Slide carb or diaphram carb?
pepperami
PostPosted: 19:06 - 22 Sep 2011    Post subject: Slide carb or diaphram carb? Reply with quote
So your putting together a little project bike and you have two carbs that match the inlet mounting rubbers.
As said in the title, one is a diaphram and the other is a good old slide type carb.
Both come from an engine of similar capacity as the one you`ve got in your project bike.
What one would be the choice to fit and why?
Is one more responsive?
C`mon mighty BCF, enlighten me Smile Thumbs Up
PostPosted: 19:13 - 22 Sep 2011    Post subject: Reply with quote
Personally I'd go for the simplicity of a slide carb, easier to debug if there's a problem.
temeluchus
PostPosted: 19:15 - 22 Sep 2011    Post subject: Reply with quote
slide carbs are simpler for the home tuner to set up so I would go for that one.
Fizzer Thou
PostPosted: 19:29 - 22 Sep 2011    Post subject: Reply with quote
It depends on what the engine is.If you have a slide type carb,the opportunity to yank the throttle open too quickly and the engine bogs is quite high.If the slide carb has an accelerator pump on it this will help,but it does take some setting up to get the length of squirt correct.Whereas with a CV type carb,the slide will only open as quickly as the engine builds revs.If everything works okay on a CV carb then there should be no problem with performance.
Always have a 'Plan B'
temeluchus
PostPosted: 20:35 - 22 Sep 2011    Post subject: Reply with quote
matching the cv carbs spring and slide travel rate isn't the easiest thing to do for a homebrewer, hence the recoendation of a slide carb.
as I recall from mucking with cv's you have to change springs and/or redrill the holes in the slide to get them to work properly on another machine or large changes in the inlet/airbox configuration.
whilst properly set up cv's are generally better a simpler slide type has fewer variables to judge so make an easier diy proposition.
pepperami
PostPosted: 20:57 - 22 Sep 2011    Post subject: Reply with quote
I`ve got diaphram carbs on my XS400 and on my Sachs 125 and they both are a pain in the bum when they need working on.
That got me thinking about some of my previous bikes that had slide carbs= Suzuki GT 250`s, RD`s, Pursangs, & CB125 twins, none of which gave me much hassle carb wise.
They all "felt" responsive? and quicker to "pick up" when I compare them against my XS400 & Sachs125 ?
Or am I looking at past bikes with rose tinted glasses?
Is there any substance to what I`m saying?
temeluchus
PostPosted: 21:02 - 22 Sep 2011    Post subject: Reply with quote
cv carbs can be great but again stick to slideys for home brewing. as you have experienced they are easier to work on.
hmmmnz
PostPosted: 22:53 - 22 Sep 2011    Post subject: Reply with quote
i have both diaphragm and slide carbs for my 500cc single, ive had far better luck with the diaphragm carb, the slide carb definitely isn't as forgiving
the humans are dead
I kick arse for the lord
Ariel Badger
PostPosted: 22:58 - 22 Sep 2011    Post subject: Reply with quote
For speed on the track a slide, for reliability and steadiness on the road a CV.
Ingah
PostPosted: 01:35 - 23 Sep 2011    Post subject: Reply with quote
Yes, from my vague recollection of the difference explained in Haynes Motorcycle Basics Techbook (i think... Laughing ) - CV is basically more efficient (i.e. better fuel consumption) and slide is more "responsive" (i.e. more likely to be seen on a sports bike).
-- Ingah
Teflon-Mike
tl;dr
PostPosted: 03:20 - 23 Sep 2011    Post subject: Reply with quote
First question; TWO STROKE OR FOUR STROKE!
I know not of a successful application of CV carb on a two stroke. This suggests, CV carbs dont work too great on them.
If four stroke.
Single, twin or Multi?
If multi, are you using multiple carbs or manifolding?
What is the displacement of the engine?
Big engines with big slide carbs can suffer slide sticktion; botterly on a CV makes them a lot lighter aginast the large vacuum of a big pot at part throttle.
Whats the NATURE of the engine? screamer, or slogger?
Is it tuned for power or ecconomy?
Whats the desired USE? Racing, carburation can be set up digitallyl throttle's slam shut or wide open. Trials we like rather a lot more finesse in the part throttle and throttle response. On the road, tend to want some measure of both, plus ecconomy.
NOT exactly giving us much to go on here!
And you have myriad deifferent designs and arrangements of CV carburettor...... Brian Kryten, got great results ditching the Mikuni Flatslides on the Norton Rotary Racers in favour of 'old fasioned' SU carbs of a frigging Morris Monor! Press called hium a luiddite for that one AND making Spondon weld up a twin shock frame..... but he started placing bikes in races!
So WHAT is the 'Little Project Bike'? And whats the actual carbs....
pepperami
PostPosted: 09:30 - 23 Sep 2011    Post subject: Reply with quote
WHOA! Mr Tef! Shocked
Ok I am in the process of seeking out a new project possibly? I hope? maybe? if I`m allowed? Smile (she who must be obeyed)
And I have decided that it will be one of the following 1. a two-smoke twin, 2. a two-smoke single, or 3. a four-stroke single.
It will be above 125cc and below 400cc.
why I am asking these questions is that I want to get the best out of my project, but I do not want to go down the road of "tuning" the living daylights out of it.
I am not affraid of a two-smoke twin with two carbs or putting a different/bigger carb on a smoker that has a single carb on a manifold to two cylinders.
As for four-strokes, Im still convinced that the "safe" settings that carbs are set up with by the makers takes a bit of the pep out of the engine?.
I seek your wisdom Thumbs Up
Teflon-Mike
tl;dr
PostPosted: 13:04 - 23 Sep 2011    Post subject: Reply with quote
If you missus lets you do ANYTHING after the XS and the SACHS.......
Do what SHE says!
Personaly usually found that Stock Set-Ups are pretty hard to better; unless you have gone wild on tuning; & if carefully set up, crisp and as responsive as anything. More gets 'dulled' mucking around with air filters and exhausts than lost ion the carb.
BUT, carts and horses!
'Project'..... a bike...... over 125 less than 400..... we dont even know what it is yet...... BUT your worrying about the carburation?!?!?!?
Whats the story with the SACH's at the moment?
To my mind that is just BEGGING to be Super-Singled with a Dominator or SL650 motor.........
pepperami
PostPosted: 18:16 - 23 Sep 2011    Post subject: Reply with quote
OH ureeka!! at last .... someone thinking along the same lines as me Very Happy Thumbs Up
I was toying with the idea of a DR250/350/400 lump but I am not sure about dimensions/size/compatability of mounting?.
That suzuki 125 engine it has living in it`s frame is a big lump for a 125?.
As for the story so far on the Sachs = it`s on the road all legal.
It`s as scruffy as hell but I dont care Very Happy
Non standard handlebars and no fairing but thats how it came to me and I kind of like it the way it is, style wise anyway Thumbs Up .
PostPosted: 20:50 - 23 Sep 2011    Post subject: Reply with quote
CV carb is more idiot proof but harder to set up. Slide carb is easier to set up but relies on some care from the rider.
Unless the CV carb was pretty close to the right setting for that bike I would use the slide carb.
The last post was made 14 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 94.78 Kb
