| Mrjoolz |
 Mrjoolz Brolly Dolly
 Posted: 10:44 - 28 Sep 2011 Post subject: May have overtightened chain |
Get clunking when pulling off away from lights...
I will adjust the chain this evening, but I have ridden into work today (40 miles), and just wondered if doing the 40 miles home will be OK, or will it damage the bike (front sprocket)
thanks in advance ____________________ Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa..... |
| P.addy |
 P.addy Red Rocket
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 11:17 - 28 Sep 2011 Post subject: |
It wont damage your sprockets, itll damage your output shaft bearings. Fingers crossed aye? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Tenko |
 Tenko Could Be A Chat Bot
| Jefr0 |
 Jefr0 World Chat Champion
| P.addy |
 P.addy Red Rocket
| The Artist |
 The Artist Super Spammer
| Mrjoolz |
 Posted: 12:06 - 28 Sep 2011 Post subject: |
Hiya Paddy,
I finish at 5:30 tonight and will be home by 6:30. I can pop in then.
| P.addy |
 P.addy Red Rocket
| Mrjoolz |
 Posted: 12:33 - 28 Sep 2011 Post subject: |
Could it damage the bike, as I am hearing a clunk when I pull away from traffic lights a little harder.
Could it be front sprocket ? ____________________ Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
| ClockworkJesu... |
 ClockworkJesu... Nitrous Nuisance
 Posted: 12:38 - 28 Sep 2011 Post subject: |
Couldn't a clunk be an under-tightened chain?
Y'know, clunking as the chain takes up slack real quick?
More of a general question than real assistance. Am learnin' too. |
| Mrjoolz |
| Mrjoolz |
 Posted: 12:55 - 28 Sep 2011 Post subject: |
Ooops, just read all the posts between my original and my next post. Thanks all, I'll check and losen chain if required.
Its not a loud clunk, but a very sublte one, but I know its there, so I am probably turning it into some local building shaking kinda thing.
Best to check it out with you all.
rather ask this question, then "how do I split my gerarbox"  ____________________ Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
| P.addy |
 P.addy Red Rocket
 Posted: 13:13 - 28 Sep 2011 Post subject: |
Its cool mate, if its tight we'll loosen it a bit. I've got a fair bit of oil too if it needs a clean and lube  |
| Souleh |
 Souleh Trackday Trickster
| ClockworkJesu... |
| Mrjoolz |
 Posted: 15:16 - 12 Oct 2011 Post subject: |
Think I may have sussed why my chain/bike is making noises when I pull away.
I have just watch a youtube video on chain tightening on a GS500 which has the wheel alignment brackets that slide over the spindle. these brackets have little feet which bend under the swingarm, but do not touch it.... :o(
I thought that they had worn somehow, and therefore when I was trying to check that wheel was aligned, I moved the bracket so one of the feet touched the swingarm, and the same on the other side, and then proceeded to tighten up spindle.
However apparently after watching this video, you position these alignment brackets so neither feet touch the swingarm, and there for the indicator points straight up at the notches.
therefore I think that the wheel is slightly out of alignment and hence the clunking is the chain catching on teeth as wheel not aligned properly.
Does this sound a fair assumption.
Mr Joolz ____________________ Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
| Vincent |
 Vincent Banned
 Posted: 15:27 - 12 Oct 2011 Post subject: |
How did you line the wheel up  ____________________ Space Is Deep |
For the chain alignment to cause the chain to snatch I would expect it to need to be quite a long way out.
To me a too tight chain seems FAR more likely.
Don't trust the marks on the swinging arm. Get the wheel in line (string, scaffolding pole, laser point, some other reliable method) and after that just make sure you turn both adjusters the same number of flats (one flat is going to move the adjuster about 1/4mm on most bikes - far more accurate than you can see on the markings even if they are accurate).
| Mrjoolz |
 Posted: 15:43 - 12 Oct 2011 Post subject: |
String ? How could I check alignment with string ?
probably being thick. thanks.  ____________________ Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
| Howling TerrorOutOfOffice |
| Mrjoolz |
 Posted: 16:29 - 12 Oct 2011 Post subject: |
excellent. I'll adjust chain as its a little loose, and then try this or alignment.
Thanks for replies. ____________________ Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
| Mrjoolz |
 Posted: 14:01 - 13 Oct 2011 Post subject: |
just called local dealers to ask them about my ongoing pulsing with brakes, and they said pop bike down and they will pop in on their brake tester and let me know if its pads, discs, wheel etc...
They are also going to check the chain/rear wheel about this clunking, to see if its kush drive/ sprocket carrier bearings/ or actually chain and sprockets.
All for 15 mins labour, at £17.00
I'm well pleased with that so I will actually have a better idea of what to actually throw money at instead of purely guess work or assumptions.
| Robby |
 Robby Dirty Old Man
 Posted: 14:18 - 13 Oct 2011 Post subject: |
You even have shiny rims, you bastard.
That bike had better be left to me in your will. That or I'm going to have to buy it off you. |
The last post was made 15 years, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
