapping, and fishing skills honed up. If your partner is slim try to get her to eat as much as possible so when she goes down at least you have some fresh meat! Don't try to use fur from trapped animals, it typically atracts predators, gives you blisters (when worn in your boots) or makes people think you are slightly off program when you reach civilisation.
Oh! and start swimming in the sea, don't know why but it's good for getting you used to silly temperatures.
Edit: forget to mention yellow snow... nvm!
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it in a fruitsalad!
YB100 v. Ford Sierra (1982 I came 2nd place) Honda H100S (Currently 0 - 0) CX500 Cafe project (me 1 - wife 0.... maybe!)
Charlie
PostPosted: 11:23 - 30 Sep 2011    Post subject: Re: Temperature check....Siberia Reply with quote
Only just got round to check it out. Just wow!
That lake was so cool. Will look at his other stories later on. Thanks for sharing Thumbs Up
kenjh
PostPosted: 15:55 - 06 Oct 2011    Post subject: Reply with quote
must be a kid ..still figger your immortal...never lose that ,your gonna have a great time ,and better stories to tell !! pictures !! we wanna learn from your misstrak's...um.. mistakes....no I don't wanna go with you ...an if your future wife still likes you after this ...awsome ..your both nut's!!good luck ..hell luck has nothing to do with it ..go for it !!!!
If I don't know I ask..an' there is a lot I don't know. I am and old biker , not a bold rider there are no old bold riders ...
gorillaonabik...
PostPosted: 01:51 - 11 Oct 2011    Post subject: Re: Riding a Ural 1500km through Siberia in Feb. Any advice? Reply with quote
You need to get some cold weather survival training. Dear God, if you are asking an internet forum about the gear you need to wear in the middle of a Siberian winter at -40, you will die.
Wearing the wrong gear at minus 40 will kill you let alone trying to do some spannering at that kind of temperature. And don't think for a second that because that dude says he is warm that you will be warm. I have experienced hypothermia and the pain is incredible, especially as the mind goes walkabout at the same time. I've broken bones but the pain did not compare with being seriously cold.
So get the survival training in as death by cold is incredibly, unbelievably painful. I've been there and the only thing it compares with is marriage...
John933
PostPosted: 02:43 - 22 Nov 2011    Post subject: One of you are going to die... Reply with quote
It's as simple as that. Or you are both going to come back less finger's and toe's. Snow in your back garden a couple of week in December/ January, wrapped up in your mother's knitted sweater. With the back door to a warm house ten feet away, is no way of understanding cold.
People who go out in them kind to temperature's have back up. In the way of a group, in the way of people know where they are. There is a plan to get them out if it go'es tit's up. You have none of these. You can be ten feet from a road in a snow hole with traffic passing. No one know's you are there. You will die.
There is no, " On the other hand ". Crazy or not. If you go you will not come back. I've done an Artice survival course, that was called off four day's in to a seven day outing. And that was with support and trained people. If we had stay any longer. One of the group would have lost some part of there body. And to get warm from that took over a day. To get warm when we got back. Took more than a few hour's in hot bath's changing the water over as our body's was cooling the water down as we absorbed the heat from the water. You don't know pain from cold when it get's that bad.
If you go you will die.
John933
My trip
kenjh
PostPosted: 06:27 - 22 Nov 2011    Post subject: Reply with quote
so how is it going ?? still married ? going to go riding in a warm place ??
The last post was made 14 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 4.84 - MySQL Queries: 15 - Page Size: 107.77 Kb
