| steven_191 |
 steven_191 Nearly there...
| Ichy |
 Ichy World Chat Champion
 Posted: 20:23 - 08 Oct 2011 Post subject: |
It should be a body filler with metal partials but even that isn't guaranteed to work. The bigger problem is that a lot of fillers will crack or fall out when the powder is baked.
One of the reasons a lot of custom bikes have painted frames is down to the amount of filler they use to blend in the welds. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/
| kestrel |
 kestrel Nearly there...
| Nexus Icon |
| Ichy |
| steven_191 |
 Posted: 08:59 - 09 Oct 2011 Post subject: |
https://i1112.photobucket.com/albums/k493/steven_191/4628dcb7.jpg
I used that JB weld. It says it's heat resistant to 300deg and the powder coaters say they bake the ally parts at 200 so should be fine.
I've put in on over quite a big area but really it's quite a thin layer. It wasn't a big dent and I managed to heat up the arm and use a lever to pull out the bottom edge. Just the bit above that that had stretched that I needed to level out. I sanded it after this and most of it came off.
I'll post up a picture after and we'll see how the powder goes |
| Ichy |
 Posted: 09:16 - 09 Oct 2011 Post subject: |
As myself and kestrel mentioned the rate of thermal expansion of the two different materials can break the bond between them. There is also the risk of air bubbles getting trapped in the filler. It'll be interesting to see how it turns out.
Did the powder coating guy suggest JB weld? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| steven_191 |
 Posted: 17:28 - 09 Oct 2011 Post subject: |
| steven_191 |
| chris-red |
| steven_191 |
The last post was made 15 years, 32 days ago. Instead of replying here, would creating a new thread be more useful? |
