Locking a left handed nut?
Martay
PostPosted: 15:10 - 09 Oct 2011    Post subject: Locking a left handed nut? Reply with quote
Hi,
Not quite a bike, but a single cylinder mower engine, hope ya'll dont mind.
The mower engine has a pull starter, which is crap. It either doesnt spin the engine for enough rotations to fire it up, then every 3rd pull the spring unravels and you need 8 tiny Japanese hands to refit it all.
Ive totally removed the pull starter and spin it up with a cordless drill on the crank nut. Works lovely. Problem: Crank nut is a lefty, so if im a bit heavy with the drill, it undoes the nut rather that cranking the engine! The flywheel is on a woodruff key (?) so it isnt a problem, just bloody annoying!
Any suggestions? I thought id put a second nut on the thread and nip the 2 together. 10minutes of fiddling later i realise a normal nut wont go on a lefty thread! Embarassed
Ta
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
MaybeGuy
PostPosted: 15:17 - 09 Oct 2011    Post subject: Reply with quote
drill and pin it
Fisty
PostPosted: 15:51 - 09 Oct 2011    Post subject: Reply with quote
Threadlock? Or buy another nut and double nut it.
Could always put a small weld blob on it.
Fatter and faster than Fret
yen_powell
PostPosted: 17:00 - 09 Oct 2011    Post subject: Reply with quote
The old ant-theft trick is to bruise the thread above the nut, but that would mean not being able to easily remove it if needed. Better, as stated above, get a thin tab washer and turn one side up hard againt one of the nut's flats.
XT1200Z and a DR350 in bits
The Artist
PostPosted: 17:22 - 09 Oct 2011    Post subject: Reply with quote
blob of weld ftw
PostPosted: 17:27 - 09 Oct 2011    Post subject: Reply with quote
I presume the nut is above some kind of flywheel. I would be tempted to put a small hole in the flywheel either side of the nut, and then use a cut down larger socket with a couple of pins on it to line up with the holes.
Raffles
PostPosted: 18:52 - 09 Oct 2011    Post subject: Reply with quote
I'd drill and tap a thread through the side of the nut and use a grub screw to secure the nut to the shaft. This method will allow you to easily remove the nut at some later stage should you need to do so.
The last post was made 14 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 57.36 Kb
