Stuck valve inspection covers
at106
PostPosted: 13:50 - 28 Sep 2011    Post subject: Stuck valve inspection covers Reply with quote
The valve inspection covers on my gs125 are stuck and wont undo whatever i try. Ive tried sockets and spanners but the covers are just rounding off. Ive now removed the head from the engine and ive tried applying heat, and putting the cover in a vice to grip them but they still wont undo. Would plusgas or similar help, or does anyone have any other ideas?
Thanks
PostPosted: 14:01 - 28 Sep 2011    Post subject: Reply with quote
Mine were an absolute butt nugget to undo.
Were rounded off before I started, I cut the edges down so they were flat, applied a blowtorch to them and used a pair of molegrips. They came out but I did need new ones Laughing
at106
PostPosted: 14:16 - 28 Sep 2011    Post subject: Reply with quote
Was that with the engine complete? I dont mind buying new ones i just dont want to cause damage to anything else.
PostPosted: 14:24 - 28 Sep 2011    Post subject: Reply with quote
If they are alloy ones, I'd suggest heat is your friend. Get them hot enough to vapourise a drop of oil then try.
Another option is freeze and release spray.
A third option is alternating between the two (heat, then freeze, then heat again until they come loose).
A good soaking in penetrating oil overnight may also help matters.
at106
PostPosted: 14:37 - 28 Sep 2011    Post subject: Reply with quote
Yes they are alloy. By heating them will i damage any other parts, the rocker arms are still fitted in the cover?
When you say freeze do you mean putting the whole cover in the freezer?
PostPosted: 14:56 - 28 Sep 2011    Post subject: Reply with quote
Shouldn't do. It's an air-cooled engine and they get pretty hot anyway. The rocker arms are steel. You could melt the whole cylinder head into a puddle and the rocker arms would still be ok.
Freeze and Release spray:
https://www.atr.com.my/store/images/Freeze%20and%20Release%20Loctitite.jpg
at106
PostPosted: 15:13 - 28 Sep 2011    Post subject: Reply with quote
Thanks for all your replies, i finally got them off! I filed the heads on them so i could fit a socket on tightly, i then put the cyclinder head into a vice and hit the end of the ratchet with a hammer to shock them loose.
The last post was made 14 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 52.4 Kb
