Engine Dies After 5 sec, fual leaking from air filler
nohackz
PostPosted: 19:15 - 30 Sep 2011    Post subject: Engine Dies After 5 sec, fual leaking from air filler Reply with quote
Hi, I have just bought a 110cc pit bike if a friend but it needed a little work, iv just replaced the Carb, throttle cable and throttle assembly, so now the bike starts but for all of about 5 seconds then it dies out, then I noticed that petrol was leaking from the air filler, I would really grateful for any help [/b]
temeluchus
PostPosted: 19:31 - 30 Sep 2011    Post subject: Reply with quote
your carb is flooding the motor.
take the bottom of the carb off check the float moves freely, then pop the float off and make sure the float needle and iits seat are clean. the needle should have a smooth conical tip with no ridges or shouldering.
reassemble the needle and float then check the float height. this varies carb to carb, but around 15-20mm is a start.
You didn't by any chance connect the fuel line up to the carb breather, did you?
I only ask because I've, uh... seen it done. Shifty
temeluchus
PostPosted: 19:32 - 30 Sep 2011    Post subject: Reply with quote
that too lol
Ariel Badger
PostPosted: 19:52 - 30 Sep 2011    Post subject: Reply with quote
What is all this "Skim words" stuff does it do spark plug as well?
Ariel Badger
PostPosted: 19:53 - 30 Sep 2011    Post subject: Reply with quote
Ok it does, let us try it with condom and dildo.
nohackz
PostPosted: 19:59 - 30 Sep 2011    Post subject: Reply with quote
Sorry miss read the post, my petrol pip is on right, although there is another pip witch I'm not sure of its purpose? Is there any tutorials on adjusting the float as I.haven't got a clue.
PostPosted: 10:41 - 01 Oct 2011    Post subject: Reply with quote
The carb should have two lines coming off it: a fuel line and a breather line. What I (still) suspect is that you've plugged the breather line into the fuel tap.
It's quicker to sort that than to disassemble the carb and check the float - try the easy stuff first.
The last post was made 15 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 56.05 Kb
