painting topbox rack.
johnsmith222
PostPosted: 02:55 - 26 Sep 2011    Post subject: painting topbox rack. Reply with quote
Hi guys.
I have a givi topbox rack that is composed of two metal arms and a plastic plate.
The paint all flaked off last winter and they were rusting up. I don't really have any money but have hammerite black that I can paint on with a brush.
I'm really just looking to protect the metal underneath. The metal arms have already been rubbed down, but what grade sandpaper should I use last before putting the paint on?
I have painted quite a few things with hammerite but it has always resulted in it flaking off and rust forming on it.
Also, how many coats do you recommend I do?
Thank you for any helpful tips.
-David.
andy_uk
PostPosted: 06:52 - 26 Sep 2011    Post subject: Reply with quote
If it was me, then I'd use "P120 finishing paper"
Make sure all bare metal is coated with at least 2 coats of Hammerite. Depending on how old your tin is, you may need to get your subsequent coats on as soon as the previous one is dry.
Each coat should be 4 times the thickness of standard household gloss paint so don't over brush it when applying it.
FerretFing
PostPosted: 11:57 - 26 Sep 2011    Post subject: Reply with quote
I recently bought a BMW F650 & the racks were pretty rusty;
https://i361.photobucket.com/albums/oo53/ferretmonsters/bmw%20f650st/before.jpg
I just got the loose stuff off with a wire brush & gave it a quick go over with something like P40 paper (very coarse) - find that the rougher the surface the better the grip/key for the paint....used Hammerite direct-to-rust paint 3 coats & the results are fine for me;
https://i361.photobucket.com/albums/oo53/ferretmonsters/bmw%20f650st/painted.jpg
johnsmith222
PostPosted: 14:32 - 26 Sep 2011    Post subject: Reply with quote
Thanks a lot guys for taking the time to answer my question! I am confident enough to do it and it should hopefully work out better than previous attempts. I think I was using too fine a sandpaper.
Thanks again!!! Thumbs Up
grant965
PostPosted: 19:01 - 26 Sep 2011    Post subject: Reply with quote
120? don't you need a finer grit?
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
PostPosted: 19:16 - 26 Sep 2011    Post subject: Reply with quote
Not with Hammerite, it's like painting with marmite.
andy_uk
PostPosted: 19:17 - 26 Sep 2011    Post subject: Reply with quote
Not if it's the final sand before applying the first coat. Hammerite (including the smooth one) tend to cover a multitude of imperfections.
When sanding between coats I'd go for 320 or finer...
johnsmith222
PostPosted: 20:09 - 26 Sep 2011    Post subject: Reply with quote
i think my lack of sanding between coats is where I have gone wrong in the past.
Ah well, I have now learned. Thumbs Up
andy_uk
PostPosted: 20:36 - 26 Sep 2011    Post subject: Reply with quote
Make sure they're fully dry before sanding though...
If you can spare the time, leave it a full day at least.
The last post was made 14 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 59.96 Kb
