| Okeydokey |
 Okeydokey Scooby Slapper
| TheSmiler |
 TheSmiler World Chat Champion
| The Artist |
 The Artist Super Spammer
 Posted: 14:01 - 29 Sep 2011 Post subject: Re: Riddle me this! |
| TheSmiler wrote: |
From my knowledge here is the reply
1. Yes motorbike theory is suited for motorcyclists and yes this must be completed after the cbt before mod1.
2.The mod 1 and mod2 test are both suited for motorbikes/scooters if you are under 17 this will be limited to 50cc once you complete it you will be restricted for two years on 33bhp. However once you turn 18 you can ride any motorbike you want as long as it is restricted.
3. No if you completed mod 1 and mod 2 then you have your license and its clean sailing for 65years.
Also the following link should help on most questions
https://www.1stopinstruction.com/motorcycletrainingeastlondon.html |
The bit in bold is wring.
When you are if you are 17-20 you need to do cbt, theory, mod1, mod2 then you can ride upto 33bhp for 2 years from your mod 2 pass, then you have a full license and can ride whatever you want.
If you are 21 you can do direct access to ride whatever you want. |
| TheSmiler |
| Recluso |
 Recluso Brolly Dolly
| Okeydokey |
| P.addy |
 P.addy Red Rocket
| MikeyBrown |
 MikeyBrown Scooby Slapper
 Posted: 23:38 - 29 Sep 2011 Post subject: |
| Okeydokey wrote: | My problem is... I've discovered the joy of driving an auto car about five years ago, can't be arsed with manual and was thinking most bikes I like the look of are under 500cc 33bhp, anyway and twist and goers. Burgman 400 being a fine example, I see mpg go up significantly after about 400cc anyway, may as well another auto mini car type thing otherwise. |
You may say that now.
But in 2 or 3 years time you may want a geared bike. If you pass now on an automatic, you'll have to retake the whole test procedure again if you want to ride a manual bike. Extra cost, hassle and worry :/
I would recommend that you pass on a geared 125. If your heart is still set on a twist-and-go, then you can have one once you've passed. But at least you'll still have the option of getting a manual bike at some time in the future, without having to re-sit any tests
Good luck  ____________________ Past Bikes: '97 CG125, '91 GPZ500S, '01 FZS600, '07 S/Triple, '99 ZX9R, '82 GP125, '83 GP100, '03 SV1000S, '98 ZX6R
Current Bike: '07 FZ1N
Trackdays: Darley Moor - 15/6/12, Donington - 28/8/12 |
| Paulington |
 Paulington World Chat Champion
 Posted: 20:22 - 30 Sep 2011 Post subject: |
If you pass your motorcycle test on an AUTOMATIC motorcycle, you can ONLY RIDE automatic motorcycles. If you wish to ride a manual motorcycle you will have to take both your Module 1 and Module 2 again. It is better to take your Module 1 and Module 2 on a manual motorcycle.
From what I gather you've never ridden a motorcycle before so how can you decide which you'd prefer? Plus, the main reasons for the advantages of an automatic car don't apply on motorcycles:
1) Pain to depress the clutch/use your arm to change gear.
Motorcycle, dip the clutch slightly (or don't use it at all) and snick it in gear with a small movement of your foot, easy.
2) Traffic meaning you have to change gear all the time/play with the clutch.
Motorcycle, filter. Or put it in gear and leave it there as most motorcycles will do enough in 1st/2nd to have no need to change.
Just pass it on a geared 125cc as you then have an option to ride both, passing on an automatic would be a false economy. ____________________ "Four wheels move the body, two wheels move the soul."
CBT: 27/08/08. Theory: 04/09/09. Module 1: 16/09/09. Module 2: 01/10/09. |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:23 - 30 Sep 2011 Post subject: |
Smiler, at 16 you cannot take the motorcycle test; you may take a moped test, but that would restrict you to a moped, for ever; completely different group.
Clearing up the twist and go bit; like a car; test on an auto and you get the group on your licence 'endorsed' automatic only. End of.
Back to practicalities; same test; three licence groups depending what you test on.
'Light Bike' machine less than 120cc, or not on DSA list of machines approved as meeting test req's for 'Standard Bike'
'Standard Bike' machine between 120 & 125cc, meeting certain performance criteria.
'DAS Bike' das test; on full powwr machine over 125cc & 25Kw power output.
Test for 'Light-Bike' you get an A1 group licence allowing you to ride no more than a 125cc machine.... for ever. You dont need L-Plates; you can carry pillions, if machine has appropriate pillion provision; you may use motrorways but the BIKE may not be more than 125cc or make more than 11Kw or be under certain power to weight; same 'specs' as apply to Learner-Legals.
Standard Bike; gets you (CURRENTLY) a Full A group licence, endorsed with two year 33bhp & Kw/Kg limit; Ride what you like as long as it meets restriction standards; after two years have lapsed; restriction 'expires' and you can ride what you like; its a full 'A' group licence. You dont have to take any tests or courses beyond passing initial test, the tests the test and that's it.
DAS; taken on bike over 25Kw; if over 21 years old, gains you full A group with no restriction straight away.
Now add twist and go rules; Perfectly feasible if you are over 21 and can find an Automatic 'big bike' to get a full A group licence with Auto-Restriction.
I think it would qualify you to ride an old 1970's Moio-Guzzi Convert, or the two Honda-matic motorcycles they made in the 1970's the CB750 and CB400 'Auto's.!
Doing STANDARD bike tests on a twist and go? I would be dubious as to what twist and go's are on the DSA standard bike test list. Doesn't demand gears, but specs would deter many from being on the list as they need to be able to reach higher speeds, many twist and go's just don't, even if they are full 125's.
MOST people testing on twist and go, do so as 'Light-Bike' to ride 125 machines without having to fork out for repeat CBT every couple of years.
Hassle and expense; and limitation imposed by twist and go only; AND new licence laws coming in Jan 2013; for the sake of working a couple of cogs on two tests lasting approximately one hour, I do NOT see why ANY-ONE would want to do anything but the full, unrestricted test on a geared bike, even if it means renting a geared bike to do it on.
Means they can still ride twist & go, but wouldn't be banned from a crunch box C90, or even propper motorbike, with gears. 'Future-proofing' the situation for the sake of a very small effort now.
Modern gearbox technology with sequential shift systems; now 'on' high end production cars, and being messed with on bikes; with electronic control allowing various auto-semi auto or full manual gear selection; opens a can of worms.
IF it has selectable gearbox, is it a manual or an auto?
I believe the question has been raised; and the matter 'in debate' as far as law enforcement are concerned; BUT having unrestricted licence oblivigates the potential hassle.
Meanwhile; as others; much as I see the appeal of a super-scooter to a non enthusiast, and I have been an auto-convert in cars a very long time; having learned to drive in Canada aged 14 in one..... I am also pretty sure that an awful lot of folk that get them; stepping up from a commuter-scooter; get to a point where they realise that its pretty much ALL compromise for very little gain.
Comuter-Scooters; they have the dissadvantages of bikes; by way of road vulnerability; lack of weather protection etc. the design adds to that, sacrificing stability, balence and control for a little 'practicality' and convenience in use.... which is fine if you merely want to get to and from accross sub 50mph speed limit congested streets; the low running costs and convenience make it worth while.
Stepping up to a Super-Scoot; you gain a bit of comfory; loose a lot of nimbleness; gain weight; loose ecconomy; and with higher tax; lower mpg and higher running costs.... compromises start working against you....... gets to a point where you might as well almost ride a Gold-Wing... and that then begs the stuck in traffoic; might as well use a car!
AND, it would be rather gauling to have done tests on a 125 twist and go; got restricted licence and restriction lapsed; and THEN in a couple of years, thing 'sod it' I want a propper bike, and find that THEN under 2013 on licence system, you have to do full DAS on big geared bike to get back to where you could have been.......
But, end of the day; your life, your licence, if you think you'll NEVER want to ride a geared bike; then fine, go for it.
Like I said; I like auto's drive auto cars; cant see myself getting another manual; BUT wouldn't WANT an auto-only licence..... becouse even though I might never buy another manual.... NICE to know I CAN jump into any car, manual or auto and drive it; whether a borrow or loan or rental, for whatever reason........ ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 15 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
