Cleaning out forks without dissasembly.
herulach
PostPosted: 16:27 - 26 Sep 2011    Post subject: Cleaning out forks without dissasembly. Reply with quote
Right, the fork oil in the fazer is getting changed this weekend, as I'm pretty confident it will never have been done.
So, I'd like to get all the slimey grey gunge out without disassembling the things (seals etc are all fine). Current plan is to fill with paraffin, pump it a few times then leave to dry out for a bit - is that going to work or does anyone have any better ideas?
YBR 125>FZS600
TUG
PostPosted: 16:31 - 26 Sep 2011    Post subject: Reply with quote
remove the forks, undo the top, leave upside down, pump like a shotgun, leave again, fill to specified amount (personally i use an air gap tool as its more accurate) then refit top -> refit forks.
Haz ER-5, innit!
herulach
PostPosted: 16:40 - 26 Sep 2011    Post subject: Reply with quote
But surely that will leave it full of grimy old oil hence the parrafin plan?
YBR 125>FZS600
TUG
PostPosted: 16:48 - 26 Sep 2011    Post subject: Reply with quote
Maybe but tbh the oil will have to be like 10 years or older to do that, I've changed loads of fork seals and have never seen that sort of stuff, the oil just goes thin and pisses out.
Paraffin is seriously unnecessary.
Haz ER-5, innit!
herulach
PostPosted: 18:26 - 26 Sep 2011    Post subject: Reply with quote
Bike is 12 years old, guessing oil is too. (certainly the rest of the stuff that should have been done with age is (brake lines etc, you should have seen the colour of the brake fluid!)
YBR 125>FZS600
PostPosted: 23:46 - 26 Sep 2011    Post subject: Reply with quote
If I was going to flush them with anything, I'd use warmed up (so it's thin) cheap and cheerful engine oil. Asda do some seriously cheap stuff.
That said, the gunk looks horrible but it's just emulsified oil. If there were bits of muck in there then I'd give them a flush out but I've never seen the need to flush any yet.
ATF makes a good substitute for 10wt fork oil and is very long-lived, pressure stable and maintains it's viscosity over a wide temperature range.
Raffles
PostPosted: 10:36 - 27 Sep 2011    Post subject: Reply with quote
I'm part way through rebuilding the forks on my 30 year old Bultaco and I suspect that that they too have been neglected since birth. I used cellulose thinners to remove the gunge although that probably wouldn't be a good idea if you are wanting to re-use your existing seals.
Stinky's idea of using warmed engine oil sounds pretty good.
The Artist
PostPosted: 10:37 - 27 Sep 2011    Post subject: Reply with quote
Fork oil is really thin anyway. I have never seen gunk. The thickest oil from forks I have seen was about the thickness of normal 10w40 engine oil.
The last post was made 15 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.5 - MySQL Queries: 13 - Page Size: 54.86 Kb
