Big click.
BLOWerMEat
PostPosted: 17:39 - 08 Oct 2011    Post subject: Big click. Reply with quote
Okay so here is the scoop I pulled up at home and the bike died with a what felt like a last sigh. When I tried to start it again the starter relay just clicked. It would not push start. I tried to jump it off of my car and the bike just made a big click WTF?????
u cant phase me you people who ( Cant Understand Normal Thinking.)s
J4mes
PostPosted: 17:46 - 08 Oct 2011    Post subject: Reply with quote
Sometimes the battery is so flat it can't be bumped or jumped. Get it charged if you have a charger!
BLOWerMEat
PostPosted: 17:50 - 08 Oct 2011    Post subject: battery not the problem Reply with quote
If the battery is not the problem what else would it be. rectifier, starter relay?
J4mes
PostPosted: 17:53 - 08 Oct 2011    Post subject: Reply with quote
If the battery has gone flat then I'd say the reg/rec probably isn't charging it. Starter relay is probably fine if it's clicking, as that means it is making contact when required to but the battery can't supply the power to turn the starter, so it just clicks away.
Ichy
PostPosted: 18:16 - 08 Oct 2011    Post subject: Reply with quote
If it won't jump start off a correctly connected and charged car battery then it isn't the rectifier or the battery that is causing the problem.
Did you connect the car battery directly to the bike battery?
Do any of the tell tale lights come on? Can you use the indicators or headlight?
BLOWerMEat
PostPosted: 18:42 - 08 Oct 2011    Post subject: Reply with quote
PostPosted: 19:16 - 08 Oct 2011 Post subject:
yes and every thing is a go until I hit the start button then the bike clicks and even puts a hard load on the car.
Ichy
PostPosted: 19:56 - 08 Oct 2011    Post subject: Reply with quote
Sounds more like a short in the starter or starter relay. Bypass the relay and attach the jump leads directly to the starter motor and see if it turns the engine over.
volvodai
PostPosted: 21:10 - 08 Oct 2011    Post subject: Reply with quote
try to bump start,starter motor probably stuck once started starter may work normal again (unless its an automatic)
Ichy
PostPosted: 22:08 - 08 Oct 2011    Post subject: Reply with quote
Good to see you read the OPs posts. Rolling Eyes
BLOWerMEat
PostPosted: 23:24 - 08 Oct 2011    Post subject: Reply with quote
I found a short at the rectifier connection. The wire going to the stator was melted away at the connector, which possibly shorted out at the frame. Should I check the stator or just replace the wire which Looks like I would need another connector .
Beelzebob
PostPosted: 00:37 - 09 Oct 2011    Post subject: Reply with quote
You should check everything that's near/related/might be affected. I would, certainly. No point changing connector and even stator, and finding when you switch it on again it fries something else cos of another short.
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
BLOWerMEat
PostPosted: 04:21 - 09 Oct 2011    Post subject: okay I took the stator cover off. Reply with quote
I took the stator cover off and it smells like gas almost thought it was at first but then the magnets have some hard plastic around them like something melted is that good?
Ichy
PostPosted: 08:37 - 09 Oct 2011    Post subject: Reply with quote
It's really hard to see anything in those photos but the magnets are held in place but a sort of resin so I guess that might look like melted plastic.
Just out of interest I would connect the starter motor directly to a battery just to make sure that its working. It may be that a short or excessive drain from another circuit may have cause the rectifer wire to burn out.
The last post was made 14 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 75.35 Kb
