Haynes manual has my spark plug size wrong?
EazyDuz
PostPosted: 13:27 - 07 Oct 2011    Post subject: Haynes manual has my spark plug size wrong? Reply with quote
This is confusing.
Bought a new spark plug after checking the haynes which the correct one is, it said CR8ES, ordered it, and the thread is too small :S
Took the existing one out (should have anyway to double check but i trusted Haynes) and the one in there is a DR8ES.
Why?
Haynes says CR8ES, ebay search for GZ125 spark plug all comes up with CR8ES as well, but mine is a larger one?
Has my engine been messed with or something?
EazyDuz
PostPosted: 13:31 - 07 Oct 2011    Post subject: Reply with quote
This place has it right:
https://www.patternparts.net/p-Suzuki_GZ_125_NGK_DR8ES_W_K8_98_08-15344.aspx
How annoying!
FerretFing
PostPosted: 14:47 - 07 Oct 2011    Post subject: Reply with quote
try the NGK partfinder;
https://www.ngkpartfinder.co.uk/motorbikes_scooters.php?type=SPARK%2520PLUGS&manufact=SUZUKI&engine=125&model=GZ125%2520W%252C%2520X%252C%2520Y%252C%2520K1-K3%2520Marauder
Looks like the Haynes is quoting the plug for 2005 & on whereas the plug is a different one for 1998-2003
I'd be surprised if the Haynes doesn't mention both if you look carefully
EazyDuz
PostPosted: 14:52 - 07 Oct 2011    Post subject: Reply with quote
Yea ive worked it out now, the frame and registration for my bike is 2005 which is correct, but the fitting for the spark plug is for the older GZ which was made up until 2003, which means either:
It has an old engine in it, at least two years older than the bike its on
Or
The engine was made in 2003, then Suzuki put it on a 2005 bike when it was new (which wouldnt be the case)
Feel a bit bummed about it now to be honest, finding out ive got an older engine in my bike, unless there is another explanation?
PostPosted: 15:06 - 07 Oct 2011    Post subject: Reply with quote
When you say the "frame", do you mean the model year digit on the VIN?
EazyDuz
PostPosted: 15:26 - 07 Oct 2011    Post subject: Reply with quote
Well the VIN is VTTAP171200101303, haynes says thats 2005
sidewinder
PostPosted: 16:29 - 07 Oct 2011    Post subject: Reply with quote
probably built on the change over. maybe registered and 2005.It happens Very Happy
EazyDuz
PostPosted: 17:08 - 07 Oct 2011    Post subject: Reply with quote
Had an engine change at some point, it has an 03 engine in it.
The last post was made 14 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 53.97 Kb
