Unleaded fuel additive in older cars
Nope.
PostPosted: 02:13 - 10 Oct 2011    Post subject: Unleaded fuel additive in older cars Reply with quote
Alright, so I went out today and got myself a Blaze Orange 1971 MGB GT. Im picking it up on friday evening when I can get a lift up there. Having only owned one car that needed a leaded fuel additive (that being a shitty old ford orion I used to rag around a mates farm at about 14) I cant for the life of me remember what the hell your supposed to do with it (Other then the obvious thing of putting it in the tank).
Its pretty expensive stuff for what it is (£12.49 for 250ml from Halfrauds) but how far does that go realistically? Is that going to last me 100 litres, 50 litres, 200 litres?
Any tips for its use would be appreciated Thumbs Up
Oh, and pics of the car on friday if its still light, if not then saturday.
oldpink
PostPosted: 07:21 - 10 Oct 2011    Post subject: Reply with quote
the bottle will tell you the ratio to mix it with
years ago I was told to use Nitrox 4 as it was the best and has an octane booster in it as well
its a bit more expensive but supposedly worth it, same way I never scrimp on 2 stroke for the crossers
a couple of pence extra to get some decent gear saves you money in the long run
Marmalade
PostPosted: 07:57 - 10 Oct 2011    Post subject: Reply with quote
Did you check to see that it still needs an additive?
It may well have been sorted by now to be perfectly ok on unleaded
jowettdriver
PostPosted: 09:49 - 10 Oct 2011    Post subject: Reply with quote
You may also find it completely unnecessary. I run a 1981 BMW R65, a 1974 Triumph Spitfire and a 1950 Jowett Javelin all of which have soft iron valve seats and run perfectly happily on super unleaded. In the 10 years since leaded fuel was phased out I have seen no valve seat recession (VSR).
The additives are quiet expensive so for my money I have always been of the opinion, that if I find signs of VSR happening then it will take many thousands of miles to burn the valve seat away, and when the head is finally knackered I will have the conversion done. To have hardened inserts fitted, they have to cut out the old seats so you lose nothing by allowing them to slowly recede.
You will also find that if VSR does happen that a lot will depend on your driving style. If you drive it everywhere at very high revs and with a heavy right foot then the VSR will be so much quicker.
When the FBHVC (Federation of British historic vehicle clubs) tested lead replacement additives back in 2000 they took a number of BMC A series engines and subjected them to about 6 weeks running at 5500 RPM (about red line for the A series in normal trim) and then measured VSR on them. The problem is that the testing does not really replicate the normal use of older engines, and while it tested the efficiency of additives it cannot be used as a basis for whether VSR is going occur.
Just my thoughts on the subject, if you decide to use an additive then at the time of testing the FBHVC found that the Millers VSP plus was the most effective. That said though other products have become available since that have not been tested. For more information https://fbhvc.co.uk/fuel-information/#f4
Just my thoughts on the subject.
Cheers Tim.
Bikes: 1980 Honda CX500, 2003 Honda CB250, 1980 Honda CG125
Nope.
PostPosted: 16:38 - 10 Oct 2011    Post subject: Reply with quote
Well, im intending to get a stage 2 head next year when im used to the car so Ill get the hardend valve seats with that.
Its not running hardend valve seats at the moment, the cars almost stock. The current owner doesn't run it very often but when he does he uses additive.
Ah well, im off to order a case of Castrol Valvemaster Thumbs Up
Shaft
PostPosted: 19:04 - 10 Oct 2011    Post subject: Reply with quote
If I were you, I wouldn't waste my money.
I'm completely with Tim on this one, there's been an awful lot of scaremongering over this issue (probably most of it was instigated by those who stood to make money from it) and I've yet to see any real evidence of it being even a slight concern.
My company specialises in classic cars (and we all run them) and not once have I seen any sign of VSR; in fact, we pulled the heads on my colleague's Essex a couple of weeks ago and the seats were completely fine, despite the fact that he has never used additives, or even high octane unleaded.
Save your cash for something worthwhile.
mistergixer
PostPosted: 19:29 - 10 Oct 2011    Post subject: Reply with quote
I recall my Father and I retarded the ignition a few degrees on my old Mini, although that was most likely to prevent any pinking and knock rather than preventing valve seat issues.
That poor little car went to the great scrapheap in the sky many years ago (courtesy of my brother's 'enthusiastic' driving), so forgive me if my memory's a little hazy.
Space Monkey #7
Ariel Badger
PostPosted: 22:59 - 10 Oct 2011    Post subject: Reply with quote
I have run old engines on unleaded for years with no problems. IMHO the whole thing was a con just like the Y2K Bug.
chrisw
PostPosted: 23:09 - 10 Oct 2011    Post subject: Reply with quote
I agree. What's the point?
The idea is to stop valve recession, if it happens you take the head off and insert hardened seats.
What do you do to convert a head to unleaded? You take the head off and insert hardened valve seats.
Just use it, if the valve clearances start to tighten up more quickly than expected, get the head work done.
Shaft
PostPosted: 00:18 - 11 Oct 2011    Post subject: Reply with quote
Just reflecting on this thread, mechanical condition on an MGB is almost irrelevant, the primary concern is always the shell.
MGBs are probably the best supported classic car on the planet (outside of the US) as everything is available and pretty cheap, but fixing body maladies can be very labour intensive.
If the plan is to do a mechanical upgrade next year, forget poncing about with fuel additives and concentrate on making sure the shell is A1, that's the bit that will cost the serious money.
Nope.
PostPosted: 01:26 - 11 Oct 2011    Post subject: Reply with quote
The shell is pretty much already in A1 condition having had a full restoration only 6 years ago and having only done 6000 miles since. The door bottoms are a little rough and the jack points could do with a little bit of welding but other then that its sound.
I know that the mechanicals are the cheap parts on the B but they SEEM pretty sound as well.
Just looking to keep the engine in the best condition I can until I can easily afford to upgrade it. I want to keep the parts like the head as original as possible which is why when I remove it ill be keeping it incase I ever want to restore the car back to its original condition.
Thanks for your input none the less Thumbs Up
Nope.
PostPosted: 01:51 - 11 Oct 2011    Post subject: Reply with quote
Ok, I cant resist, pics from the advert:
https://atechplace.co.uk/MG/Photos/ebay/1.jpg
https://atechplace.co.uk/MG/Photos/ebay/2.jpg
https://atechplace.co.uk/MG/Photos/ebay/3.jpg
https://atechplace.co.uk/MG/Photos/ebay/4.jpg
https://atechplace.co.uk/MG/Photos/ebay/5.jpg
https://atechplace.co.uk/MG/Photos/ebay/6.jpg
https://atechplace.co.uk/MG/Photos/ebay/7.jpg
https://atechplace.co.uk/MG/Photos/ebay/8.jpg
https://atechplace.co.uk/MG/Photos/ebay/9.jpg
The last pic is of the history file that comes with it. Stuff back to the original owner including the original bill of sale and every MOT its ever had.
Andy_Pagin
PostPosted: 12:14 - 11 Oct 2011    Post subject: Reply with quote
Very pretty, hasn't got those ghastly hideous vile disgusting black bumpers they needed to keep the yanks h&s nazis happy. MG should have told then to learn to like chrome or fuck off.
Shaft
PostPosted: 12:17 - 11 Oct 2011    Post subject: Reply with quote
I'm not normally into prophet of doom posts, but I would be very, very wary of a car that's had a 'full restoration', but already has rust issues less than 6000 miles later.
These cars are notorious for unseen rust problems in the sills and they are extremely difficult to put right; it's no coincidence that they started reproducing complete shells, the cost of repairing them is outrageous.
If I were in your shoes, I would go with a trolley jack and use the jacking points to make sure that the car is capable of supporting it's own weight, without making curious creaking noises or closing up the door gaps, but be prepared for the sills to collapse.
Unfortunately, not everyone has the same idea of what 'full restoration' actually means and there are still an awful lot of these around that have had cosmetic work, but haven't had the correct structural attention and an MOT is not necessarily a foolproof indicator of a rust free body.
Tread carefully Exclamation
Charlie
PostPosted: 13:13 - 11 Oct 2011    Post subject: Reply with quote
Lovely looking car Thumbs Up I'd like one one day.
Nexus Icon
PostPosted: 13:26 - 11 Oct 2011    Post subject: Reply with quote
https://www.broquet.co.uk/
My dad ran his ancient Merc with one of these in for years after 4* fuel disappeared. It never had any issues at all.
Greetings from Shitsville!
Walloper
PostPosted: 21:10 - 11 Oct 2011    Post subject: Reply with quote
I have not googled it but I think the AA, RAC and or the police used Astras when u/l fuel was introduced.
There was reported incidence of VSR in these cars. So everyone panicked and all sorts of theories came around to ward off the devil in u/l fuel.
One of the most popular is to run your car on leaded fuel every now and then. (If you can remember what you put in last time.)
I think possibly Astras had a bad batch of metal and this sparked the scare.
I may be talking shite though... Confused
.Chris.
PostPosted: 22:32 - 11 Oct 2011    Post subject: Reply with quote
Not total shite - the lead builds up on the valve seat, creating a 'lead memory' that lasts for a while after you start running on unleaded. Not sure that just the occasional tank of leaded would produce this effect to any significant extent, however.
I do use additives in my A-series engined car, but then it does quite a high mileage with quite a lot of driving at highish speed. Personally I'd advise you to do the same, as valve seat recession does occur (I have personal experience of this).
Not sure how much B-Series heads go for, but an alternative is to not bother with the additives, and just swap the head over for a different one (acquired for a few quid) if you get any trouble. This used to be a good idea on A-series cars, but in the past couple of years the price of decent spare heads seems to have risen quite a lot, making it a less attractive option.
As for fuel catalysts, they're a bit of an unknown quantity. None of the manufacturers submitted them for the tests the FBHVC did in 2000. Therefore personally I'd avoid.
Chris
1985 Kawasaki Z550F
Nope.
PostPosted: 23:08 - 11 Oct 2011    Post subject: Reply with quote
HA! Just found out theres a garage a couple of miles from me that sells leaded 4 star. Guess I know where ill be filling up from now on Very Happy
Walloper
PostPosted: 10:20 - 12 Oct 2011    Post subject: Reply with quote
I hope it's not just an auld **** sticker on the pump...
Mr. Green
The last post was made 15 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 128.38 Kb
