| deleted111 |
 deleted111 World Chat Champion
 Posted: 21:38 - 05 Oct 2011 Post subject: Keys don't want to stay in the ignition |
Evenin' all,
About a week ago, I was riding to work and the keys decided to fly out of my ignition at about 50mph. Bike in question is a 1999 CG125. I did a u-turn, picked the keys up (after a few minutes of scanning the road for a wemoto keyring), put them in my pocket and continued on my way to work.
When I got to work, I pulled the keys out of my pocket, put them in the bike, turned the ignition off and walked into the office. Figured it was something I could look into that evening.
Anyway, I noticed they were loose in the barrel, but they hadn't flown out of the ignition since, until tonight.
Has anybody else had this happen before? Is there anything I can do to repair the barrel (if there's anything wrong with it? )
Just thought I'd ask before I look at new ones.
Many thanks,
Steve. |
| Kwaks |
 Kwaks I'm not a fast rider
 Posted: 21:43 - 05 Oct 2011 Post subject: |
seen this before on a CG, think of it as a safety feature,you can only be bike jacked once if you keep the ke3ys in your pocket ____________________ Fallen Angel "Nae sniffing my seat now!!!!! "
www.cliqueycuntsmcc.co.uk
I AM NOT A FAST RIDER!!!!!!!!! |
| yambabe |
 yambabe World Chat Champion
 Posted: 22:24 - 05 Oct 2011 Post subject: |
Just get something that you can loop over the mirror so if they come out again at least they stay attached to the bike! ____________________ Sod falling in love, I wanna fall in chocolate.  |
| Dan79 |
 Dan79 Scooby Slapper
| 5headh |
 5headh Renault 5 Driver
| Purplepill |
 Purplepill Trackday Trickster
| deleted111 |
 Posted: 15:48 - 06 Oct 2011 Post subject: |
Glad to know I'm not the only one with this issue!
I don't have a killswitch (kickstart model) but I've been leaving the bike running and taking the keys out of my pocket to turn it off whenever I get somewhere. T'is but a mild inconvenience at the moment.  |
| Poseidon |
 Poseidon World Chat Champion
| Freaky_1 |
 Freaky_1 Nova Slayer
 Posted: 21:07 - 06 Oct 2011 Post subject: |
lock (ign in this case) wafers or pins do tend to get gunked up just like most any other part of a bike or car. The difference is that you think to clean most other parts.
Aerosol carb or brake cleaner (easiest if it's got the tube nozzle), your least worn out key and some lock cylinder lube will fix many up right easy (though not all, some have gone too far).
Think of all the little pieces of grit that are going to end up in a bike lock cylinder (switch) over the years. Add that to the remains of it's most recent lube (usually what came from the factory) and you get a nice abrasive putty that sticks pins / wafers as well as grinds everything down.
DISCONNECT earth from battery!
If it's a vertical lock cylinder, it's often best to just pull it if it's not such a task. Otherwise, test the vertical ones to see if they drain properly with a quick shot.
Spray in cleaner (if it's not vertical, try to get it situated to drain back out the key slot).
Work least worn key in and out of slot a couple times. (note the crud on the key after)
Repeat the process until the key starts to come out clean.
Then let stand for two hours to dry, and go back with the lube.
On bikes that tend to actually get used, it's best to just clean the lock cylinder once or twice a season.
Former locksmith (don't have the patience for dealing with the public in my second youth), so use it if you care to or not if you don't.
Also, if you only have one key for anything, get another made and put up somewhere to replace a badly worn one as it's useless to trace from a worn key (you only get another loose key).
HTH |
The last post was made 15 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
