| jimbothe |
 jimbothe World Chat Champion
 Posted: 13:08 - 29 Sep 2011 Post subject: Ok Guru's try and tig or decent chemical metal. Engine mount |
So, picked this up the other day as a non runner and been stood for 6 years.
30k from new with papers.
https://i22.photobucket.com/albums/b342/jgillard/NEWFJ1200007.jpg
Got it running last night after stripping and rebuilding the carbs, replacing some wiring, the odd fuse and draining, flushing and draining the old fuel out and a quick service.
Runs surprisingly well but exhaust has rotted out. Began removing the exhaust then heard the sound of a metal part falling off
That metal part was this:
https://i22.photobucket.com/albums/b342/jgillard/NEWFJ1200003.jpg
Carried on removing the exhaust and got to the front pipe. Found where the jigsaw piece goes. Excuse the crap picture but you get the idea.
https://i22.photobucket.com/albums/b342/jgillard/NEWFJ1200004.jpg
For those who can't tell it's the top engine mount on the left hand side as sitting on the bike.
A quick dig around and Yamaha's legendary crap engine casing material crubled to dust:
https://i22.photobucket.com/albums/b342/jgillard/NEWFJ1200001.jpg
Basically, what do you think? How to proceed?
I've tried Tig welding casings before and with not much luck. Partly because the casings are not exactly the best quality Ally and partly because I'm crap at it..
It's holding on the other side and the weight is also being held by the bottom two mounts as well as the rear mounts.
I figured I would clean it all up and try some quick steel to get the shape back and then paint the frame silver again.
Waits for ridicule  ____________________ Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle |
| P.addy |
 P.addy Red Rocket
 Posted: 13:11 - 29 Sep 2011 Post subject: |
| jimbothe |
 Posted: 13:16 - 29 Sep 2011 Post subject: |
| P.addy |
 P.addy Red Rocket
 Posted: 13:30 - 29 Sep 2011 Post subject: |
Fair point  |
| temeluchus |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| jimbothe |
 Posted: 17:14 - 29 Sep 2011 Post subject: |
It is very firm in there but is just visible when the belly pan is on. I've got to take it for mot eventually and wasn't sure if they would pick up on it?
Clean metal it is not
I know that realistically chemical metal won't 'hold it' as such, it was more of a cosmetic thing so it blends in and doesn't *cough* get noticed by the mot man.  ____________________ Check out our tackle shop on Facebook:
| Andy_Pagin |
| kestrel |
 kestrel Nearly there...
 Posted: 19:10 - 29 Sep 2011 Post subject: |
Most likely the damage was caused by the corrosion itself, or by someone in the past trying to remove the heavily corroded mounting bolt. ____________________ a.k.a 'Geri'
| Vincent |
 Vincent Banned
 Posted: 20:01 - 29 Sep 2011 Post subject: |
Wow that's well wierd. Have you got a decent camera you can get some macro pics with?
first thoughts are that it's been fractured at some point....or battery acid leak maybe  ____________________ Space Is Deep |
| Handsome |
 Handsome World Chat Champion
 Posted: 20:16 - 29 Sep 2011 Post subject: |
I bought some Chemical Metal from B&Q to sort out my sump plug a couple of years back, it's still in there ( Before anyone asks again, I tried other methods but they didn't work, plus I have two sump plugs ! )...
It's still in there, has a temp rating of 150 degrees and it'll stick shit to fog, currently the tube is in the shed and I'm not allowed out after dark, if you remind me tomorrow I'll grab it from out of the tool box as I've just had a mooch on their website and I can't see it...
I recommend it though...  ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
| Vincent |
 Vincent Banned
 Posted: 20:34 - 29 Sep 2011 Post subject: |
Theres a difference between using it for a sump plug and using it on an engine mounting bolt though.
I've got to confess that I rode one of my bikes for quite a while with one out of four engine mountings missing That was on a 250, not an 1100 mind. ____________________ Space Is Deep |
| Handsome |
| garth |
 garth World Chat Champion
| jimbothe |
 Posted: 20:54 - 29 Sep 2011 Post subject: |
| jimbothe |
| cb1rocket |
 cb1rocket World Chat Champion
| kestrel |
| Vincent |
 Vincent Banned
| jimbothe |
 Posted: 22:55 - 29 Sep 2011 Post subject: |
Well thats fucked it.
The bolt circled in white has now sheared off. I soaked it, heated it and it just sheared. Very little effort if I'm honest. I reckon someones welded it in there or as said before it's a previous repair and they have stuck it in good and proper.
The remaining thread is still in the recess. I think I'm just going to weld the bastard in the hole and cover it with the sheared off bit and a bit of quick steel. Nowt lost as far as engine removal is concerned (if need be) as the frame can come off with the engine at that point.
The shaft is not moving at all. Not even from the other side.
https://i22.photobucket.com/albums/b342/jgillard/NEWFJ1200004-1.jpg ____________________ Check out our tackle shop on Facebook:
The last post was made 14 years, 351 days ago. Instead of replying here, would creating a new thread be more useful? |
