Wrist pain
Noobie_42
PostPosted: 17:14 - 09 Oct 2011    Post subject: Wrist pain Reply with quote
Ive been doing a few rides since i passed my mod 2 last week,short rides have been ok but after an hour I have been getting quite a bit of discomfort in my wright wrist. Has any one else experienced this or found a solution?
Still gettin away with it.MOD 2 passed 29/09/11
CBF125>Bandit 600n>Speed Triple 1050>Street Triple R
PostPosted: 17:30 - 09 Oct 2011    Post subject: Reply with quote
It's common for new riders. Unusual strain on your wrists coupled with holding the bars too tight. Grip the bike with your legs and take the weight off your arms. Relax your grip.
Noobie_42
PostPosted: 17:36 - 09 Oct 2011    Post subject: Reply with quote
To be fair my grip is fairly loose already,looks like i better put in a few more miles then Laughing
Slacker24seve...
PostPosted: 18:16 - 09 Oct 2011    Post subject: Reply with quote
Visit Palmetta more often, that'll toughen up the wrists Cool
Banger rallies are ace
PostPosted: 19:52 - 09 Oct 2011    Post subject: Reply with quote
It depends whether it's your arm position, or strain from holding the throttle on. If it's the latter, try a cramp buster aka cruise control:
https://www.sierrabmwonline.com/images/Crampbuster.jpg
It's just a plastic tab that you can press with the heel of your hand instead of gripping the throttle. Simple, effective for some people - I like mine.
Maverick Rigger
PostPosted: 19:59 - 09 Oct 2011    Post subject: Reply with quote
Stupid question I know but are you reposition your hand after accelerate or decelerating?
The motorcycle presents you a challenge to master the machine, a challenge to adventure. You ride through the wind, linked to the road by a vehicle that responds to your commands as no other does. Unlike an automoblie, there is no metal cage around you, Like and airplane, a pre-ride inspection and regular maintenance are essential to your safety. Your reward freedom.
Noobie_42
PostPosted: 20:27 - 09 Oct 2011    Post subject: Reply with quote
Thats not a stupid question and I have no idea,should I be? and if so how?
MadCatLady
PostPosted: 21:08 - 09 Oct 2011    Post subject: Reply with quote
Having had a Colles fracture to my right wrist several years ago, I also get wrist pain on anything other than short journeys. I wear a neoprene wrist support which helps somewhat, but doesn't get rid of it completely.
CBT - 06/07/11 Theory passed - 19/09/11 Module 1 - 00/00/00 Module 2 - 00/00/00
Yamaha YBR 125
el_oso
PostPosted: 22:35 - 09 Oct 2011    Post subject: Reply with quote
your gloves may be too tight.
whenever i wear my leather jacket with summer gloves i will sometimes get discomfort after a while on the bike. the arms of my jacket are a little long and the strap on my gloves sits just where jacket cuff is so i can't do the Velcro up properly without it being too tight.
Duke 390
Car: Jeep Wrangler 4.0L
Noobie_42
PostPosted: 17:11 - 10 Oct 2011    Post subject: Reply with quote
Been to work on the bike today and the pain is still there.Not as bad but it still doesnt feel right.Going to loosen the gloves tomorrow and see how that goes.Maybe I should practice some other form of wrist excercise,any suggestions Wink
PostPosted: 17:23 - 10 Oct 2011    Post subject: Reply with quote
Unless you have body issues you should be able to lower your forearms. This can help in two ways 1 you control the bike better and 2 the weight is transferred elsewhere. You may be riding too upright, arms outstretched style.
Let the tank take some weight when braking. Use the pegs to shift your weight. Shake-out the wrists at the lights.
Dazbo666
PostPosted: 18:22 - 10 Oct 2011    Post subject: Reply with quote
also have you made sure that your brake/clutch controls are in the right position for you?? ie, should be somewhere near a straight line along your forearm, thru your wrist, and thru the brake/clutch lever. In theory you shouldn't need to arch your wrist forwards or bent backwards when reaching for the levers.
I've had this exact issue previously with mountainbikes, and more recently when I first bought the Bandit
Word of the day : DILLIGAF
waffles
PostPosted: 18:30 - 10 Oct 2011    Post subject: Reply with quote
Definitely worth checking this out, my brake/clutch levers weren't in the right place for me on my bike and it gave me no end of wrist pain. My mate helped me adjust them and now I only get achey wrists after particularly long rides.
Fizzer Thou
PostPosted: 19:29 - 10 Oct 2011    Post subject: Reply with quote
I recommend these
https://i180.photobucket.com/albums/x21/adoptagreyhound/Transcription/HandExerciser.jpg
I keep one in the car and one in the house.20 squeezes each hand,then another 20.
As I ride enduro you need the strength in your wrists.These also help to build up the muscles in the forearms.
If you cannot find any of the above,squeeze a tennis ball.
Always have a 'Plan B'
Sherwood Bambi
PostPosted: 21:44 - 10 Oct 2011    Post subject: Reply with quote
I found myself suffering from wrist pain while doing my DAS - my instructor explained it was probably largely due to being too tense and gripping too tightly.
Ever since then I use a variety of techniques to alleviate it - including the old "funky chicken" bit with the arms, shaking the wrist / hand when stationary at lights and just generally trying to relax a bit more.
Time, experience and confidence have helped massively - though I do like the look of those cramp busters !
Berk
PostPosted: 23:16 - 10 Oct 2011    Post subject: Reply with quote
Fizzer Thou wrote:
I recommend these
When my grandad used to go scrambling he found his wrists were really weak, so he got 2 pairs of pliers and whenever he had a quiet moment at work he'd sit and squeeze them. Got to the point where he could get the ends of the handles to meet.
Same principle, but it meant he didn't have to buy any fancy kit (that probably didn't exist back then).
Maverick Rigger
PostPosted: 16:18 - 11 Oct 2011    Post subject: Reply with quote
One of the first thing my instructor taught me (this is going back a bit now). Is to reposition your hand so your wrist is straight, both your hands should be in a comfortable position. Just sort of roll your finger around the throttle so your wrist is straight again.
Failing that, seeing as we are punting stuff that we use.
https://www.powerballs.com/
Builds your upper body up a treat, including your forearm and wrist.
Noobie_42
PostPosted: 05:51 - 12 Oct 2011    Post subject: Reply with quote
Started to re-position my hand yesterday,feels better but i will check on the position of the clutch and brake levers.Thanks for all the ideas guys.
Angel Girl
PostPosted: 13:59 - 13 Oct 2011    Post subject: Reply with quote
I have tendonitis now which is slowly improving, the doc said most likely cause was gripping too tightly when I started riding a couple of months ago (which I did!)
I've started to relax now when I'm riding and my wrist is slowly getting a little better but it will take time and I have to rest it well.
Par for the course I guess Smile
Rides Honda CB500S aka "The Orange Peril"
The last post was made 14 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 103.94 Kb
