Paint in to spray cans
Hex
Party Boy
PostPosted: 15:58 - 29 Sep 2011    Post subject: Paint in to spray cans Reply with quote
How do all, got some paint that I need putting in to some spray cans as have a couple of small bits i need to paint to match.
Anyone know where I can do this or am I on a hiding to nothing?
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
mad4it028
PostPosted: 16:06 - 29 Sep 2011    Post subject: Reply with quote
wouldnt know local to you but for me granvile autopaints do it, dont halfords mix paints? if so maybe have a word in there
sebastianw
PostPosted: 16:34 - 29 Sep 2011    Post subject: Reply with quote
https://www.grsuk.com/index.asp?docs/56.asp
Google......................
Snodvan
PostPosted: 17:31 - 29 Sep 2011    Post subject: Reply with quote
If you can beg/ borrow a small compressor then this is super kit
https://www.machinemart.co.uk/shop/product/details/diy-air-brush-kit-cab1h
I have not tried but I guess that for a small job you could rig up an air supply from an innertube + one of those cheapo (£5) tyre pumps
If you go a bit further then they do one with a can of propellant
https://www.machinemart.co.uk/shop/product/details/easy-to-use-airbrush-kit
Just what you want
Snod
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
Hex
Party Boy
PostPosted: 19:55 - 29 Sep 2011    Post subject: Reply with quote
Ohhh excelent, many thanks.
If i knew i was going to use it enough I'd get a little compresoor but its literally a cn or so job and thats it.
Snodvan
PostPosted: 20:27 - 29 Sep 2011    Post subject: Reply with quote
You will be surprised. Spraying (on a small scale) is easy enough and once you have brightened up the first couple of items you get 'hooked' and start thinking of other jobs which would look much better spray painted than hand painted.
I have a BMW F650 CS (the belt drive job) and the Rotax engines on those are painted and prone to the paint lifting with corrosion on the alloy casing
I scraped off the thick corrosion then soda blasted the main engine casing (soda blast = baking soda in a shot blaster gun = super surface preparation / cleaning on alloy with no damage) annd then sprayed the engine with Hamerite smooth silver. That is a near perfect match to the original. I used the £9 Machine Mart spray.
TimNorwich
PostPosted: 20:32 - 29 Sep 2011    Post subject: Reply with quote
So you just used Hammerite Smooth paint on the engine? What about the heat?
Snodvan
PostPosted: 20:49 - 29 Sep 2011    Post subject: Reply with quote
The Hamerite has been on now for near a year - no change ie copes perfectly well with the heat. However, note that the barrel & head were not sprayed, only the crankcase. It may cope on the barrel & head as well, I just do not know.
I sprayed about 5 thin coats and left each to dry off at least 4 hours with a gentle warm air blow from a 500W fan heater about 2-3 metres away
Snod
TimNorwich
PostPosted: 20:52 - 29 Sep 2011    Post subject: Reply with quote
Thats useful to know, always thought you had to use heat proof paint.
My engine casing could do with just that, I don't have the equipment to blast the engine though, I guess sand paper would give a half decent result, providing I work at it long enough?
Snodvan
PostPosted: 22:00 - 29 Sep 2011    Post subject: Reply with quote
So long as you have a compressor then the kit for soda blasting can be a VERY simple DIY job
https://www.garagenight.tv/diy-soda-blasting-build-your-own-rig-cheap/
I had a normal grit blaster (which was only about £15) so did not have to go the DIY route
The advantage of soda blasting - esp if you are cleaning up a carb or the like - is that when all is cleaned you simply wash the item with water and all the soda just dissolves. Baking soda (sodium bicarbonate) costs about £3 for 1 kg in most oriental supermarkets
Wear a mask when blasting - it tastes 'orrible
Snod
ZRX61
Victor Meldrew
PostPosted: 00:57 - 01 Oct 2011    Post subject: Reply with quote
Use Preval spray pots..
https://www.tcpglobal.com/spraypaintdepot/preval-paint-sprayer.aspx
They're not one night stands, they're auditions.
The last post was made 14 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 68.37 Kb
