Headstock bearings on the way out?
Marcg868
PostPosted: 17:47 - 09 Oct 2011    Post subject: Headstock bearings on the way out? Reply with quote
Not really sure what to make of this as i don't know. Basically when i press the front brake, there is a knocking sound coming from the bars, now it doesn't seem to do it on the flat but more so if I'm on the brakes downhill.
Could this be my headstock bearings on the way out?
Bikes Hyosung GT125R 2006 with 23,000 miles.
JACK, MISS YOU LOADS YOU LEGEND.
pepperami
PostPosted: 18:14 - 09 Oct 2011    Post subject: Reply with quote
yes!
serlant
PostPosted: 18:17 - 09 Oct 2011    Post subject: Reply with quote
Could need tightening, normally the indicator of worn headbearings is notchiness with the bars straight, and the bike is unwilling to turn into corners, a good way to tell is to get the front end off the floor and try putting the bars just off straight, if they move back to dead straight on their own i'd replace them.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
Maruchino
PostPosted: 18:34 - 09 Oct 2011    Post subject: Reply with quote
Sometimes a slight knocking from a front end is the pads in the calipers moving forward (obviously more on worn calipers/pads/pins etc).
As previously mentioned, best to get the front off the ground and check properly.
Teflon-Mike
tl;dr
PostPosted: 00:29 - 10 Oct 2011    Post subject: Reply with quote
A knock means that there is some 'play' in something, somewhere.
It could be the headstock bearings, need adjusting, could also be that the fork buishes are shot; could be that brake caliper mounts are loose; floating caliper pins are worn; floating brake disk bushes worn; pads loose, or any number of anomolies, like a cable is fretting on a plastic cover!
So dont jump to conclusions; do the checks and eliminate the possibilitoes in turn to be sure.
neil.
PostPosted: 05:57 - 10 Oct 2011    Post subject: Reply with quote
Exactly the same symptoms on the YBR - if you are at a standstill, and hold the front brake on whilst pushing down/forward hard to pump the suspension, does it happen? In my case it still did, and re-torquing the headstock bearings sorted the issue. Thumbs Up
The last post was made 14 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.74 - MySQL Queries: 13 - Page Size: 48.98 Kb
