| tripod.psend |
 tripod.psend Derestricted Danger
 Posted: 17:21 - 04 Oct 2011 Post subject: |
In answer to your query, it is a single wire AC generator. When the lighting is on it splits the output between the horn and the lights. When it's off, the horn getts the full whack of the 2.5A AC it is capable of producing.
If you wanted to rectify it you would need to use a two wire selenium rectifier.
This is a total waste of time, effort and money because this bike produces nothing like the output needed to power even one off your list of battery, brakelight and flashers. Rectifying removes half the power straight away and there are other losses inline leaving you with (ballpark) 1A DC output.
Not much you can do with a 1A DC charging system. You still have to power the headlamp and horn from that. It would be straining the boundries of what could be done even using the most modern and cutting edge LEDs.
The headlight on this bike is NOT to see in the dark with, it's to be seen in the dark by.. If you're lucky. I would not advise using it in the dark anywhere there aren't streetlights. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| tripod.psend |
 Posted: 17:58 - 04 Oct 2011 Post subject: |
Looks like they are using the headlamp output to charge the battery when the headlight is off and the horn output to power the brake light.
The latter should work ok as long as you don't want to sound the horn and brake at the same time. The former I suspect doesn't work very well. Having had one of these bikes myself, I wouldn't like to try using the indicators while the headlight is on.
By all means try but it really isn't going to output enough to run DC lighting. You'll notice they've fitted a 2Ah battery which matches the draw for the lighting circuit. With the lights on, it won't be charging (at all).
You may also notice they've dropped the taillight to a 2W bulb on that model! For reference, that's the same power bulb as I have in the instrument panel on my VFR.
Have a crack. Just don't be disappointed when the headlight goes on and off with the flashers.
EDIT: To clarify, it's one coil. Look at the earth (singular). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| tripod.psend |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 18:39 - 04 Oct 2011 Post subject: |
.in theory you could convert it to a dc lighting arrangment but you'd get no benefit as bulbs are very happy with ac and having the coils all on,or wired in, all the time would affect the engines power output slightly,as the coils would be 'on' all the time .
you'd do far better replacing the indicator /side/brake light bulbs with LED ones and finding a better replacement headlamp bulb.many cycles are fitted with much better lighting thesedays.
The three coils all share the same earth ,and each coil produces a different amount of juice,its NOT three phase,ITS A SINGLE COIL with 'taps' to take off less than the full power. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| tripod.psend |
| unitynotsocri... |
 Posted: 19:31 - 04 Oct 2011 Post subject: |
yep i think thats right.the first 2 coils are lower output settings,more coils =more power.if you did go through the trouble of converting to dc then the third tap would be your 'charging coil.' remember though that many small bikes using batteries still have their lighting power coming from seprate lighting coils in the generator.
because the output on your scoot is so small ,i can't see any advantages in changing any of it except for LED indicators and brake/side/lights.These would just reduce the power needed and LED indicator bulbs may help your indicators to flash normally at traffic lights without having to rev it a bit.If its a saftey/visibilty issue then I'd just wear a flourescant pink jacket or buy some mountain bike lights for extra saftey. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| tripod.psend |
| finpos |
 finpos World Chat Champion
| unitynotsocri... |
 Posted: 23:10 - 04 Oct 2011 Post subject: |
the coil is basically one long wire with wires coming off it called taps.The taps allow the selection of different power outputs depending on wether the head/sidelights are on or off.
You may be better using a mountain bike LED headlight for saftey and as a dayriding lamp,or the pink flourescant jacket.for all the messing about involved you could restore another 50cc goped. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Teflon-Mike |
 Posted: 06:42 - 05 Oct 2011 Post subject: |
With that small a generator; why not just 'give up'; use a battery; but forget trying to charge it off the engine, just go 'total loss'.
How long do you ride for, in one go?
Works on push bikes, and this isn't much different.
Just have two batteries; one on a charger on a window sill; one on the bike, and swap them each time you go out.
Use bikes genny for headlamp & horn, as standard; then go 12v for tail & stop and indies if you want them; again on LED bulbs, with solid state flasher, for low consumption & long battery life. Use LED 'side' light on 12 TL circuit, to augment headlamp at low revs..... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| tripod.psend |
| unitynotsocri... |
 Posted: 13:00 - 05 Oct 2011 Post subject: |
because the coil outputs AC,or alternating current,the voltage swings between - 3v and + 3v. O v is a reference to a dc voltage.
When you put a diode(a rectifier) in the circuit the voltage becomes DC so a -3v +3v coil would output + 3v DC
still reccomend the flourescant pink jacket or mountain bike lamps though,or wire it as standard and if you sell it in twenty years time it will get a better price! ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
 Posted: 16:44 - 05 Oct 2011 Post subject: |
The coil itself consists of a single, crescent shaped steel block with a length of copper wire wrapped round it. There are three branches coming off this wire at different points along its length.
The rotor magnets spin round it and generate an alternating current in the coil. The amount of current depends on the length of wire.
It's one coil, one phase. To get a different phase, you'd need another coil mounted in a different position. A three phase system has three seperate coils mounted 120 degrees apart with a common earth.
| unitycrippledatmo wrote: | because the coil outputs AC,or alternating current,the voltage swings between - 3v and + 3v. O v is a reference to a dc voltage.
When you put a diode(a rectifier) in the circuit the voltage becomes DC so a -3v +3v coil would output + 3v DC |
Err. It's 6v AC. That means it's alternating between +8.5v and -8.5v. Rectified it'll put out (an optimistic) 6V DC. Use a 6v battery and 6v bulbs.
If you want to know why, google for: rms ac voltage
I'll reiterate, I believe you are pissing in the wind tryng to get anything more out of that bikes charging system than it already produces. It can barely light up the headlamp as it is.
If you want to try and charge a battery using such a piddling coil, you need to use a two pole silicone diode (such as fitted to many small bikes of that era). Wemoto do a pattern Honda one for just over a fiver. Connect this before the battery. I would try for a 6v 2Ah battery (or maybe even smaller). You will not need any form of voltage regulator, the battery will damp down any excess in the unlikely even of it producing more than 6v.
I'm not going to suggest how to connect it to the coil because I don't believe it'll work so pick one and have a bash but those are the correct componants for that type of charging system.
I would strongly suggest leaving the head and tail light as direct lighting. It is just possible you'll get enough charge into a battery to power some very small LED flashers and brake light.
EDITED TO REMOVE ALL THE SPURIOUS, IRRELEVANT AND CONFUSING SKIMRESOURCES HYPERLINKS ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| tripod.psend |
 Posted: 12:25 - 06 Oct 2011 Post subject: |
| tripod.psend wrote: |
stinkwheel, you say it's 6v AC. That means it's alternating between +8.5v and -8.5v.
I cant mentally understand this because surely that would mean it is making +17V full in each direction which would blow the 6V bulbs it has. |
No.
Fuck.
What do they teach kids in school these days?
Year 8 physics lesson.
The voltage is how hard the electricity is being pushed through the wires. The current (in amps) is how much electricity is being pushed. The power (Watts) is a function of the current and the voltage and indicates the amount of work the electricity is doing.
So imagine you had a hosepipe with a pump on the end instead of a wire. The amount of water is the current. How hard it is being pumped round is the voltage.
With DC, you would be pumping water out of a bucket, through the hose and back into the bucket. The pressure you're pumping it at would be your 6V.
With AC, you would have a pump on each end of the hose, you pump the water from one end to the other, then pump it back again. The maxiumum pressure it reaches would be the equivalent of + or - 8.5v.
It would never make the voltage equal 17v because it is going in one direction, then the other. The bulb doesn't care what direction the voltage is going in, it just cares how much there is.
A bit more sciency (maybe year 10). If you draw a graph of the AC power in that circuit, plotting voltage against time, you'll get a sine wave centred on the zero axis and peaks at + and - 8.5v. The average voltage is zero because there is as much positive as negative. If you just look at the positive side (so going from zero to +8.5 and back again), the average voltage will work out as being +6V. This is called the Root Mean Square (rms) voltage and is how AC is measured.
For a standard sine wave AC, the rms is the peak voltage multiplied by the square root of 2 (that's geometry of a curve)
It's the same in your house. The power at your socket is 230v AC. That means it fluctuates between + amd - 325V.
Now, you're going to rectify it by fitting a diode that only allows electricity to flow in one direction. You now only get the positive voltage. The peaks have a maximum of +8.5v. They average out at +6V rms. This is called half-wave rectification.
Two pictures, one showing normal single phase AC, the other showing it half-wave rectified. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 Posted: 13:49 - 06 Oct 2011 Post subject: |
I thought of a better analogy.
Driving a car.
The road is the wire, the car is the current, the engine is the generator and the velocity of the car is the voltage. The power is the size of the car multiplied by its velocity
DC would be driving the car forwards at a steady speed round in a circle.
AC would be driving the car forwards round the circle, coasting to a halt then driving it in reverse, stopping, driving forwards etc.
If I drive the car up to 10mph and stop then reverse up to 10mph and stop. My maximum velocity was + or - 10mph. My velocity was zero, I'm back where I started. My rms speed (assuming constant acceleration and deceleration) was 7.07 mph. There is no way I could ever be doing 20mph.
So driving up to 10mph then reversing at 10mph would be the equivalent of driving in a straight line at 7.07mph. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| unitynotsocri... |
 Posted: 20:15 - 06 Oct 2011 Post subject: |
thanks stinkwheel,
apoligies tripo.psend for my appalling maths.. +6v it is.If you need your house rewiring call me in a year! ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| tripod.psend |
| neil. |
 neil. World Chat Champion
 Posted: 09:13 - 25 Oct 2011 Post subject: |
I worked it out by combining the wattage of the head and tail lights. I'm aware it is only just capable of lighting those up when you rev the bottom off it so I took that as maximum output. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| tripod.psend |
| tripod.psend |
 Posted: 09:51 - 25 Oct 2011 Post subject: |
So does anyone know a correct way to measure the maximum current output from the coil/flywheel??
I'm scared of blowing the coil if I just connect from output wire to frame.
Would a large watt 6V bulb show the maximum current. As it would not draw anymore current as the wattage is too high for the bikes coil/flywheel. Would this be the max current output of the coil/flywheel.
Well if it doesn't fully light them then at low revs it would show the max current output. But I want to test it to the max.
The last post was made 14 years, 332 days ago. Instead of replying here, would creating a new thread be more useful? |
