need help with cyclone c11
swirlctw
PostPosted: 03:56 - 30 Sep 2011    Post subject: need help with cyclone c11 Reply with quote
I have a cy50-a and just got my cyclone c11 alarm system. I am having some issues with the remote start. I followed the instructions I do believe and when I hit the remote start on the key fob the switch comes on but it will not fire over any sujestions?
andy_uk
PostPosted: 06:37 - 30 Sep 2011    Post subject: Reply with quote
Is there an inhibitor switch ?
When you start it normally does it have to be off the stand, or do you have to pull a brake lever in?
swirlctw
PostPosted: 07:32 - 30 Sep 2011    Post subject: Reply with quote
No brake I can hit the remote and the switch will turn on but does not turn over I have to press the starter after and it will start
Roakusfm
PostPosted: 07:43 - 30 Sep 2011    Post subject: Reply with quote
Andy_UK
wooow, I do have the same problem on my beret motorcycle alarm. my suzuki gz125, in normal way, before you can start with his key, you have to pull clutch lever. but the alarm remote can not start but if i pull clutch lever then it wanted to start but it doesnt. because F1 indicator was flashing.
I hope someone can help you, so that, I also can solve mine or if I found solution then I will inform you as well. grrrrr Sad
The last post was made 14 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 38.57 Kb
