Mtx 125 88 Supermoto rims
bradh511
PostPosted: 14:58 - 25 Sep 2011    Post subject: Mtx 125 88 Supermoto rims Reply with quote
Right this is my question .. my standard rims only reli allow shitty off road tyres that on a 40 mile round trip most days.. if and where possible i would like to put some nice road tyers on it..
Here is my point if i could was to get some 18" supermoto wheels and take the center hub out and changeing it with the mtx center hubs... if this is possible this is what i need to know
Thanks Brad
Teflon-Mike
tl;dr
PostPosted: 15:21 - 25 Sep 2011    Post subject: Re: Mtx 125 88 Supermoto rims Reply with quote
Thanks Brad
What you are talking about is re-building the wheel around standasrd hubs, but with 17" rums.
Yes thats what they do. BUT wheel building is hard, and its not cheap.
Set of rims will set you back, probably £90 each, spokes about £30 a set, then you have to build and true the wheel, which is you pay some-one is likely to be around £50 a wheel.... THEN you can go look for tyres and tubes and rim tape to to mount them, and you are looking at best part of £500...
On a 23 year old mud-plugga probably not worth that on standard tyres....
You would also have to recalibrate the speedo to account for smaller front wheel turning faster for same road speed, and get new chain and sprokets to gear up to account for same at the back wheel, or you'll be screaming along with the speedo showing something like 1oomph when you are flat out in top doing a genuine 60!
Personally; I would hunt out a pair os spare hubs to 'build' up as motard rims, so I could easily switch back to dirt tyres and use the bike as intended.... but I probably wouldn't go to the trouble on a 23 year old 125; maybe if it was a propper MX road conversion, or big bore enduro bike, but not a 125 trailie.
For the cost and hassle and effort (ins co's already dispise 125 dirt bikes, withouyt having to decalre fairly major mods like different wheels) probably be cheaper and easier and a LOT less hassle to put the money into buying a propper road bike, for the road....
Or if you have no intension of using it off road, simply flogging it; adding money for conversion to what you'd get for it and using that to buy either a propper motard, or propper road bike....
WHICH; sort of begs the suggestion; why a 125? And if the answer is 'no licence', the suggestion suffering the wheels it has a little longer, getting tests done on it; then flogging off for a bike more suitable to what you want.
PostPosted: 15:53 - 25 Sep 2011    Post subject: Re: Mtx 125 88 Supermoto rims Reply with quote
You can get good and very capable road tyres in trail sizes. Easily enough to get my knee down and more a dr600 (obviously need a reasonable bit of lean to get your knee down.)
I've done thousands of miles on trail rims with road tyres and plenty of people have gone around the world, spending many hours in the saddle every day.
There probably are some road rims that with different bearings and a caliper bracket could be made to fit.
This is presuming you're not planning to use it for 'real' supermoto - ie races which involve on and off road sections.
Also, supermoto wheels are pretty much always 17". You probably already have an 18" rear wheel as it is!
And yes, as per Mike, you can get rims laced to your wheels. Likely to be the most expensive solution.
stevo as b4
PostPosted: 18:28 - 26 Sep 2011    Post subject: Reply with quote
Yeah definately look into some decent road tyres for the std 21"/ 18" rim sizes if it's just better roadholding and braking that you want. Then you can easily switch back to off road or trail tyres somewhere between the two if you want to use it off road.
The 17" supermoto rim idea is mainly just better for the style and ease of obtaining real proper sticky race or track day tyres. On a purpose built Motard then wide 17" rims are obviously the best way to ensure a decent tyre choice for track use etc.
On a cheap and old bike with std trailbike suspension and brakes, then 17" rims are not going to be much of a benefit, especially as the forks and swinging arm are probably going to limit tyre widths to sizes that are not available in the stickest sports bike compounds and designs.
Im sure that Pirelli did the MT65 tyre in 21" fitments for the front of trail bikes, and i found them to be a really good grippy tyre for my CG125, so if you can get a set of those or whatever the modern equivalent is (City sport demon?) then id definately give them a try, and i think you would be massively please with the improvement over trail or proper off road tyres for road only use. steering, wet grip, and acceleration and braking should all be a bit better TBH!
The last post was made 14 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.07 - MySQL Queries: 13 - Page Size: 44.47 Kb
