| Jefr0 |
 Jefr0 World Chat Champion
 Posted: 13:56 - 27 Sep 2011 Post subject: Bike didn't start this morning - guessing electrical - fixed |
Hi all
On my Honda CBR 600 F '91, I use it 5 days a week commuting.
Went to start it this morning and didn't even try to. The dash lights came on slowly, then I pushed the starter and they faded almost off.
I'm assuming it's regulator/rectifier.
Is there any obvious signs. For example if the rectifer has burn't out would it be a case of replacing that and sorted or will there be other things to replace?
Otherwise it's in the shop to find out
Thanks
Jeff ____________________ Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
| mjn51 |
 mjn51 Traffic Copper
| Bendy |
 Bendy Mrs Sensible
| Jefr0 |
| GSTEEL32 |
 GSTEEL32 Traffic Copper
| FirebladeRuss |
 FirebladeRuss Spanner Monkey
| Jefr0 |
| FirebladeRuss |
| Jefr0 |
| FirebladeRuss |
 Posted: 15:44 - 27 Sep 2011 Post subject: |
There's no point in measuring the current battery, as clearly it's goosed.
For example, (car example, i'm afraid, as it's all i know!) a new car battery off the shelf should read around 12v. When connected to the car, and the car is running, the alternator will be charging the battery and so it'll usually read around 13.5v - 14v.
My thoughts were apply the same principle to the bike.
https://www.ehow.com/how_5877475_measure-car-battery-multi_meter.html
It says here to not do it with the engine running - which is fine if you want just the battery voltage (will be the same as measuring it not connected to the bike) - having the engine running, do the same thing and you'll see a slightly higher voltage reading if the charging system's ok. ____________________ Twitter is for people who can't STFU even when they're by themselves |
| Jefr0 |
| Martay |
 Martay World Chat Champion
 Posted: 15:47 - 27 Sep 2011 Post subject: |
Deffo sounds like the battery.
If you'd like to check the reg/rec, you need to get the bike running.
Can you bump start the bike?
If so, check the voltage before and after, with the engine running, check it doesnt rise over 14 orso volts with the engine running or revving.
EDIT: ^ beat me to it! ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
| FirebladeRuss |
| Jefr0 |
| FirebladeRuss |
| Jefr0 |
 Posted: 21:35 - 27 Sep 2011 Post subject: |
UPDATE
I put the battery on a trickle charger (optimate) for about 3 hours.
Came back to it and it showed a green light (charged)
Went to start it on the button and it just clicked once and the ignition lights went out.
Left it for 5 seconds and the ignition lights slowly came back on.
Was going to try and charge it overnight and see if that makes a difference.
Ideally need to test another battery on it.
Does the above sound like the battery is dead or another symptom?
Sorry to keep going on!  ____________________ Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95) |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 21:37 - 27 Sep 2011 Post subject: |
Yes, it's a dead battery. It's not holding charge. ____________________ My Flickr |
| orac |
 orac World Chat Champion
 Posted: 22:48 - 27 Sep 2011 Post subject: |
as everyone has said the battery has had it day. my MF battery did that same thing but blew fuses instead.
any how if you want to check you charging, check the battery voltage while off (12isvh volts), then across the battery temrinals check the voltage with the engine at or above 5000 rpm, with and without the lights off. as a general rule be getting above 14.5v and below 15.5 (normally quoted as 15v), but check you manual. it sholdnt get any higher if the revs go above 5k, so it should be within spec at 7k, 10k or whatever but not normally below 5k
if you are not getting that into the battery then it is not charging, or more than that, its overcharging and cooking the battery. if it low, check the alternator output, and coil resistance. if that OK then swap the reg/rec, i can speak to a buddy and he may be able to give me wiring for installing the bullet proof CB250 into your machine.
Edit:
also with your current battery, check you abttery before you swith on the ignition, keep the meter of/connected and watch what happens to the reading - if goes down that its the battery. ensure that the abttery doesnt get, if it does you got a short |
| Jefr0 |
The last post was made 14 years, 356 days ago. Instead of replying here, would creating a new thread be more useful? |
