| james1988 |
 james1988 World Chat Champion
| growler |
 growler Traffic Copper
| james1988 |
| Benson_JV |
 Benson_JV World Chat Champion
 Posted: 22:04 - 28 Sep 2011 Post subject: |
Drilled will be clogged up by grain very very easily.
Also, it needs to face down, otherwise stuck mash will occur.
Looks good though otherwise.
The boiler, be careful with those youngs barrels...they can get very squidgy at boiling temp...you have been warned!
You might want to fit two elements, I find when doing 23L length brews that it takes an age to get to boil with two! God help ye if you want to do 10 gallon brews.
I would also make a copper cooler, the crash cooling helps aid the coagulation of proteins and this is what you want!
Anything else mate and I'm happy to help.
Edit: Also, even though you've insulated the mash tun make sure you insulate with blankets, don't wish to sound patronising but you want to keep it shweet at 67. ____________________ Willson - "If you go out on that CBR600 in the winter, you're going to do more miles on your side than on your wheels."
Previous Bikes: '96 Bandit 600, '96 GPz305 |
| james1988 |
| Benson_JV |
| james1988 |
 Posted: 09:41 - 29 Sep 2011 Post subject: |
I had a thought earlier, would wrapping the strainer in voile stop the mash getting stuck? I thought it would have the same effect as the boil in a bag way of doing things. I can then use the remaining copper piping to create a - albeit shitty - cooler. I'm on a bit of a budget unfortunately so I'm trying to do everything as cheap as possible.
As for the boiler, I was thinking of filling it from the hot tap first - it was 50c when I checked the other day - and then using the boiler to take it the rest of the way. Does the mash out lose much temperature?
I'm beginning to think that there is a lot more to this than I originally thought.
James
*Edit*
The tap on the boiler still hasn't sealed. Looks like I'm going back to the drawing board with this one.  |
| Benson_JV |
 Posted: 20:28 - 29 Sep 2011 Post subject: |
Probably not, with the weight of 5-6kg of grist pressing down on it I'd make sure to do it properly first time, could become more expensive otherwise.
Water from the hot tap, I've always heard you shouldn't really use that (although I can't think of a particular reason why not) but I always just use cold tap water. Make sure you use a campden tablet to kill the chlorine eitherway.
Mash out doesn't really loose much temp, I generally aim to mash out at about 75-78C.
If the boiler isn't sealing, I would personally go for a bigger/better boiler such as this one: (the one I have)
https://www.hopandgrape.com/public/detailv1.asp?itemcode=TEN20175450
They do say that they recommend you don't use them for boilers but that is just to cover their arses.
If you take a look over at www.jimsbeerkit.com/forum you'll see many many people (inc myself) use these.
That way you have more than enough room for a 5 gallon brew (you need around 30L to start with to end up with a 23L brew) and you can just about squeeze a 10gallon brew in. ____________________ Willson - "If you go out on that CBR600 in the winter, you're going to do more miles on your side than on your wheels."
| Ariel Badger |
 Ariel Badger Super Spammer
| Benson_JV |
 Posted: 21:27 - 29 Sep 2011 Post subject: |
There you go then.
I thought it was something like that but didn't want to sound like a twit if I was completely off the mark.  ____________________ Willson - "If you go out on that CBR600 in the winter, you're going to do more miles on your side than on your wheels."
| james1988 |
 Posted: 21:58 - 29 Sep 2011 Post subject: |
Thanks for the advice. I'll start over and do it right this time haha
I'm trying to think of something I could use a bastardised FV for. I really don't want to throw 10quid down the drain
James |
| Ariel Badger |
| james1988 |
| Ariel Badger |
| Benson_JV |
 Posted: 06:46 - 30 Sep 2011 Post subject: |
Seal it up with a tap! Then you have a FV with a tap.  ____________________ Willson - "If you go out on that CBR600 in the winter, you're going to do more miles on your side than on your wheels."
| defblade |
 defblade World Chat Champion
| james1988 |
| Berk |
 Berk Scooby Slapper
 Posted: 10:41 - 30 Sep 2011 Post subject: |
https://www.howtobrew.com/appendices/appendixD-1.html
Might be useful for you? I found it last night, inspired by this thread. I've had a quick skim and it seems to be a fairly comprehensive book.
Make sure to keep us updated with how you get on.  |
| james1988 |
| Benson_JV |
 Posted: 11:09 - 01 Oct 2011 Post subject: |
Looks perfect!
If you weren't so far away I'd happily lend you some of my equipment for the brew. But alas, money does not stretch to get myself that far.
But, I digress. It seems to be coming along quite nicely.
As I said, check out some of the stuff on www.jimsbeerkit.com/forum
Quite a lot of homemade AG setups on there. ____________________ Willson - "If you go out on that CBR600 in the winter, you're going to do more miles on your side than on your wheels."
| james1988 |
| Benson_JV |
| james1988 |
| Germ |
 Germ Trackday Trickster
| james1988 |
 Posted: 17:38 - 03 Oct 2011 Post subject: |
Thanks for that I'll look into getting one of those on the weekend and some more piping. The bedroom brewery is getting there
James  |
The last post was made 14 years, 170 days ago. Instead of replying here, would creating a new thread be more useful? |
