| binge |
 binge Emo Kiddy
 Posted: 20:24 - 28 Sep 2011 Post subject: Mindset Tests |
Hi guys,
I've recently been headhunted to work for another company.
Part of the interview / screening process involved one of these Online Mindset tests.
Now I've never done one of these before, and after the first 30 or so questions, I quickly realized that it was pretty much a massive repeat of a small batch of questions, just asked in a different manor.
I am assuming this is to detect if you are lying about the answers.
I answered it with the answers which were instinctive, as apposed to the ones I thought were 'right'.
In some cases, I felt I was putting myself down a little, but at least the test has come through as truthful as possible.
Can any of you guys explain the answers at all? I have Google'd it but the opinions are very varied.
The job I am going for is a Recruitment Consultant role, so it is based closely around targets, sales, and money. They seem to be the 3 key areas of recruitment.
Money motivated, tenacious people... aha!
Anyway, the answers are in 3 areas, then a total figure.
What do these numbers mean? Should they be higher, or lower?
My results were:
Global
319
Good
291
Grit
336
Total
946
Is this good/bad/average?
Cheers guys.
Ben |
| mistergixer |
 mistergixer World Chat Champion
 Posted: 20:41 - 28 Sep 2011 Post subject: |
Those scores probably mean that you are either a rapist or a peedo.
Expect a knock on the door from the coppers in the next few days.
 ____________________ Space Monkey #7
Mistergixer's videos on YouTube |
| Dr. Quack |
 Dr. Quack Could Be A Chat Bot
| RPM |
 RPM Nova Slayer
 Posted: 21:05 - 28 Sep 2011 Post subject: |
The scoring system is much more subjective than you might think. The emphasis can shift depending on the type of job, organisation or field of work.
In my experience you could be strong in any one or more of the 3G arenas based upon the circumstances you are facing at the time.
If you are looking at HR and recruitment then an employer might hope to see strengths in Good, Global and Grit in that order.
In systems or matrix management they might expect or prefer Global, Grit and Good.
With this test, it is usual for the interview panel to look for links to support your scoring within your CV. This is not always a reliable strategy because a lot would depend on interpretation.
Either way these tests are only tools. I am sure that you are already aware that it is the actual chance to show your true skills set. I would have expected the panelists to have undertaken the same or a similar test at some point in time, just for reference, if nothing else.
I'll bet that everyone that does this type of test will not necessarily accept and the results without question. If you google mind tools or Business balls and play around with some of the tests, you will be able to influence the results quite easily. Especially Belbins or the Edisk ones.
Good luck
Mike |
| binge |
 binge Emo Kiddy
| Slacker24seve... |
 Slacker24seve... World Chat Champion
 Posted: 21:25 - 28 Sep 2011 Post subject: |
| RPM wrote: |
Good luck
Mike |
Done 'properly' Belbin is quite interesting. I found it genuinely helpful when my team shrunk after some of my FTAs took up new jobs; it sort of made everyone think about their place in the team. I'm not really one for management bollocks, I've recently been through some tedium about that with the CMI but that was one of the things I took from it that actually worked. ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
Banger rallies are ace |
| RPM |
 RPM Nova Slayer
 Posted: 21:35 - 28 Sep 2011 Post subject: |
@ Slacker24seven
Yes, I have also had to endure the CMI levels 5 and 7. I am not a fan of the culture of Management being applied as a means of trying to make the intrinsically insecure feel a bit more secure.
I think that these type of tests can be good.
I just prefer it when they are used for constructive purpose rather than as another hoop to jump through
Mike |
| Slacker24seve... |
 Posted: 22:54 - 28 Sep 2011 Post subject: |
Mike, I am a mere level 4 padawan. I don't think I'll be taking it any further than that for a while. I agree wholeheartedly though  ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
| D O G |
 D O G World Chat Champion
| binge |
 binge Emo Kiddy
The last post was made 15 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
