wire for loom
at106
PostPosted: 19:53 - 24 Sep 2011    Post subject: wire for loom Reply with quote
My suzuki gs125es needs a new loom, as there are many bodged connections. I cant find any for sale so im going to make one. Ive found a website which sells wire but what type and size of wire do i need.
Battery cable
https://www.autoelectricsupplies.co.uk/product/752/category/124
For the main part of the loom i have a choice between
Standard PVC cable
https://www.autoelectricsupplies.co.uk/product/66/category/11
Or Thin wall cable
https://www.autoelectricsupplies.co.uk/product/70/category/114
So what type and size of wire is recommended?
Thanks
FerretFing
PostPosted: 20:09 - 24 Sep 2011    Post subject: Reply with quote
I don't have much experience with an entire loom but I needed to make a new connection between my voltage regulator & alternator for my BMW F650 & I used this;
https://www.ebay.co.uk/itm/Tri-rated-2-5mm-Yellow-cable-wire-14AWG-5metres-30amps-/260853578840?pt=UK_CarsParts_Vehicles_BoatEquipment_Accessories_SM&hash=item3cbc15bc58
They sell all kinds of wire at different ratings
neil.
PostPosted: 05:39 - 25 Sep 2011    Post subject: Reply with quote
I would not go for the thin wall stuff - less insulation means it could be rubbed away more easily if a wire fouled part of the frame or something.
Johnser
PostPosted: 22:23 - 25 Sep 2011    Post subject: Reply with quote
I've built a loom for an old car and a bike. quite a satisfying project once you've got started. I ordered most of my bits from this guy:
https://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php
Great service and pretty easy to use website.
If you want to do it on the cheap, go to a scrappy and grab as long a length of the main loom as possible from something big and german, grab the relays and fuses too. the front to back section of the loom will contain loads of different colours and gauges - plenty to sort a small motorbike.
Thinwall; better for keeping looms compact than resisting abrasion, play to its advantages!
Solder every spade/bullet connector. do not rely on crimping alone
heat-shrink tubing and cable ties are your friends
good luck
at106
PostPosted: 19:03 - 26 Sep 2011    Post subject: Reply with quote
Thanks for all the replies and the links Thumbs Up I think im going to go for the 30/33 amp thin wall wire and i'll put it into a pvc tube thing to protect it.
The last post was made 14 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 44.17 Kb
