Gilera DNA 50cc not firing up - Coil? Ignition? Battery?
will108
PostPosted: 16:58 - 22 Sep 2011    Post subject: Gilera DNA 50cc not firing up - Coil? Ignition? Battery? Reply with quote
Hi guys,
As per the title, my DNA is not firing up.
I do not think it is the battery as I connect a charger to it and it said full, and when I started the bike with it attached, it just kept kicking but did not fire.
Please have a look at a video I have uploaded of me starting it:
https://www.youtube.com/watch?v=Mv3_Ryftwbw
I have put in a brand new spark plug.
Thanks in advance.
Will.
PostPosted: 17:23 - 22 Sep 2011    Post subject: Reply with quote
Dead battery.
Its not even turning it over.
cb1rocket
PostPosted: 20:36 - 22 Sep 2011    Post subject: Reply with quote
battery has totally had it, it say charged cos the battery won't take any charge fooling the charger into thinking its charged.
As above it doesn't even turn over, get a new battery mate
Nope.
PostPosted: 00:21 - 23 Sep 2011    Post subject: Reply with quote
1) Battery is dead.
2) Try kick starting it.
Itxi
PostPosted: 00:50 - 23 Sep 2011    Post subject: Reply with quote
Can the battery be dead if the starter motor is still working? (I guess that's what you can hear, pretty sure it turned it over once.)
Have you looked at the spark plug(s)? Check that they still give a spark when you kick start it. If not it could be that you need to check the spark gap (not likely if it's worked before), or you may need a new plug.
If the new plug doesn't work my guess would be the ignition coil. You can test it with a multimeter or a bulb, best to look in the haynes manual for your bike to check how on that one.
I'm having the same problem with my bike, I can only guess it's the ignition coil right now since I've checked everything else. But at the same time this is my first bike so I'm not the best person to take advice from.
Nope.
PostPosted: 01:34 - 23 Sep 2011    Post subject: Reply with quote
Ok, were back to trouble shooting small capacity two strokes again!
There are several things that every 2 stroke engine needs to run (Ill stick to two strokes as its on topic).
It needs the following:
Air, Fuel, 2 Stroke Oil, Spark, Compression.
(Well, it might run without 2 stroke oil, but it'll seize quickly!)
So, to troubleshoot a Two stroke engine you need to check all these things.
Start with the basics that anybody can do at home.
CHECK THAT THE KILL SWITCH ISNT ON!
Start by checking that fuel is getting to the carb. Check that the fuel tap is on, that the fuel line isn't blocked/kinked, that you have petrol in the tank.
Then check that you have two stroke oil in the tank, that the line isn't blocked and that its still connected to the carb and/or crank case.
Then check the air filter. Check that it hasn't fallen out, make sure that its clean, make sure nothings blocked up and make sure the air box is still connected to the carb.
Check that you have a spark. Unplug the HT lead, take out the spark plug and re-attach the HT lead. Place the side of it against a head bolt or something. Hold it there with a pair of insulated pliers then kick the engine over. If there is a spark then you know that its sparking. Pop the plug back into the engine. If there is no spark then you need to check the HT lead, the Coil, the CDI/Points and condenser and associated parts.
If all thats ok then you need to look at compression. You'll need to get yourself a compression tester and find out what the compression should be for your engine. Check the compression and if its far below what it should be then your engine is due a rebuild. If thats ok and its still not running then you need to check a few other things.
Take off the exhaust and make sure that theres no nasty bits in there. De-coke the exhaust (It wont necessarily help your starting issues, but it cant hurt while its off). (The following bit is stolen from Pete)
Pete. wrote:
Go to the chemist and buy some caustic soda. They have to ask you what you want it for by law, tell them it's for de-coking your motorbike exhaust. I used 2 packets last time I did this.
Take the exhaust off the bike. Find something to plug the front hole with like a sink plug - it's gotta be a good fit.
Get a plastic dustbin and fill it to the top with water.
Get a bucket and fill that with warm water. Put on some marigolds and SLOWLY add the caustic soda to the bucket of water, give it a stir.
IMPORTANT: DO NOT put the caustic soda in the bucket first or you'll get very badly burnt when you add the water. DONT get the caustic soda on your skin or you'll get severe burns. If you splash yourself with the water/soda mix, get your hands into the dustbin fast and wash it off.
Plug the end of the exhaust and pour the bucketful of water/caustic soda mix into the other end of the exhaust until it's full. Next, pick up the whole exhaust, and put it in the dustbin full of water. This is to stop the mixture from running out of any leaks.
Leave it overnight, in the morning you should be able to tip out a sludgy black gunge from the pipe and it will be unblocked.
Once you've done that put the exhaust back on.
So if your bike STILL isnt running then you've got problems. If you've got Air, Spark, Fuel, Compression and Oil and its not running then theres a serious issue. At this point in time we dont care how well its running, just that its RUNNING!. Try starting the bike on full throttle. Hold the throttle open and kick it over.
If its still not running then id suspect carb problems. Take the carb out and strip and clean it. For this you'll need some carb cleaner (I use STP, you can get it for around £5 on fleabay or from any decent auto parts store). There a plenty of guides for cleaning and checking carbs around so read one of those and see if you can find a specific one for your carb if you've never done it before. I also recommend reading up on carbs first so you know what your looking at.
Once you've cleaned the carb put it back on and try again.
Now you should have everything needed for combustion. Spark, Fuel, Air, Oil, Compression. Your bike should now be running. If its not then you've done something wrong. Go back through it all again.
If you're still failing to get it to run, ask for help from someone or take it to a garage.
PostPosted: 08:38 - 23 Sep 2011    Post subject: Reply with quote
Thats not turning over..that using what little juice the battery has left to move.
This is a good battery turning over a bike...
https://www.youtube.com/watch?v=xqbfnKwOr1E
OP... new battery, get it and charge it... fit it and you'll be fine.
You have a kick start on that DNA?
will108
PostPosted: 15:53 - 23 Sep 2011    Post subject: Reply with quote
Wow, thanks for the responses guys.
I have ordered a new battery for £25, will get in Sunday and let you know.
Thanks again.
Will.
PS. I have broken the inside of the kick start, I need a new case.
will108
PostPosted: 17:19 - 12 Oct 2011    Post subject: Sorted Reply with quote
Hi,
Checks made:
Getting good spark.
Enough compression in top end.
Carb Getting petrol.
No oil coming through.
So:
Oil pump not working, added oil in tank.
Cleaned carb.
New plug.
Cleaned choke.
New battery.
Done.
Works.
Crazy.
Thanks.
Will.
cb1rocket
PostPosted: 20:22 - 12 Oct 2011    Post subject: Reply with quote
you really need to get that pump sorted, are you checking it correctly?
Nope.
PostPosted: 23:34 - 12 Oct 2011    Post subject: Re: Sorted Reply with quote
will108 wrote:
Hi,
Checks made:
Getting good spark.
So:
Cleaned carb.
New plug.
Cleaned choke.
New battery.
Done.
Works.
Crazy.
Thanks.
Will.
You do realise that you cant just chuck two stroke in the tank and hope for the best right?
The last post was made 15 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 73.14 Kb
