| jjdugen |
 jjdugen World Chat Champion
| MickC |
 MickC Spanner Monkey
 Posted: 09:32 - 08 Oct 2011 Post subject: |
And on top of all those other problems there is the little extra problem of the decibel restriction placed on bikes registered after 1982/86 decibel ( https://thames-valley-region.mag-uk.org/Pages/legisla_chronology_of_motorcycles.htm ). ( lucky me 81 and fitted with CV carbs which i have been told adjust rather well to straight through pipes - but not to pod filters! )
So crappy gas millage, running issues, a noise loud enough to wake the dead/deafen the rider and they give any bored PC plod an excuse to but fuck you!!!! ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| stinkwheel |
 Posted: 11:05 - 08 Oct 2011 Post subject: |
Which is why a dynojet kit, while seeming an extortionate price for a small bag of jets, springs and throttle needles, is actually worth the money. They do the dyno work so you don't have to.
The throttle needles and throttle spring in a dynojet kit are often radically different to the standard ones and the needles are something of a black art, tricky to tweak without a lot of knowledge and skill (and availability of needles).
Fitting a straight through pipe, buy a stage 1 kit, fit it, then tweak on the dyno. One run will probably do it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jjdugen |
| stinkwheel |
 Posted: 15:52 - 08 Oct 2011 Post subject: |
Or with a well designed pipe, a free flowing air filter and a properly set up dynojet kit. More power, smoother fuelling across the rev range and better fuel economy during normal riding.
That's been my experience (VFR 750, K&N filter, straight through Micron end can and stage 1 kit). Smoother off the throttle, better acceleration and better fuel economy. Can't comment on top speed because I've only ever had it fully flat-out twice. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| instigator |
 instigator Super Spammer
| Kickstart |
 Kickstart The Oracle
| jjdugen |
| Kickstart |
 Posted: 18:45 - 08 Oct 2011 Post subject: |
Don't think the actual pressure is the issue as it is the pressure waves bouncing back that cause it (actual pressure would really screw things up, in the same way that you get a large flat spot at half the rpm the exhaust is working at). Longer or shorter pipes change this dramatically. Larger bore pipes destroy this effect.
Possible that with a long valve overlap it is pushing mixture back through the engine into the carb and increasing the pressure around the choke. Stops the carb working to draw mixture from the float bowl while also stopping the "slide" in the carb from lifting (as I am sure you know but for others info, on a CV carb the slide is lifted by the lower pressure caused by the air speed through the carb).
| jjdugen |
The last post was made 14 years, 117 days ago. Instead of replying here, would creating a new thread be more useful? |
