Glasses fogging inside lid
FBSF
PostPosted: 14:52 - 03 Oct 2011    Post subject: Glasses fogging inside lid Reply with quote
Ok, it's getting near that time of year again when I start my futile search for a way of getting the 10 miles home without getting so fogged up I can't see where I'm going.
I've got a fog city, and this works for the visor 95% of the time. My glasses are a little bit more of an issue. Can't wear contacts or have surgery due to medical reasons, so I'm stuck with them.
Now, in the dry, this ain't a problem. Crack open the visor a bit and job's done.
In the wet though, even if I only open it to the first click on the visor, the rain runs down the inside, meaning I can't see through that.
Any suggestions, or is it just one of those things...
kramdra
PostPosted: 15:40 - 03 Oct 2011    Post subject: Reply with quote
Breath deflector. Some helmets have them built in. Mine doesnt so I have a slightly uncomfortable thing sitting inside it, but it works
downside is it covers your mouth and nose, so any conversations with lid on are quite a bit more difficult to understand...
but breathing keeps your neck warm Smile
Thelostone
PostPosted: 15:52 - 03 Oct 2011    Post subject: Reply with quote
Would it be rude of me to correct the previous post to say "a well designed breath deflector"?
My previous helmet had one that kept my breath off the visor but deflected it back onto my glasses. Removed it and the problem was considerable lessened.
FBSF
PostPosted: 15:54 - 03 Oct 2011    Post subject: Reply with quote
Had thought about those, but most seemed to direct the steam upwards rather than downwards. Might see if I can get a couple of neoprene masks and superglue bits together to make something that works, if nothing else comes up...
Bendy
Mrs Sensible
PostPosted: 16:01 - 03 Oct 2011    Post subject: Reply with quote
Do you put anti-fog stuff on your glasses? Proper spray or just fairy liquid should help.
Have you experimented with the vents in your helmet?
neil.
PostPosted: 16:30 - 03 Oct 2011    Post subject: Reply with quote
Get a Foggy Mask. Thumbs Up
FBSF
Yeah, the vents don't seem to make much difference (it's an HJC AC-10).
I was toying with the idea of running a thin strip of silicone sealant around the top of the visor opening on the lid, and the top of the visor, to try and stop the drips coming down. Not sure if silicone will damage the lid tho...
FBSF
PostPosted: 16:31 - 03 Oct 2011    Post subject: Reply with quote
do they work with glasses, most masks seem to sort the visor, but at the expense of pushing the steam upwards...
neil.
PostPosted: 16:35 - 03 Oct 2011    Post subject: Reply with quote
I find they are okay with my glasses, you just have to faff about when you're installing it to get the fit perfect.
Edit: Contact lenses are really the best solution but get expensive - which is why I went back to glasses.
stonesie
PostPosted: 17:45 - 03 Oct 2011    Post subject: Reply with quote
I used FogTech wipes last winter and they worked brilliantly, lasted 4~5 days before they needed another wipe over and each wipe lasted me about 3 weeks if it was put back in its packet and sealed up Thumbs Up
PostPosted: 17:54 - 03 Oct 2011    Post subject: Reply with quote
Cat Crap no-wait-it's-a-brand-name-don't-troll-rate-me-bro.
Ted
PostPosted: 17:59 - 03 Oct 2011    Post subject: Reply with quote
I've got a breath deflector in my lid, and I have to shape the bit of metal at the top of it to make sure it sits against my nose every time I put my lid on (if my specs are likely to fog up), with that and keeping the visor open a bit, I've not had an issue so far.
waffles
PostPosted: 18:22 - 03 Oct 2011    Post subject: Reply with quote
Sounds gross but spit on the lenses of your glasses, wipe it round then clean off. Stops things fogging up temporarily Thumbs Up
kramdra
PostPosted: 18:24 - 03 Oct 2011    Post subject: Reply with quote
The one Im talking about works, your breath all goes downwards. It basicly sits around your nose and cheeks, and has velcro attached to the inside of helmet foam.
And I leave it in the helmet, occasionally need to adjust its position, but its not an extra item I have to put on each time.
it might not be as comfortable for the speccys as it sits on your nose, probably just below where your glasses sit.
Ted
PostPosted: 18:28 - 03 Oct 2011    Post subject: Reply with quote
Same as mine, although mine is a removable bit that came with the lid. But sometimes the tip of it flattens out, so I have to pinch it back to the shape of my nose, if that makes sense!
Diddylord
PostPosted: 18:57 - 03 Oct 2011    Post subject: Reply with quote
I used to have a similar problam with my Glasses all the time had to open visor when stationary. i don't seem to get it at all sine i change glasses to Oacklys, there not cheap but they are brilliant on the bike ans they do not have the bit the drops down behind the ears so they go in a helmet really easily and as I say they seem to have fixed the steaming up problem.
Recluso
PostPosted: 18:58 - 03 Oct 2011    Post subject: Reply with quote
I believe, although I could be mistaken, that you can also have glasses coated at the opticians to stop them misting up.
No harm in popping into your local and asking though Smile At the moment I just grin and bear it for 10 seconds with my visor up until it clears. But I'm in slacker mode at the moment Very Happy
'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900
waffles
PostPosted: 19:03 - 03 Oct 2011    Post subject: Reply with quote
stonesie
PostPosted: 19:30 - 03 Oct 2011    Post subject: Reply with quote
Deja vu, Waffles?
Tenko
PostPosted: 19:55 - 03 Oct 2011    Post subject: Reply with quote
Nothing works for me - I have to ride along with the visor up then turn my head from time to time to ged rid of the rain droplets...
bobbertandsam...
PostPosted: 23:31 - 03 Oct 2011    Post subject: Reply with quote
I got a little tin of Bob Heath anti fog spray last time I was in J&S and it works a treat, much cheaper than the fog city wipes.
Its never easy
FBSF
PostPosted: 09:09 - 05 Oct 2011    Post subject: Reply with quote
Ok, have pretty much solved my problem.
How?
Well, you know some helmets have a chin-curtain to stop draughts? It was that same thing that was causing the steam to get caught and not exit stage south.
I ripped the bloody thing off this morning when I figured it could be causing the issue and bingo. All the way to work with a clicked-closed visor and no steaming.
So if anyone else gets a similar issue, and has one of those chin-warmers, rip it out!
The last post was made 14 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 113.66 Kb
