| koolio |
 koolio Spanner Monkey
| stinkwheel |
 Posted: 23:41 - 20 Sep 2011 Post subject: |
You'll be gearing it significantly higher. Might need to drop a tooth or two on the front sprocket to pull away cleanly.
If you go from 19-18 to 20-20 you'll be effectively dropping the front by an inch. It'll be a bit twitchier and will drop into corners more agressively.
It will be a bitch finding decent tyres.
Your speedo will under-read by a fair amount.
Practicality-wise. You might find tyres foul the swingarm, touch the rear mudguard under compression or rub on the front mudguard bracket.
I'd check the clearance and tyre availability before blowing your wad on tasty rims. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| el_oso |
 el_oso World Chat Champion
| Silentwalker |
 Silentwalker Two Stroke Sniffer
| G |
 G The Voice of Reason
| chris-red |
| stinkwheel |
 Posted: 10:35 - 21 Sep 2011 Post subject: |
| chris-red wrote: | I would have though it would be more stable not more twitchy. But stable in a bad way, as in not wanting to lean over at all, the bike always fighting to be upright. |
Shouldn't do. If the back is going from 18 to 20 and the front is going from 19 to 20 you're raising the rear by 2" and the front by 1". It would have the same net effect on the steering geometry as dropping an inch of fork through the yokes. It'll get twitchier, possibly a lot twitchier.
If it gets too twitchy, you might need to alter the ride height somehow, either by fitting longer forks, slugging the original forks (nasty!) or fitting shorter shocks (assuming the wheel would still fit under the mudguard). Or you could chop the frame...
Or it might turn it into a nimble little road racer? Or you might just decide to fit wider bars, crank up the steering damper and live with it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| chris-red |
 Posted: 11:21 - 21 Sep 2011 Post subject: |
| stinkwheel wrote: | | chris-red wrote: | I would have though it would be more stable not more twitchy. But stable in a bad way, as in not wanting to lean over at all, the bike always fighting to be upright. |
Or it might turn it into a nimble little road racer? Or you might just decide to fit wider bars, crank up the steering damper and live with it. |
My thinking is the centrifugal force of the bigger wheels will slow the handling down loads. People raise the rear of bikes by an inch all the time and it doesn't make them twitchy. My TDM has the rear raised 30mm, and it made it handle quicker but by no means is it twitchy. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| G |
 Posted: 11:24 - 21 Sep 2011 Post subject: |
But bigger wheels should make it less twitchy, so possible it will balance out .
Or you may be able to get a lower profile tyre, depending on the current one on (though less likely at these sizes.)
Or may be able to adjust the ride attitude in other ways too. |
| weasley |
 weasley World Chat Champion
| chris-red |
| koolio |
| Ariel Badger |
 Ariel Badger Super Spammer
| Fizzer Thou |
 Posted: 22:23 - 23 Sep 2011 Post subject: |
On the front of one of my CB550 Hondas I had this setup
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Earlydays034.jpg
What I had wanted to do was to fit an 18" alloy rim to the front hub with CB750F1 discs and caliper brackets.But with the two 500/550 discs it was more than adequate stopping,with one disc having a set of Ferodo pads,with the other having Vesrah pads.This way it was twin discs in the dry,and single disc operation in the wet,as Vesrah were known to be rubbish in the wet in those days.
But on my CB750F2 I fitted a much bigger rear wheel,a 4.75x18 rim,with the front being a 3.25x18.This allowed me to fit a 160 on the back CMA wheel and a 110/80x18 on the front CMA.Both wheels were custom made for me,thus allowing what were modern tyres in their day.
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/My750042.jpg ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| G |
The last post was made 14 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
