| fatjames |
 fatjames World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 17:39 - 28 Sep 2011 Post subject: |
Dont add a K&N, it costs more money than you need to spend...and you go no faster.
17mm ring spanner/socket on the underside of the bike. Can be done on the side stand. When you refill, I believe its 1litre... remember to put the sump plug back in... preferably a new crush washer. Go careful to undo and do it up the right way.
Dont over tighten it on the way back in... They are quite easy to bugger on this bike.
Test the oil level by letting the bike sit idling for a minute after the oil change. Unscrew the dipstick, clean it off and with the bike on a flat level and standing upright put the dipstick back in and screw it in, unscrew it again and check the oil is on the xxxx area of the dipstick between the top and bottom is ideal. Mine tends to sit more near the top end of the dipstick xxxx's  |
| fatjames |
 Posted: 17:58 - 28 Sep 2011 Post subject: |
| ##Paddy## wrote: | Dont add a K&N, it costs more money than you need to spend...and you go no faster.
Cheers, that sounds much easier than I thought.
| Quote: | Dont over tighten it on the way back in... They are quite easy to bugger on this bike.
Do you know if there is a torque setting? Or am I just looking to stop when it gets tight? |
| Livefast123 |
 Livefast123 Nearly there...
 Posted: 18:28 - 28 Sep 2011 Post subject: |
As said K & N = Waste of time.
Take the bike for a spin before doing the oil change to get the engine oil nice and hot. Let it settle for around 10 mins and then leave it drain out for at least 20 mins. This just ensures that you get all the shit out of the bottom of the sump. Your new oil stays cleaner for longer and you get a happy engine
When it feels tight it probably is....don't push it any further ____________________ Current ride - Yamaha MT-07 |
| P.addy |
 P.addy Red Rocket
 Posted: 19:22 - 28 Sep 2011 Post subject: |
Do you have a torque wrench?
Oil drain plug is 25nm  |
| cb1rocket |
 cb1rocket World Chat Champion
| fatjames |
| fatjames |
The last post was made 14 years, 353 days ago. Instead of replying here, would creating a new thread be more useful? |
