gear shift problems
markrolls88
PostPosted: 06:57 - 21 Sep 2011    Post subject: gear shift problems Reply with quote
i have one of them rubbish chineese import engines and all the gears go downwards to shift up the gears and to shift back to neutral you move the lever up well when im riding say im in forth and i go to shift down its going straight to neutral in all gears but if im moving sometimes i can get it to go down and i have to rev the crap out of it i have done two oil changes on it in the past week because of this problem so im ruling that out
sparky
Damon
PostPosted: 07:09 - 21 Sep 2011    Post subject: Reply with quote
Check your gear linkage for excessive play.
markrolls88
PostPosted: 13:38 - 22 Sep 2011    Post subject: Reply with quote
do you think i could get my gear box off my cg engine and put it on the chinese copy of the cg engine
sparky
PostPosted: 15:01 - 22 Sep 2011    Post subject: Re: gear shift problems Reply with quote
Which one? What's the number on it? 156FMI? 157FMI? Something else?
No idea what that means. Typical shift pattern is 1 Arrow N Arrow 2 Arrow 3 Arrow 4 Arrow 5. Some domestic Chinese bikes go N Arrow 1 Arrow 2 Arrow 3 Arrow 4 Arrow 5 Arrow N Arrow ... repeat.
What's the shift pattern on yours?
Is the shift lever secure on the selector shaft?
Have you bent the shift lever, or is it rubbing against the casing?
Have you dropped or otherwise damaged the shift lever or the shaft?
If you have a 156 or 157FMI engine, then a CG125 lump is likely to be a straight swap, although you may have issues with the electrics depending on the age of the CG unit.
The more information you give us, the better we can advise.
markrolls88
PostPosted: 15:34 - 22 Sep 2011    Post subject: Reply with quote
the shifting is neutral 1 2 3 4 5 but say im in 5th ill shift to go to 4th and it goes to neutral then shift back to 5th but sometimes if i shift back to forth again it goes in with some reving off the engine but i cant seem to find first unless i rev it from neutral and it clicks in to first on its on the lever is secure on the shaft it hasnt been dropped and the shaft has no play in it
sparky
Ariel Badger
PostPosted: 21:36 - 23 Sep 2011    Post subject: Reply with quote
It could be down to clutch adjustment but I fear it is just because it is Chinese.
The last post was made 14 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 54.77 Kb
