What can I use to clean a chain?
Recluso
PostPosted: 18:35 - 21 Sep 2011    Post subject: What can I use to clean a chain? Reply with quote
Howdy guys and gals!
I'm giving the YBR a bit of tlc this weekend (weather permitting) and on the list of my things to do is give the chain a really good cleaning (I'll admit that I've neglected it a bit so far in my ignorance).
I've collected a veritable assortment of cleaning goodies and toys, but I don't have anything with which to clean the chain (barring some cheapy toothbrushes I picked up). I've had a bit of a look around but seem to only find expensive contraptions like the Muc Off chain doctor thingy.
Can anyone suggest a brand or concoction that will let me get my chain sparkling clean again?
Thanks in advance as always!
'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900
Slacker24seve...
PostPosted: 18:43 - 21 Sep 2011    Post subject: Reply with quote
Paraffin and a toothbrush.
Banger rallies are ace
chrisjpartrid...
PostPosted: 18:44 - 21 Sep 2011    Post subject: Reply with quote
WD40 and a toothbrush
lihp
PostPosted: 19:00 - 21 Sep 2011    Post subject: Reply with quote
Chain cleaner?
neatbik
PostPosted: 19:12 - 21 Sep 2011    Post subject: Reply with quote
This.
Go to your local DIY place, its about £5 or so for 5 litres. Will last forever and cleans chains a treat.
Recluso
PostPosted: 19:15 - 21 Sep 2011    Post subject: Reply with quote
PhilDawson8270 wrote:
Chain cleaner?
Not helpful Razz
Microcut
PostPosted: 19:30 - 21 Sep 2011    Post subject: Reply with quote
Maybe i'm just lazy or simply buy into marketing, but i'd go and buy a cheap spray chain cleaner. I use Silkolene (600ml) and the fact you've got the force of the spray and a little nozzle for precise (questionable) application, you can get the job done pretty easily.
As for lube i like the Silkolene titanium gel lube. The gel is white so is easy to see where you're applying it and has some fancy anti fling formula. Both products are good to use on chains with O-rings btw.
I'd advise against WD40 as a cleaner. Paraffin is good but ask yourself, how often do you clean a chain and how much elbow grease do you want to avoid?
Or maybe i sound like i've got shares in the Fuchs company.
WannaBeDude
PostPosted: 19:38 - 21 Sep 2011    Post subject: Reply with quote
Use the search button, and while your there type in nodding Idea Smile
PostPosted: 19:42 - 21 Sep 2011    Post subject: Reply with quote
I would just use a toothbrush and some random oil (ie, any small amount left in a bottle, or just used oil)
Silentwalker
PostPosted: 19:46 - 21 Sep 2011    Post subject: Re: What can I use to clean a chain? Reply with quote
Recluso wrote:
I'll admit that I've neglected it a bit so far in my ignorance.
Something with a busy life we all forget to do. Buy and fit a Scottoiler, it might help with those senior moments?
WannaBeDude
PostPosted: 19:56 - 21 Sep 2011    Post subject: Reply with quote
I tell you what, must be a nightmare keeping lots of bikes like G and Kick, and also running one like Marmalade.
As for my ' bitch ' Italian 2Ts so much win and fail amalganated ! Very Happy
PostPosted: 20:53 - 21 Sep 2011    Post subject: Reply with quote
Chain cleaner?
Not helpful Razz
Only if you want to be fleeced.
Diesel and a toothbrust for me.
Johnser
PostPosted: 20:59 - 21 Sep 2011    Post subject: Reply with quote
anything that will dissolve oil but not steel or - more importantly, the o-rings in the chain (if its an o-ring chain).
poundland toothbrushes are 5 for ... well, a pound.
paraffin, petrol, diesel, white spirit... e.t.c will all help cut through the crud.
dry chain with rag before applying new lube
Recluso
PostPosted: 21:51 - 21 Sep 2011    Post subject: Re: What can I use to clean a chain? Reply with quote
If I was looking to keep the YBR then I'd definitely be looking into it. But as I'm hopefully looking to sell it in the next couple of months I'll be oiling and lubing it by hand for now Wink
That said, a Scott Oiler is top of the list of things to add when I change bikes. They seem like one of the most amazing gadgets ever Razz
And I'm not THAT senior... only 26 Razz
ClockworkJesu...
PostPosted: 03:46 - 22 Sep 2011    Post subject: Reply with quote
Some kind of spirit and a toothbrush.
Bike on centre-stand, kick it into 5th, let the wheel turn under tick over, press the toothbrush to the chain, and wait. Cool
Or.. Bad idea, since you're taking the oil off the chain?
We'll find out. Mr. Green
WannaBeDude
PostPosted: 11:01 - 22 Sep 2011    Post subject: Reply with quote
https://i37.photobucket.com/albums/e53/covdude/2011/hand.jpg
whitedevil
PostPosted: 11:08 - 22 Sep 2011    Post subject: Reply with quote
Man Jam Thumbs Up
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
tk338
PostPosted: 12:28 - 22 Sep 2011    Post subject: Reply with quote
Yeah, if you're taking oil off, don't let the bike turn the rear wheel, turn it manually. If you're just lubing it up and not having any contact with the chain itself by all means. But there was a guy lost fingers cleaning his chain with his bike in gear!
Ybr125(10)>CBR600fY(00)>Bandit650N(58)
Formerly known as
P.
PostPosted: 12:31 - 22 Sep 2011    Post subject: Reply with quote
Yum..
Graphic images.. Beware
https://www.gixxer.com/forums/showthread.php?t=242261
Recluso
PostPosted: 12:25 - 23 Sep 2011    Post subject: Reply with quote
Yeah, I'd rather not lose any fingers (curse you and your links, Paddy! Razz). As tempting as it might be to try and speed things up with the engine running, I'd rather not risk it. I've got the wrong sort of luck.
So! With the help of some paraffin, a toothbrush, 2 hours of elbow grease and an assortment of rags, I present my much cleaner looking chain!
https://img.photobucket.com/albums/v357/Inkersall/Bike%20Stuff/IMG_0314.jpg
https://img.photobucket.com/albums/v357/Inkersall/Bike%20Stuff/IMG_0313.jpg
Admittedly I probably could have gotten it even cleaner but the paraffin fumes were starting to get to me a little bit. But it's a huge improvement. When I took the chain guard off and actually got up close and personal, I was shocked at just how dirty it was! There was so much gunge and grime (and hair... don't ask. I don't want to know myself) in there that the toothbrush was fully 'gunged' within about 20 mins and I found it far more effective to get in there with a few rags and clean it.
Lesson learned though. I'm going to be far more careful about cleaning my chain from now on.
Once my head's stopped spinning I'll clean the rest of the bike. Just look at the state of those wheels! Very Happy
Thanks for all the input though folks, had I not thought to ask, I would have just gone out and spent £7-£8 quid on a branded cleaner rather than a couple of quid on a bottle of paraffin that did the job better than I ever could have imagined!
Dan_Davies
PostPosted: 17:01 - 23 Sep 2011    Post subject: Reply with quote
i used motul chain clean, oil just dripped off instantly, and harder bits just gave a rub with a cloth, had it free in m&ps because i was buying some other gear Thumbs Up
current ride: 07 suzuki sv650s
ex rides : lifan mirage 125
The last post was made 14 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 113.63 Kb
