| Tom85 |
 Tom85 Borekit Bruiser
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 20:39 - 30 Sep 2011 Post subject: |
Either or really.
Whatever oil you choose it's more important to use one of the correct weight and change it regularly.
Personally I'd also add make sure it's a bike specific oil.
Oil is like tyres, everyone has their own personal preference.
Advantages and disadvantages here;
https://en.wikipedia.org/wiki/Synthetic_oil#Advantages
IMO for road use just chuck some decent semi-synth in of the correct weight and use the saving you've made over fully synth to put towards your next oil change. Also especially with the C1H make sure you pour some oil into the new filter before you attach the bike. It's good practice to do it on all bikes (and I always have), however some claim it can cause issues on the C1H if you start it with the filter empty after an oil change. ____________________ My Flickr
| Dr. Quack |
 Dr. Quack Could Be A Chat Bot
| Wafer_Thin_Ham |
| Dr. Quack |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 20:47 - 30 Sep 2011 Post subject: |
Nabbed from wiki regarding synthetic oils.
Advantages
The technical advantages of synthetic motor oils include:[citation needed]
Measurably better low- and high-temperature viscosity performance at service temperature extremes
Better chemical & shear stability
Decreased evaporative loss
Resistance to oxidation, thermal breakdown, and oil sludge problems
Extended drain intervals with the environmental benefit of less oil waste.
Improved fuel economy in certain engine configurations.
Better lubrication during extreme cold weather starts
Longer engine life
Superior protection against "ash" and other deposit formation in engine hot spots (in particular in turbochargers and superchargers) for less oil burnoff and reduced chances of damaging oil passageway clogging.
Disadvantages
The disadvantages of synthetic motor oils include:
The lower friction[citation needed] may make them unsuitable for break-in (i.e., the initial run-in period of the vehicle), where friction is desirable to cause wear. However, improved engine-part machining has made break-in less critical than it once was. A select few cars (in general turbo- or supercharged) are factory filled with synthetic oil, usually to help minimize high-temperature oil degradation issues.
Potential decomposition problems in certain chemical environments (predominantly in industrial use.)
Potential stress cracking of plastic components made of polyoxymethylene (POM) in the presence of polyalphaolefin (PAO).
Synthetics do not hold lead in suspension as well as mineral oil, thus caution is advised when the engine is run on leaded fuel,[citation needed] which is still commonly used in aviation (avgas).[16]
In July 1996, Consumer Reports published the results of a two-year motor oil test involving a fleet of 75 New York taxi cabs and found no noticeable advantage of synthetic oil over regular mineral oil. In their article, they noted that "Big-city cabs don't see many cold start-ups or long periods of high-speed driving in extreme heat. But our test results relate to the most common type of severe service - stop-and-go city driving." According to their study, synthetic oil is "worth considering for extreme driving conditions: high ambient temperatures and high engine load, or very cold temperatures." [17]
Synthetic oils are not recommended in automotive rotary engines.[18] ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Wafer_Thin_Ham |
| Kickstart |
 Kickstart The Oracle
| Fizzer Thou |
| Wafer_Thin_Ham |
| Wafer_Thin_Ham |
| Tom85 |
| sickpup |
 sickpup Old Timer
| von1papen |
 von1papen Spanner Monkey
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 12:46 - 01 Oct 2011 Post subject: |
I've previously only used Motul 10w40 bike specific semi-synth... if only because the original owner of my first bike used it, and it seemed to be doing the job so I didn't see a need to change.
However I've recently had to do an oil change on the Bandit while money was tight, so got some cheapie supermarket branded 10w40 semi synth (car oil), and thanfully the bike seems to be running just fine on it. ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| weasley |
 weasley World Chat Champion
| sickpup |
 sickpup Old Timer
| weasley |
| Dr. Quack |
 Posted: 21:36 - 01 Oct 2011 Post subject: |
| tahrey |
 tahrey World Chat Champion
 Posted: 15:58 - 02 Nov 2011 Post subject: |
| sickpup wrote: |
I think it highly unlikely that a company would claim that their oil only met an obsolete standard rather than a current one assuming it did. |
I know it may not be an entirely transferable concept, but I can only point to examples in other markets, such as Intel de-rating some of their higher speed CPUs (that cost the same to make as the cheaper ones, but have a lower chance of successfully passing QC; all they had to do was print a different rating label on top because the actual speed setting was done by the motherboard jumpers) because the market demand for the mid-range ones (costing, say, 2/3rds the price) was so much higher they actually made more money that way.
Apparently this is the story behind certain supermarket ownbrands as well. Actually bigger name products but with the serial numbers filed off and, e.g. a little extra salt (or water, or whatever) put in to make it taste a bit different and seem lower quality. Same production cost, lower selling price and margin, but because of a much greater volume of sale actually well worth the effort.
The weirdest thing about all this oil controversy (which is bizarre to someone who started out in cars...) ?? I haven't yet bought or tried fully synth in my bike because the people on the sales desk in service centres won't sell it to me. So far I haven't found it on the shelf, but ask if they have any of brand X but in the fully synth type. They axe me what my bike is, and following the answer damn near get into a red faced argument over whether or not I need it, want it, should be using it, and I just give up and buy the semi, even though I think the full synth may be beneficial because of the pasting my engine tends to get, often right from cold...
I'll probably order it off the net next time, though I normally wouldn't figure on buying such things unseen (or having heavy bottles of liquid posted) is a great idea. And probably get into an argument with the online shopping basket.
Jeez. Look. If it works for you, it friggin' works, OK? And don't we have a right to experiment? It's being sold for bikes of vaguely similar construction from the same manufacturer, and if it all goes tits up, I'll just drain it and run a bottle of engine flush through... |
| Souleh |
 Souleh Trackday Trickster
 Posted: 16:19 - 02 Nov 2011 Post subject: |
The only noticable difference is the semi synth motul is a dingy colour wheras the fully synth is an awesome red.  |
The last post was made 14 years, 339 days ago. Instead of replying here, would creating a new thread be more useful? |
