Bost Bike
TheSmiler
PostPosted: 11:56 - 07 Oct 2011    Post subject: Bost Bike Reply with quote
Was going to go the garage this morning for new tires and sort out the indicators but have developed two main problems the first is constant flooding of the engine when I left the garden (working perfectly in the garden).
The second is when I managed to get it going along the street it wouldn't go any more than 10mph. So just had to push it about 25 houses to get it home.
Any idea what could be the cause of these problems.
shereen
PostPosted: 11:58 - 07 Oct 2011    Post subject: Reply with quote
I think your bike might be broken. Thumbs Up
pepperami
PostPosted: 12:00 - 07 Oct 2011    Post subject: Reply with quote
I would possibly look to see if the main jet has fallen out of it`s thread, or is the float getting stuck?
Just a couple of ideas?
TheSmiler
PostPosted: 12:02 - 07 Oct 2011    Post subject: Reply with quote
After leaving the garden thats kinda weird though it was starting perfectly before I got onto the road.
TheSmiler
PostPosted: 13:04 - 07 Oct 2011    Post subject: Reply with quote
Thanks for the idea pepper I will see If I can get to it when it stops chucking it down with rain.
Thread update managed to start it normally but now after I turn the engine off and try to start again it sounds flooded and not starting compared to not starting before at all.
PostPosted: 13:16 - 07 Oct 2011    Post subject: Reply with quote
Yup, my thoughts too. Have you been fiddling with the carb recently?
Or, have you put your upside-down head on and are flipping a flippy choke the wrong way? I ask because I've done it myself after telling dozens of other owners which way to flip it. Doh!
What kind of bike is it?
TheSmiler
PostPosted: 13:25 - 07 Oct 2011    Post subject: Reply with quote
It has been left alone for about a week I haven't messed with any of the carbs at all or anything on the bike apart from the battery which is back to normal. The choke is the pull kind and I'm doing it correctly I believe well I hope Embarassed
The bike is a Honda Cb125
Teflon-Mike
tl;dr
PostPosted: 23:27 - 09 Oct 2011    Post subject: Reply with quote
Betcha left petrol switched off too.
Your float needles will be sicking due to evaporation from the float bowl.
Common problem if you let bike 'stand'.... especially so cantankerouse little Super-Dreams, with a pair of PD24 Carbs!
NOW!
Refer to Haynes.....
THEN remember your tutorlidge under expert Teflon guidance.
HOW MANY effing times did we take them float bowls off to clean, swap or otherwise effect change to get carburation sweet?
SURELY you haven't forgotten already!
Floats, we dropped numerous times without even taking carbs off, just the four screws under the float bowl.
If the float bowls have firred up though, probably be worth pulling main & idle jet & emulsion tube; and cleaning gently with tooth-brush & deturgent; they as tiny holes in emulsion tubes tend to be the first to fir up with evaporation deposits.
ALSO.... phenomina of the model, Snowies and Number five AND Number two all do it.... after any time left, they wet themselves a bit from the float bowl vent, until the float needles been washed and the float bowl gasket swells.
Roger; its a Red 125 Super-Dream, with custom graphics, and alarm LED set into the speedo housing; he has a pull for 'on' choke knob by the speedo....
.............................and with the carburettors properly set up and balanced, it USED to do a GPS checked 70mph two up on the flat!
TheSmiler
PostPosted: 01:27 - 10 Oct 2011    Post subject: Reply with quote
NOW!
Thanks for the reply mike I can honestly say I left the fuel at the on position Embarassed
I understand my problem now and will have a look at it on tuesday get it sorted, next time im ill I will go out and turn it over twice a day. Also she will get up to speed easily I think she is just in a mood with me at the moment for when I was ill. Wait till I get her back up and running she will purr again and enjoy university as well as a nice run down to see you at a weekend Wink
The last post was made 14 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 68.28 Kb
