| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| neatbik |
 neatbik World Chat Champion
 Posted: 09:25 - 04 Oct 2011 Post subject: |
I have a set of Oxford ones, had them for 4 years and have never let me down.
| Dilyan |
 Dilyan World Chat Champion
 Posted: 09:27 - 04 Oct 2011 Post subject: |
A tat off-topic: I'm considering heated gloves instead. IMO they seem to slow down the arthritis Warming up your palms won't help your knuckles  ____________________ Current: 2007 VFR800; Ex: 2001 YZF600R Thundercat
Škoda Octavia (yes, a taxi driver) |
| Marmalade |
 Marmalade World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| G |
 G The Voice of Reason
| Kickstart |
 Kickstart The Oracle
| DrDonnyBrago |
 Posted: 11:46 - 04 Oct 2011 Post subject: |
How long do normal (i.e. not heated) grips last before they wear out, I've never had to replace any?
I'm tempted by the symtec because it means I can replace the grips without having to shell out £60 again. But if the heating element/wiring etc wont outlast the rubber grips themselves then I may as well save some effort and fit the oxfords.
Also there seem to be several types of oxford hot grips, what is the difference between the original and sports? I'm not concerned about the appearance but I intend to fit them to a CBR600f.
EDIT: One more thing, are ROXTERs (ebay clicky) the same as oxfords but rebranded?
| The Artist |
 The Artist Super Spammer
| stinkwheel |
 Posted: 12:24 - 04 Oct 2011 Post subject: |
Mrs. stinkwheels symtec ones are still going strong. If/when they go I'd expect them to go at the wire going to the throttle side which sees a lot of movement. I made sure to put a nice wide loop in the wire to help with this and taped that end of the pad down securely.
As far as I can work out though, they are the same as those cheap chinese ones on ebay. Frankly, for £3.99 delivered, they've got to be worth a punt. The only real difference is that the symtec ones have high and low settings which is achieved by having them in series on low and paralell on high. To do this you'd need a three position switch rather than the one they come with.
If Mrs. stinkwheels ones fail, I'll just replace the pad with a chinese one, just be a case of popping the grip off, sticking the new pad on and plugging it in. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| JonE |
 JonE Scooby Slapper
| DrDonnyBrago |
 Posted: 13:16 - 04 Oct 2011 Post subject: |
Hmmm, I am mighty poor atm... think I might just go for two sets of the chinese ones.
If the first set are reliable then I'll position the spare set in my seat to keep my balls warm .
Is there anyway to bolster up the wires on the chinese ones to stop them breaking? How many miles have you had with yours fitted artist? |
| The Artist |
| Marmalade |
| Beelzebob |
 Beelzebob Spanner Monkey
| swampy |
 swampy World Chat Champion
 Posted: 17:45 - 04 Oct 2011 Post subject: |
I've got Roxters on my Viffer. Warm as toast, and wont turn on unless there's enough juice in the battery to run them.
Only probs with mine is the control has up and down buttons (like the one's on a ZX81) rather than a dial, which makes it a bit tricky to use with gloves on.
Think they are re-branded Oxford from the (limited) research I've done.
Mild threadjack, but does anyone have any tips for adhering them to the bars ?I was thinking hairspray, but wondered about flammability issues... ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
| P.addy |
 P.addy Red Rocket
| The Artist |
| P.addy |
 P.addy Red Rocket
 Posted: 17:55 - 04 Oct 2011 Post subject: |
This year im going for a set of Tucano Urbano muffs, G's looked fantastic and seem roomy enough in there.. Plus possibly symtec stuff...but it will be when I have some spare funds... muffs are only £38 so combine with cheap heaters, toasty winter
Mr Moss, do they get pretty warm given there is no temp control? |
| The Artist |
| Beelzebob |
 Posted: 18:11 - 04 Oct 2011 Post subject: |
Plus - see Stinkwheel's handy guide on wiring up accessories with a relay so you can't forget to turn em off - thus sparing winter flat battery woes. ____________________ '09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard" |
| The Artist |
 Posted: 18:13 - 04 Oct 2011 Post subject: |
That is the complicated way of doing it. The ultimate Artist bodge tip 1.
Wire the grips into the brake light circuit or similar. Therefore using the ignition relay rather than wiring your own in. |
| Beelzebob |
| The Artist |
| ms51ves3 |
 ms51ves3 Super Spammer
The last post was made 14 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
