soaking new clutch plates?
pepperami
PostPosted: 11:56 - 07 Oct 2011    Post subject: soaking new clutch plates? Reply with quote
What are the mighty BCF sage`s thoughts on this one?
Can you put new clutch plates straight in or is it a case of they must be soaked in oil before they are put in ?
I seek your advice Thumbs Up
Fizzer Thou
PostPosted: 12:05 - 07 Oct 2011    Post subject: Reply with quote
It is common practice to soak them in oil overnight.I have always done this,but with workshop times being limited there must be times when this is not done.
Always have a 'Plan B'
PostPosted: 12:15 - 07 Oct 2011    Post subject: Reply with quote
Never done it, not had a problem. I think it is an old wives tale TBH.
MickC
PostPosted: 12:24 - 07 Oct 2011    Post subject: Reply with quote
Never done it to mine either - never had a problem
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
pepperami
PostPosted: 14:18 - 07 Oct 2011    Post subject: Reply with quote
Well I put them in, but dipped them in oil before I put them in place.
+ new metal plates and new springs and all appears to be good Thumbs Up
Clutch slip is gone Smile and it appears to be a bit smoother to engage gears Thumbs Up
So far so good!
Fizzer Thou
PostPosted: 14:20 - 07 Oct 2011    Post subject: Reply with quote
I see it this way - if the clutch is supposed to be a wet clutch,you install new plates into the basket and replace the side cover.You then fill the engine with oil to the correct level.Some parts of the new friction material will be affected by the oil.This could compromise performance - it might not.But if the friction plates were soaked beforehand,then plate action would be uniform.
But then I have only been working on bike engines for 36 years.
pepperami
PostPosted: 14:38 - 07 Oct 2011    Post subject: Reply with quote
All plates were dipped and left in oil for approx 15 mins before I put them in, whilst I was doing other stuff.
Nothing was put in the bike dry (ie metal plates were smeared with oil also) and the bike was gently run with the clutch being engaged and disengaged several times before any load was put on it.
All appears to feel fine and smooth at the moment.
I have pulled the side off many an off-road bike and slammed in a new set of plates and then ridden again that same meet without any problems.
I was seeking wisdom in that it may be different for road bikes?
I would of rather given them a soaking in oil for a few hours but time is of the essence.
In the past I have never soaked clutch plates for my road bikes ie x5 GT 250`s & RD 250 but was wondering if there was a reason for doing it now, for example the friction material is different?
unitycrippledatmo wrote:
probably an old ritual from the days of cork clutch plates
So what are your clutch plates made of then?
Last EBC clutch kit I bought had instructions on the box to soak the friction plates in oil before fitting.
PostPosted: 16:33 - 07 Oct 2011    Post subject: Reply with quote
A clutch is a centrifuge and centrifuges are used to dry stuff, so anything more than the barest minimum of oil is going to get thrown off the surface of the friction pads during the first few seconds anyway. Any oil not on the surface of the friction material isn't actually doing anything.
hmmmnz
PostPosted: 21:13 - 07 Oct 2011    Post subject: Reply with quote
just fitted a new cluch the the bandit 12,
on the instructions i got from barnett, they said only soak the plates for 10mins any more is just wasting time,
clutch is good as gold, and works fine,
the humans are dead
I kick arse for the lord
Fizzer Thou
PostPosted: 22:39 - 07 Oct 2011    Post subject: Reply with quote
Except that oil is normally introduced at the centre of a clutch and is used to help keep the plates cool as well as to move away the debris.
johnsmith222
PostPosted: 00:05 - 08 Oct 2011    Post subject: Reply with quote
It really is one of those things that probably isn't that important to do, but it costs nothing to stick them in a tub with some oil overnight whether it's wasting time or not.
Marmalade
PostPosted: 00:07 - 08 Oct 2011    Post subject: Reply with quote
I usually stick them in a bowl of oil when i start the job, they maybe get an hour to soak before going in.
Got to be better than having them fitted dry
PostPosted: 00:08 - 08 Oct 2011    Post subject: Reply with quote
Happened across this https://youtu.be/Q4_k9TeQfDg
Turn the sound down for obvious reasons...but note the plates soaking. Thumbs Up
PostPosted: 09:26 - 08 Oct 2011    Post subject: Reply with quote
On some bikes, not all. That has no bearing on the actual topic of soaking plates anyway.
pepperami
PostPosted: 13:46 - 08 Oct 2011    Post subject: Reply with quote
So in conclusion it might of been better to give them an overnight soak, but as time was limited, putting them in after a 15 minute soak wont be to much of an issue Smile Thumbs Up
gave everything a look-see and try out today and all seemed hunky-dory Thumbs Up
The last post was made 14 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 103.7 Kb
